[mapserver-commits] r9912 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Mar 3 12:36:55 EST 2010
Author: assefa
Date: 2010-03-03 12:36:54 -0500 (Wed, 03 Mar 2010)
New Revision: 9912
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapogcsld.c
Backport fix for SLD filters column names detection #3052
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-03 17:32:37 UTC (rev 9911)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-03 17:36:54 UTC (rev 9912)
@@ -15,8 +15,10 @@
Current Version (SVN branch-5-6):
-- Backport fix for WFS OGC filters regex tests #3289
+- Backport fix for SLD filters column names detection (#3052)
+- Backport fix for WFS OGC filters regex tests (#3289)
- Fix crash with GRID layers with no classes (#3352)
- Avoid memory error when building SQL bbox (#3324)
Modified: branches/branch-5-6/mapserver/mapogcsld.c
--- branches/branch-5-6/mapserver/mapogcsld.c 2010-03-03 17:32:37 UTC (rev 9911)
+++ branches/branch-5-6/mapserver/mapogcsld.c 2010-03-03 17:36:54 UTC (rev 9912)
@@ -641,8 +641,8 @@
layerObj *psCurrentLayer = NULL;
const char *pszWmsName=NULL;
int j=0;
+ const char *key=NULL;
if (psRoot && psLayer)
psUserStyle = CPLGetXMLNode(psRoot, "UserStyle");
@@ -734,11 +734,23 @@
if (j < psLayer->map->numlayers)
+ /*make sure that the tmp layer has all the metadata that
+ the orinal layer has, allowing to do parsing for
+ such things as gml_attribute_type #3052*/
+ while (1)
+ key = msNextKeyFromHashTable(&psCurrentLayer->metadata, key);
+ if (!key)
+ break;
+ else
+ msInsertHashTable(&psLayer->metadata, key,
+ msLookupHashTable(&psCurrentLayer->metadata, key));
FLTPreParseFilterForAlias(psNode, psLayer->map, j, "G");
/* If the filter has a spatial filter or is a simple, we keep */
/* the node. This node will be parsed when applying the SLD and */
More information about the mapserver-commits
