[mapserver-commits] r10269 - sandbox/sdlime/common-expressions/mapserver
Wed Jun 30 23:49:04 EDT 2010
Author: sdlime
Date: 2010-07-01 03:49:04 +0000 (Thu, 01 Jul 2010)
New Revision: 10269
   sandbox/sdlime/common-expressions/mapserver/mapparser.c
   sandbox/sdlime/common-expressions/mapserver/mapparser.h
   sandbox/sdlime/common-expressions/mapserver/mapparser.y
   sandbox/sdlime/common-expressions/mapserver/mapraster.c
   sandbox/sdlime/common-expressions/mapserver/mapserver.h
   sandbox/sdlime/common-expressions/mapserver/maputil.c
More...
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.c
--- sandbox/sdlime/common-expressions/mapserver/mapparser.c	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.c	2010-07-01 03:49:04 UTC (rev 10269)
@@ -121,19 +121,14 @@
 #include "maptime.h" /* for time comparison routines */
 #include "mapprimitive.h" /* for shapeObj */
-// extern int msyylex(void); /* lexer globals */
-// extern int msyyerror(const char *);
+// int yylex(void); /* lexer globals */
+// int yyerror(const char *);
 shapeObj *yyshape;
 layerObj *yylayer;
 expressionObj *yyexpr;
-typedef union {
-  int intval;
-  char *strval;
-  shapeObj *shpval;
-} parseResultObj;
-parseResultObj yyresult;
+parseResultObj yypresult;
 /* Enabling traces.  */
@@ -150,7 +145,7 @@
 #endif
 #if ! defined (YYSTYPE) && ! defined (YYSTYPE_IS_DECLARED)
-#line 34 "mapparser.y"
+#line 29 "mapparser.y"
 typedef union YYSTYPE {
   double dblval;
   int intval;
@@ -159,7 +154,7 @@
   shapeObj *shpval;
 } YYSTYPE;
 /* Line 185 of yacc.c.  */
-#line 163 "mapparser.c"
+#line 158 "mapparser.c"
 # define yystype YYSTYPE /* obsolescent; will be withdrawn */
 # define YYSTYPE_IS_DECLARED 1
 # define YYSTYPE_IS_TRIVIAL 1
@@ -171,7 +166,7 @@
 /* Line 213 of yacc.c.  */
-#line 175 "mapparser.c"
+#line 170 "mapparser.c"
 #if ! defined (yyoverflow) || YYERROR_VERBOSE
@@ -370,13 +365,13 @@
 /* YYRLINE[YYN] -- source line where rule number YYN was defined.  */
 static const unsigned short int yyrline[] =
-       0,    72,    72,    73,    74,    82,    85,    93,   102,   110,
-     119,   127,   136,   144,   153,   154,   155,   168,   174,   180,
-     186,   192,   198,   204,   205,   213,   221,   230,   238,   246,
-     254,   260,   266,   272,   278,   284,   290,   311,   332,   338,
-     346,   352,   365,   366,   367,   368,   369,   370,   371,   378,
-     379,   380,   381,   391,   392,   393,   405,   406,   407,   410,
-     411
+       0,    67,    67,    68,    69,    77,    80,    88,    97,   105,
+     114,   122,   131,   139,   148,   149,   150,   163,   169,   175,
+     181,   187,   193,   199,   200,   208,   216,   225,   233,   241,
+     249,   255,   261,   267,   273,   279,   285,   306,   327,   333,
+     341,   347,   360,   361,   362,   363,   364,   365,   366,   373,
+     374,   375,   376,   386,   387,   388,   400,   401,   402,   405,
+     406
 #endif
@@ -1202,22 +1197,22 @@
   switch (yyn)
         case 3:
-#line 73 "mapparser.y"
-    { yyresult.intval = (yyvsp[0].intval); }
+#line 68 "mapparser.y"
+    { yypresult.intval = (yyvsp[0].intval); }
     break;
   case 4:
-#line 74 "mapparser.y"
+#line 69 "mapparser.y"
      if((yyvsp[0].dblval) != 0)
-       yyresult.intval = MS_TRUE;
+       yypresult.intval = MS_TRUE;
      else
-       yyresult.intval = MS_FALSE;
+       yypresult.intval = MS_FALSE;
     break;
   case 6:
-#line 85 "mapparser.y"
+#line 80 "mapparser.y"
 	                                 if((yyvsp[-2].intval) == MS_TRUE)
 		                           (yyval.intval) = MS_TRUE;
@@ -1229,7 +1224,7 @@
     break;
   case 7:
-#line 93 "mapparser.y"
+#line 88 "mapparser.y"
 	                                 if((yyvsp[-2].intval) == MS_TRUE) {
 			                   if((yyvsp[0].intval) == MS_TRUE)
@@ -1242,7 +1237,7 @@
     break;
   case 8:
-#line 102 "mapparser.y"
+#line 97 "mapparser.y"
@@ -1254,7 +1249,7 @@
     break;
   case 9:
-#line 110 "mapparser.y"
+#line 105 "mapparser.y"
@@ -1267,7 +1262,7 @@
     break;
   case 10:
-#line 119 "mapparser.y"
+#line 114 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != 0)
@@ -1279,7 +1274,7 @@
     break;
   case 11:
-#line 127 "mapparser.y"
+#line 122 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != 0) {
@@ -1292,7 +1287,7 @@
     break;
   case 12:
-#line 136 "mapparser.y"
+#line 131 "mapparser.y"
@@ -1304,7 +1299,7 @@
     break;
   case 13:
-#line 144 "mapparser.y"
+#line 139 "mapparser.y"
@@ -1317,17 +1312,17 @@
     break;
   case 14:
-#line 153 "mapparser.y"
+#line 148 "mapparser.y"
     { (yyval.intval) = !(yyvsp[0].intval); }
     break;
   case 15:
-#line 154 "mapparser.y"
+#line 149 "mapparser.y"
     { (yyval.intval) = !(yyvsp[0].dblval); }
     break;
   case 16:
-#line 155 "mapparser.y"
+#line 150 "mapparser.y"
                                          ms_regex_t re;
@@ -1344,7 +1339,7 @@
     break;
   case 17:
-#line 168 "mapparser.y"
+#line 163 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) == (yyvsp[0].dblval))
@@ -1354,7 +1349,7 @@
     break;
   case 18:
-#line 174 "mapparser.y"
+#line 169 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != (yyvsp[0].dblval))
@@ -1364,7 +1359,7 @@
     break;
   case 19:
-#line 180 "mapparser.y"
+#line 175 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) > (yyvsp[0].dblval))
@@ -1374,7 +1369,7 @@
     break;
   case 20:
-#line 186 "mapparser.y"
+#line 181 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) < (yyvsp[0].dblval))
@@ -1384,7 +1379,7 @@
     break;
   case 21:
-#line 192 "mapparser.y"
+#line 187 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) >= (yyvsp[0].dblval))
@@ -1394,7 +1389,7 @@
     break;
   case 22:
-#line 198 "mapparser.y"
+#line 193 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) <= (yyvsp[0].dblval))
@@ -1404,12 +1399,12 @@
     break;
   case 23:
-#line 204 "mapparser.y"
+#line 199 "mapparser.y"
     { (yyval.intval) = (yyvsp[-1].intval); }
     break;
   case 24:
-#line 205 "mapparser.y"
+#line 200 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1421,7 +1416,7 @@
     break;
   case 25:
-#line 213 "mapparser.y"
+#line 208 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) != 0)
@@ -1433,7 +1428,7 @@
     break;
   case 26:
-#line 221 "mapparser.y"
+#line 216 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) > 0)
@@ -1446,7 +1441,7 @@
     break;
   case 27:
-#line 230 "mapparser.y"
+#line 225 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) < 0)
@@ -1458,7 +1453,7 @@
     break;
   case 28:
-#line 238 "mapparser.y"
+#line 233 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) >= 0)
@@ -1470,7 +1465,7 @@
     break;
   case 29:
-#line 246 "mapparser.y"
+#line 241 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) <= 0)
@@ -1482,7 +1477,7 @@
     break;
   case 30:
-#line 254 "mapparser.y"
+#line 249 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) == 0)
@@ -1492,7 +1487,7 @@
     break;
   case 31:
-#line 260 "mapparser.y"
+#line 255 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) != 0)
@@ -1502,7 +1497,7 @@
     break;
   case 32:
-#line 266 "mapparser.y"
+#line 261 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) > 0)
@@ -1512,7 +1507,7 @@
     break;
   case 33:
-#line 272 "mapparser.y"
+#line 267 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) < 0)
@@ -1522,7 +1517,7 @@
     break;
   case 34:
-#line 278 "mapparser.y"
+#line 273 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) >= 0)
@@ -1532,7 +1527,7 @@
     break;
   case 35:
-#line 284 "mapparser.y"
+#line 279 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) <= 0)
@@ -1542,7 +1537,7 @@
     break;
   case 36:
-#line 290 "mapparser.y"
+#line 285 "mapparser.y"
 					 char *delim,*bufferp;
@@ -1567,7 +1562,7 @@
     break;
   case 37:
-#line 311 "mapparser.y"
+#line 306 "mapparser.y"
@@ -1592,7 +1587,7 @@
     break;
   case 38:
-#line 332 "mapparser.y"
+#line 327 "mapparser.y"
@@ -1602,7 +1597,7 @@
     break;
   case 39:
-#line 338 "mapparser.y"
+#line 333 "mapparser.y"
                                          if(strcasecmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1614,7 +1609,7 @@
     break;
   case 40:
-#line 346 "mapparser.y"
+#line 341 "mapparser.y"
@@ -1624,14 +1619,14 @@
     break;
   case 41:
-#line 352 "mapparser.y"
+#line 347 "mapparser.y"
       int rval;
       rval = msGEOSIntersects((yyvsp[-2].shpval), (yyvsp[0].shpval));
       if((yyvsp[-2].shpval)->scope == 1) msFreeShape((yyvsp[-2].shpval));
       if((yyvsp[0].shpval)->scope == 1) msFreeShape((yyvsp[0].shpval));
       if(rval == -1) {
-        msyyerror("Intersects operator failed.");
+        yyerror("Intersects operator failed.");
         return(-1);
       } else
         (yyval.intval) = rval;
@@ -1639,35 +1634,35 @@
     break;
   case 43:
-#line 366 "mapparser.y"
+#line 361 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-1].dblval); }
     break;
   case 44:
-#line 367 "mapparser.y"
+#line 362 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) + (yyvsp[0].dblval); }
     break;
   case 45:
-#line 368 "mapparser.y"
+#line 363 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) - (yyvsp[0].dblval); }
     break;
   case 46:
-#line 369 "mapparser.y"
+#line 364 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) * (yyvsp[0].dblval); }
     break;
   case 47:
-#line 370 "mapparser.y"
+#line 365 "mapparser.y"
     { (yyval.dblval) = (int)(yyvsp[-2].dblval) % (int)(yyvsp[0].dblval); }
     break;
   case 48:
-#line 371 "mapparser.y"
+#line 366 "mapparser.y"
       if((yyvsp[0].dblval) == 0.0) {
-        msyyerror("Division by zero.");
+        yyerror("Division by zero.");
         return(-1);
       } else
         (yyval.dblval) = (yyvsp[-2].dblval) / (yyvsp[0].dblval);
@@ -1675,25 +1670,25 @@
     break;
   case 49:
-#line 378 "mapparser.y"
+#line 373 "mapparser.y"
     { (yyval.dblval) = (yyvsp[0].dblval); }
     break;
   case 50:
-#line 379 "mapparser.y"
+#line 374 "mapparser.y"
     { (yyval.dblval) = pow((yyvsp[-2].dblval), (yyvsp[0].dblval)); }
     break;
   case 51:
-#line 380 "mapparser.y"
+#line 375 "mapparser.y"
     { (yyval.dblval) = strlen((yyvsp[-1].strval)); }
     break;
   case 52:
-#line 381 "mapparser.y"
+#line 376 "mapparser.y"
       if((yyvsp[-1].shpval)->type != MS_SHAPE_POLYGON) {
-        msyyerror("Area can only be computed for polygon shapes.");
+        yyerror("Area can only be computed for polygon shapes.");
         return(-1);
       (yyval.dblval) = msGetPolygonArea((yyvsp[-1].shpval));
@@ -1702,17 +1697,17 @@
     break;
   case 54:
-#line 392 "mapparser.y"
+#line 387 "mapparser.y"
     { (yyval.shpval) = (yyvsp[-1].shpval); }
     break;
   case 55:
-#line 393 "mapparser.y"
+#line 388 "mapparser.y"
       shapeObj *s;
       s = msShapeFromWKT((yyvsp[-1].strval));
       if(!s) {
-        msyyerror("Parsing WKT text failed.");
+        yyerror("Parsing WKT text failed.");
         return(-1);
       s->scope = 1;
@@ -1721,17 +1716,17 @@
     break;
   case 57:
-#line 406 "mapparser.y"
+#line 401 "mapparser.y"
     { (yyval.strval) = (yyvsp[-1].strval); free((yyvsp[-1].strval)); }
     break;
   case 58:
-#line 407 "mapparser.y"
+#line 402 "mapparser.y"
     { sprintf((yyval.strval), "%s%s", (yyvsp[-2].strval), (yyvsp[0].strval)); free((yyvsp[-2].strval)); free((yyvsp[0].strval)); }
     break;
   case 60:
-#line 411 "mapparser.y"
+#line 406 "mapparser.y"
     { (yyval.tmval) = (yyvsp[-1].tmval); }
     break;
@@ -1739,7 +1734,7 @@
 /* Line 1037 of yacc.c.  */
-#line 1743 "mapparser.c"
+#line 1738 "mapparser.c"
   yyvsp -= yylen;
   yyssp -= yylen;
@@ -1967,7 +1962,7 @@
-#line 414 "mapparser.y"
+#line 409 "mapparser.y"
@@ -1976,19 +1971,55 @@
 int yylex(void)
-  int token;
+  int token, i=yyexpr->curtoken;
   if(yyexpr->curtoken == yyexpr->numtokens) return(0); /* done */
-  token = msyyexpr->tokens[msyyexpr->curtoken];
-  msyyexpr->curtoken++;
+  token = yyexpr->tokens[i].token; /* may override if a binding token */
+  switch(yyexpr->tokens[i].token) {
+  case NUMBER:
+    yylval.dblval = yyexpr->tokens[i].tokenval.dblval;
+    break;
+  case STRING:
+  case ISTRING:
+    yylval.strval = strdup(yyexpr->tokens[i].tokenval.strval);
+    break;
+  case REGEX:
+  case IREGEX:
+    yylval.strval = yyexpr->tokens[i].tokenval.strval;
+    break;
+  case TIME:
+    yylval.tmval = yyexpr->tokens[i].tokenval.tmval;
+    break;
+  case MS_TOKEN_BINDING_DOUBLE:
+  case MS_TOKEN_BINDING_INTEGER:
+    token = NUMBER;
+    yylval.dblval = atof(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+    break;
+  case MS_TOKEN_BINDING_STRING:
+    token = STRING;
+    yylval.strval = strdup(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+    break;
+  case MS_TOKEN_BINDING_TIME:
+    token = TIME;
+    msTimeInit(&(yylval.tmval));
+    if(msParseTime(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index], &(yylval.tmval)) != MS_TRUE) {
+      yyerror("Parsing time value failed.", "yylex()");
+      return(-1);
+    break;
+  case MS_TOKEN_BINDING_SHAPE:
+    token = SHAPE;
+    yylval.shpval = yyshape;
+    break;
+  default:
+    break;
+  yyexpr->curtoken++;
   return(token);
-int yywrap() /* override */
-  return(1);
 int yyerror(char *s) {
   msSetError(MS_PARSEERR, s, "yyparse()");
   return(0);
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.h
--- sandbox/sdlime/common-expressions/mapserver/mapparser.h	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.h	2010-07-01 03:49:04 UTC (rev 10269)
@@ -84,7 +84,7 @@
   double dblval;
   int intval;
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.y
--- sandbox/sdlime/common-expressions/mapserver/mapparser.y	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.y	2010-07-01 03:49:04 UTC (rev 10269)
@@ -14,19 +14,14 @@
 shapeObj *yyshape;
 layerObj *yylayer;
-typedef union {
-  int intval;
-  char *strval;
-  shapeObj *shpval;
-} parseResultObj;
 /* Bison/Yacc declarations */
@@ -70,12 +65,12 @@
 input: /* empty string */
- | logical_exp { yyresult.intval = $1; }
+ | logical_exp { yypresult.intval = $1; }
  | math_exp {
      if($1 != 0)
      else
Modified: sandbox/sdlime/common-expressions/mapserver/mapraster.c
--- sandbox/sdlime/common-expressions/mapserver/mapraster.c	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/mapraster.c	2010-07-01 03:49:04 UTC (rev 10269)
@@ -37,13 +37,13 @@
 MS_CVSID("$Id$")
-extern int msyyparse(void);
-extern int msyylex(void);
-extern char *msyytext;
+extern int yyparse(void);
+// extern int msyylex(void);
+// extern char *msyytext;
-extern int msyyresult; /* result of parsing, true/false */
-extern int msyystate;
-extern char *msyystring;
+extern parseResultObj yypresult; /* result of parsing, true/false */
+// extern int msyystate;
+// extern char *msyystring;
 #ifdef USE_GDAL
 #include "gdal.h"
Modified: sandbox/sdlime/common-expressions/mapserver/mapserver.h
--- sandbox/sdlime/common-expressions/mapserver/mapserver.h	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/mapserver.h	2010-07-01 03:49:04 UTC (rev 10269)
@@ -536,6 +536,12 @@
 #ifndef SWIG
 typedef union {
+  int intval;
+  char *strval;
+  shapeObj *shpval;
+} parseResultObj;
+typedef union {
   double dblval;
   int intval;
   char *strval;
Modified: sandbox/sdlime/common-expressions/mapserver/maputil.c
--- sandbox/sdlime/common-expressions/mapserver/maputil.c	2010-06-30 16:37:12 UTC (rev 10268)
+++ sandbox/sdlime/common-expressions/mapserver/maputil.c	2010-07-01 03:49:04 UTC (rev 10269)
@@ -55,7 +55,7 @@
 extern int msyylex_destroy(void);
-extern parseResultObj yyresult; /* result of parsing, true/false */
 extern shapeObj *yyshape; /* globals to hold the active shape/layer/expression */
 extern layerObj *yylayer;
@@ -328,9 +328,12 @@
   msAcquireLock( TLOCK_PARSER );
-  msyystate = MS_TOKENIZE_EXPRESSION; msyystring = tmpstr1;
-  status = msyyparse();
-  result = msyyresult;
+  // after subs, tokenize, then parse...
+  // msyystate = MS_TOKENIZE_EXPRESSION; msyystring = tmpstr1;
+  // status = msyyparse();
+  // result = msyyresult;
   msReleaseLock( TLOCK_PARSER );
   free(tmpstr1);
@@ -390,7 +393,7 @@
       return MS_FALSE;
-    return yyresult.intval;
+    return yypresult.intval;
     break;
   case(MS_REGEX):
     if(itemindex == -1) {
