[mapserver-commits] r10262 - sandbox/mapserver6
svn at osgeo.org
svn at osgeo.org
Tue Jun 29 11:26:14 EDT 2010
Author: tbonfort
Date: 2010-06-29 15:26:14 +0000 (Tue, 29 Jun 2010)
New Revision: 10262
sandbox/mapserver6/configure
sandbox/mapserver6/configure.in
sandbox/mapserver6/mapagg2.cpp
sandbox/mapserver6/mapcairo.c
sandbox/mapserver6/mapgdal.c
sandbox/mapserver6/mapoutput.c
sandbox/mapserver6/maprendering.c
sandbox/mapserver6/mapresample.c
sandbox/mapserver6/maputil.c
restore gdal output
Modified: sandbox/mapserver6/configure
--- sandbox/mapserver6/configure 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/configure 2010-06-29 15:26:14 UTC (rev 10262)
@@ -12952,8 +12952,8 @@
echo "${ECHO_T} Enabling debug features: -g in CFLAGS." >&6
else
- CXXFLAGS=`echo "$CXXFLAGS " | sed "s/-g //"`
- CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
+ CXXFLAGS=`echo "$CXXFLAGS -DNDEBUG " | sed "s/-g //"`
+ CFLAGS=`echo "$CFLAGS -DNDEBUG " | sed "s/-g //"`
fi
DEBUG_FLAGS=$DEBUG_FLAGS
Modified: sandbox/mapserver6/configure.in
--- sandbox/mapserver6/configure.in 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/configure.in 2010-06-29 15:26:14 UTC (rev 10262)
@@ -2425,8 +2425,8 @@
AC_MSG_RESULT([ Enabling debug features: -g in CFLAGS.])
else
fi
AC_SUBST(DEBUG_FLAGS, $DEBUG_FLAGS)
Modified: sandbox/mapserver6/mapagg2.cpp
--- sandbox/mapserver6/mapagg2.cpp 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/mapagg2.cpp 2010-06-29 15:26:14 UTC (rev 10262)
@@ -793,6 +793,7 @@
renderer->supports_imagecache = 0;
agg2InitCache(&(MS_RENDERER_CACHE(renderer)));
+ renderer->cleanup = agg2Cleanup;
renderer->renderLine = &agg2RenderLine;
renderer->renderPolygon = &agg2RenderPolygon;
Modified: sandbox/mapserver6/mapcairo.c
--- sandbox/mapserver6/mapcairo.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/mapcairo.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -75,7 +75,10 @@
cairo_t *dummycr;
} cairoCacheData;
-void initializeCache(cairoCacheData *cache) {
+void initializeCache(void **vcache) {
+ cairoCacheData *cache = (cairoCacheData*)malloc(sizeof(cairoCacheData));
+ *vcache = cache;
cache->facecache = NULL;
FT_Init_FreeType(&(cache->library));
/* dummy surface and context */
@@ -104,6 +107,7 @@
if(ccache->library)
FT_Done_FreeType(ccache->library);
+ free(ccache);
return MS_SUCCESS;
@@ -841,8 +845,7 @@
renderer->supports_imagecache=0;
renderer->supports_pixel_buffer=1;
renderer->supports_transparent_layers = 0;
- MS_RENDERER_CACHE(renderer) = malloc(sizeof(cairoCacheData));
- initializeCache(MS_RENDERER_CACHE(renderer));
+ initializeCache(&MS_RENDERER_CACHE(renderer));
renderer->startLayer = startLayerRasterCairo;
renderer->endLayer = closeLayerRasterCairo;
renderer->renderLine=&renderLineCairo;
@@ -881,8 +884,7 @@
renderer->supports_pixel_buffer=0;
renderer->supports_transparent_layers = 1;
renderer->startLayer = startLayerVectorCairo;
renderer->endLayer = closeLayerVectorCairo;
Modified: sandbox/mapserver6/mapgdal.c
--- sandbox/mapserver6/mapgdal.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/mapgdal.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -128,9 +128,11 @@
GByte *pabyAlphaLine = NULL;
char **papszOptions = NULL;
outputFormatObj *format = image->format;
+ rasterBufferObj rb;
GDALDataType eDataType = GDT_Byte;
msGDALInitialize();
+ memset(&rb,0,sizeof(rasterBufferObj));
/* Identify the proposed output driver. */
@@ -184,21 +186,21 @@
/* Establish the characteristics of our memory, and final */
/* dataset. */
-#ifdef TBT
if( format->imagemode == MS_IMAGEMODE_RGB )
nBands = 3;
- assert( gdImageTrueColor( image->img.gd ) );
+ assert( MS_RENDERER_PLUGIN(format) && format->vtable->supports_pixel_buffer );
+ format->vtable->getRasterBufferHandle(image,&rb);
else if( format->imagemode == MS_IMAGEMODE_RGBA )
pabyAlphaLine = (GByte *) calloc(image->width,1);
nBands = 4;
- else
-#endif
- if( format->imagemode == MS_IMAGEMODE_INT16 )
+ else if( format->imagemode == MS_IMAGEMODE_INT16 )
nBands = format->bands;
eDataType = GDT_Int16;
@@ -213,13 +215,11 @@
-#ifdef TBT
else
assert( format->imagemode == MS_IMAGEMODE_PC256
- && !gdImageTrueColor( image->img.gd ) );
+ && format->renderer == MS_RENDER_WITH_GD );
-#endif //TBT
/* Create a memory dataset which we can use as a source for a */
@@ -278,78 +278,62 @@
+ iBand * image->width * image->height,
image->width, 1, GDT_Byte, 1, 0 );
-#ifdef TBT
-#if GD2_VERS > 1
- else if( nBands > 1 && iBand < 3 )
- GByte *pabyData;
-#ifdef CPL_MSB
- pabyData = ((GByte *) image->img.gd->tpixels[iLine])+iBand+1;
-#else
- pabyData = ((GByte *) image->img.gd->tpixels[iLine])+(2-iBand);
-#endif
- GDALRasterIO( hBand, GF_Write, 0, iLine, image->width, 1,
- pabyData, image->width, 1, GDT_Byte, 4, 0 );
- else if( nBands > 1 && iBand == 3 ) /* Alpha band */
- int x;
-#ifdef CPL_MSB
- GByte *pabySrc = ((GByte *) image->img.gd->tpixels[iLine]);
-#else
- GByte *pabySrc = ((GByte *) image->img.gd->tpixels[iLine])+3;
-#endif
- for( x = 0; x < image->width; x++ )
- if( *pabySrc == 127 )
- pabyAlphaLine[x] = 0;
- else
- pabyAlphaLine[x] = 255 - 2 * *pabySrc;
- pabySrc += 4;
- pabyAlphaLine, image->width, 1, GDT_Byte, 1, 0 );
-#endif
- else
- image->img.gd->pixels[iLine],
+ else if(format->renderer == MS_RENDER_WITH_GD) {
+ gdImagePtr img = (gdImagePtr)image->img.plugin;
+ GDALRasterIO( hBand, GF_Write, 0, iLine, image->width, 1,
+ img->pixels[iLine],
image->width, 1, GDT_Byte, 0, 0 );
-#endif //TBT
+ else {
+ GByte *pabyData;
+ unsigned char *pixptr = NULL;
+ assert( rb.type == MS_BUFFER_BYTE_RGBA );
+ switch(iBand) {
+ case 0:
+ pixptr = rb.data.rgba.r;
+ break;
+ case 1:
+ pixptr = rb.data.rgba.g;
+ break;
+ case 2:
+ pixptr = rb.data.rgba.b;
+ break;
+ case 3:
+ pixptr = rb.data.rgba.a;
+ break;
+ assert(pixptr);
+ pabyData = (GByte *)(pixptr + iLine*rb.data.rgba.row_step);
+ pabyData, image->width, 1, GDT_Byte, rb.data.rgba.pixel_step, 0 );
if( pabyAlphaLine != NULL )
free( pabyAlphaLine );
-#ifdef TBT
/* Attach the palette if appropriate. */
- if( format->imagemode == MS_IMAGEMODE_PC256 )
+ if( format->renderer == MS_RENDER_WITH_GD )
GDALColorEntry sEntry;
int iColor;
GDALColorTableH hCT;
hCT = GDALCreateColorTable( GPI_RGB );
- for( iColor = 0; iColor < image->img.gd->colorsTotal; iColor++ )
+ for( iColor = 0; iColor < img->colorsTotal; iColor++ )
- sEntry.c1 = image->img.gd->red[iColor];
- sEntry.c2 = image->img.gd->green[iColor];
- sEntry.c3 = image->img.gd->blue[iColor];
+ sEntry.c1 = img->red[iColor];
+ sEntry.c2 = img->green[iColor];
+ sEntry.c3 = img->blue[iColor];
- if( iColor == gdImageGetTransparent( image->img.gd ) )
+ if( iColor == gdImageGetTransparent( img ) )
sEntry.c4 = 0;
else if( iColor == 0
- && gdImageGetTransparent( image->img.gd ) == -1
+ && gdImageGetTransparent( img ) == -1
&& format->transparent )
sEntry.c4 = 0;
else
@@ -385,7 +369,6 @@
GDALGetRasterBand( hMemDS, 4 ), GCI_AlphaBand );
#endif
-#endif //TBT
/* Assign the projection and coordinate system to the memory */
@@ -559,7 +542,7 @@
/* Initialize the object. */
format->imagemode = MS_IMAGEMODE_RGB;
- format->renderer = MS_RENDER_WITH_GD;
+ format->renderer = MS_RENDER_WITH_AGG;
/* Eventually we should have a way of deriving the mime type and extension */
/* from the driver. */
Modified: sandbox/mapserver6/mapoutput.c
--- sandbox/mapserver6/mapoutput.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/mapoutput.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -288,9 +288,7 @@
if( format != NULL )
format->inmapfile = MS_FALSE;
- if( format!= NULL && MS_RENDERER_PLUGIN(format) ) {
- msInitializeRendererVTable(format);
return format;
@@ -363,17 +361,15 @@
if( format == NULL )
return;
- if(MS_RENDERER_PLUGIN(format)) {
- format->vtable->cleanup(MS_RENDERER_CACHE(format->vtable));
+ if(MS_RENDERER_PLUGIN(format) && format->vtable) {
+ format->vtable->cleanup(MS_RENDERER_CACHE(format->vtable));
+ free( format->vtable );
msFree( format->name );
msFree( format->mimetype );
msFree( format->driver );
msFree( format->extension );
msFreeCharArray( format->formatoptions, format->numformatoptions );
- /* msFreeRendererVTable( format->vtable ); */
- msFree( format->vtable );
msFree( format );
@@ -642,6 +638,10 @@
*target = format;
format->refcount++;
+ if( MS_RENDERER_PLUGIN(format) ) {
+ msInitializeRendererVTable(format);
if( formatToFree )
msFreeOutputFormat( formatToFree );
@@ -686,12 +686,6 @@
dst->inmapfile = src->inmapfile;
- if( MS_RENDERER_PLUGIN(dst) )
- msInitializeRendererVTable(dst);
return dst;
@@ -1013,7 +1007,6 @@
msDebug( "OUTPUTFORMAT %s has IMAGEMODE RGB/RGBA, which is not supported for GD drivers.",
format->name );
return result;
Modified: sandbox/mapserver6/maprendering.c
--- sandbox/mapserver6/maprendering.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/maprendering.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -544,8 +544,11 @@
goto cleanup; /*finished plain polygon*/
} else if(symbol->type == MS_SYMBOL_HATCH){
+ if(MS_VALID_COLOR(style->backgroundcolor)) {
+ renderer->renderPolygon(image,offsetPolygon, &style->backgroundcolor);
double width = (style->width <= 0)?scalefactor:style->width*scalefactor;
- style->color.alpha = MS_NINT(style->opacity*2.55);;
+ style->color.alpha = MS_NINT(style->opacity*2.55);
double spacing = (style->size <= 0)?scalefactor:style->size*scalefactor;
ret = msHatchPolygon(image,offsetPolygon,spacing,width,style->angle, &style->color);
Modified: sandbox/mapserver6/mapresample.c
--- sandbox/mapserver6/mapresample.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/mapresample.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -1503,6 +1503,7 @@
if( MS_RENDERER_PLUGIN(sDummyMap.outputformat) ) {
assert(rb);
+ msInitializeRendererVTable(sDummyMap.outputformat);
if( rb->type == MS_BUFFER_GD ) {
assert( !gdImageTrueColor( rb->data.gd_img ) );
sDummyMap.outputformat->transparent = MS_TRUE;
@@ -1521,11 +1522,7 @@
sDummyMap.outputformat->imagemode = MS_IMAGEMODE_RGBA;
- sDummyMap.imagecolor.red = map->imagecolor.red;
- sDummyMap.imagecolor.green = map->imagecolor.green;
- sDummyMap.imagecolor.blue = map->imagecolor.blue;
- sDummyMap.imagecolor.alpha = map->imagecolor.alpha;
+ MS_INIT_COLOR(sDummyMap.imagecolor,-1,-1,-1);
Modified: sandbox/mapserver6/maputil.c
--- sandbox/mapserver6/maputil.c 2010-06-29 13:08:39 UTC (rev 10261)
+++ sandbox/mapserver6/maputil.c 2010-06-29 15:26:14 UTC (rev 10262)
@@ -664,9 +664,21 @@
if (img)
- if (MS_RENDERER_PLUGIN(img->format)) {
+#ifdef USE_GDAL
+ if( MS_DRIVER_GDAL(img->format) )
+ if (map != NULL && filename != NULL )
+ nReturnVal = msSaveImageGDAL(map, img,
+ msBuildPath(szPath, map->mappath,
+ filename));
+ else
+ nReturnVal = msSaveImageGDAL(map, img, filename);
+ } else
+#endif
+ if (MS_RENDERER_PLUGIN(img->format)) {
rendererVTableObj *renderer = img->format->vtable;
FILE *stream;
+ int ret;
if(filename)
stream = fopen(msBuildPath(szPath, map->mappath, filename),"wb");
else {
@@ -678,28 +690,19 @@
return MS_FAILURE;
if(renderer->supports_pixel_buffer) {
rasterBufferObj data;
- renderer->getRasterBufferHandle(img,&data);
+ if(renderer->getRasterBufferHandle(img,&data) != MS_SUCCESS)
+ return MS_FAILURE;
- msSaveRasterBuffer(&data,stream,img->format );
+ ret = msSaveRasterBuffer(&data,stream,img->format );
} else {
- renderer->saveImage(img, stream, img->format);
+ ret = renderer->saveImage(img, stream, img->format);
fclose(stream);
- return MS_SUCCESS;
+ return ret;
else if( MS_DRIVER_IMAGEMAP(img->format) )
nReturnVal = msSaveImageIM(img, filename, img->format);
-#ifdef USE_GDAL
- else if( MS_DRIVER_GDAL(img->format) )
- if (map != NULL && filename != NULL )
- nReturnVal = msSaveImageGDAL(map, img,
- msBuildPath(szPath, map->mappath,
- filename));
- else
- nReturnVal = msSaveImageGDAL(map, img, filename);
-#endif
#ifdef USE_MING_FLASH
else if(MS_DRIVER_SWF(img->format) )
@@ -1698,6 +1701,7 @@
#ifdef USE_GEOS
msGEOSCleanup();
#endif
msIO_Cleanup();
msResetErrorList();
@@ -1726,7 +1730,6 @@
unsigned char *red_dst, unsigned char *green_dst,
unsigned char *blue_dst, unsigned char *alpha_dst )
- int src_weight, dst_weight, tot_weight;
double alpha , onealpha, dstalpha;
/* Simple cases we want to handle fast. */
More information about the mapserver-commits
