[mapserver-commits] r9922 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Mar 6 14:39:03 EST 2010
Author: tamas
Date: 2010-03-06 14:39:01 -0500 (Sat, 06 Mar 2010)
New Revision: 9922
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapmssql2008.c
Fixed the query handling with the MSSQL2008 driver (#3058)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-06 17:08:20 UTC (rev 9921)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-03-06 19:39:01 UTC (rev 9922)
@@ -15,6 +15,8 @@
Current Version (SVN branch-5-6):
+- Fixed the query handling with the MSSQL2008 driver (#3058)
- Fixed swig zoomRectangle() method: the maxy in the rect object have to be < miny value (#3286)
- Backport fix for SLD filters column names detection (#3052)
Modified: branches/branch-5-6/mapserver/mapmssql2008.c
--- branches/branch-5-6/mapserver/mapmssql2008.c 2010-03-06 17:08:20 UTC (rev 9921)
+++ branches/branch-5-6/mapserver/mapmssql2008.c 2010-03-06 19:39:01 UTC (rev 9922)
@@ -97,6 +97,30 @@
layer->layerinfo = (void*) MSSQL2008layerinfo;
+void handleSQLError(layerObj *layer)
+ SQLCHAR SqlState[6], Msg[SQL_MAX_MESSAGE_LENGTH];
+ SQLINTEGER NativeError;
+ SQLSMALLINT i, MsgLen;
+ SQLRETURN rc;
+ msMSSQL2008LayerInfo *layerinfo = getMSSQL2008LayerInfo(layer);
+ if (layerinfo == NULL)
+ return;
+ // Get the status records.
+ i = 1;
+ while ((rc = SQLGetDiagRec(SQL_HANDLE_STMT, layerinfo->conn->hstmt, i, SqlState, &NativeError,
+ Msg, sizeof(Msg), &MsgLen)) != SQL_NO_DATA)
+ if(layer->debug)
+ msDebug("SQLError: %s\n", Msg);
+ i++;
/* remove white space */
/* dont send in empty strings or strings with just " " in them! */
static char* removeWhite(char *str)
@@ -417,8 +441,6 @@
return MS_FAILURE;
- //setMSSQL2008LayerInfo(layer, layerinfo);
return MS_SUCCESS;
@@ -492,7 +514,7 @@
Plus 10 formatted doubles (15 digits of precision, a decimal point, a space/comma delimiter each = 17 chars each)
Plus SRID + comma - if SRID is a long...we'll be safe with 10 chars
- char box3d[40 + 10 * 17 + 11];
+ char box3d[40 + 10 * 22 + 11];
char query_string_temp[10000]; /* Should be big enough */
int t;
@@ -568,14 +590,23 @@
columns_wanted = _strdup(buffer);
- sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", /* %s.STSrid)", */
- rect.minx, rect.miny,
- rect.maxx, rect.miny,
- rect.maxx, rect.maxy,
- rect.minx, rect.maxy,
- layerinfo->user_srid
+ if (rect.minx == rect.maxx || rect.miny == rect.maxy)
+ /* create point shape for rectangles with zero area */
+ sprintf(box3d, "Geometry::STGeomFromText('POINT(%.15g %.15g)',%s)", /* %s.STSrid)", */
+ rect.minx, rect.miny, layerinfo->user_srid);
+ else
+ sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", /* %s.STSrid)", */
+ rect.maxx, rect.miny,
+ rect.maxx, rect.maxy,
+ rect.minx, rect.maxy,
+ layerinfo->user_srid
/* substitute token '!BOX!' in geom_table with the box3d - do an unlimited # of subs */
/* to not undo the work here, we need to make sure that data_source is malloc'd here */
@@ -1249,6 +1280,7 @@
/* Any error assume out of recordset bounds */
if (rc != SQL_SUCCESS && rc != SQL_SUCCESS_WITH_INFO)
+ handleSQLError(layer);
return MS_DONE;
@@ -1263,6 +1295,8 @@
/* figure out how big the buffer needs to be */
rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
+ if (rc == SQL_ERROR)
if (needLen > 0)
@@ -1276,6 +1310,8 @@
/* Now grab the data */
rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, valueBuffer, needLen, &retLen);
+ if (rc == SQL_ERROR || rc == SQL_SUCCESS_WITH_INFO)
/* Terminate the buffer */
valueBuffer[retLen] = 0; /* null terminate it */
@@ -1292,6 +1328,8 @@
/* Set up to request the size of the buffer needed */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
/* allow space for coercion to geometry collection if needed*/
wkbTemp = (char*)malloc(needLen+9);
@@ -1307,6 +1345,8 @@
/* Grab the WKB */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, wkbBuffer, needLen, &retLen);
memcpy(&geomType, wkbBuffer + 1, 4);
@@ -1368,6 +1408,9 @@
/* Next get unique id for row - since the OID shouldn't be larger than a long we'll assume billions as a limit */
rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 2, SQL_C_BINARY, oidBuffer, sizeof(oidBuffer) - 1, &retLen);
oidBuffer[retLen] = 0;
record_oid = strtol(oidBuffer, NULL, 10);
@@ -1442,7 +1485,7 @@
if(layer->numitems == 0)
- snprintf(buffer, sizeof(buffer), "%s.STAsBinary()", layerinfo->geom_column);
+ snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
else
@@ -1451,7 +1494,7 @@
snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "convert(varchar(max), %s),", layer->items[t]);
- snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary()", layerinfo->geom_column);
+ snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
@@ -1477,6 +1520,9 @@
return MS_FAILURE;
+ layerinfo->sql = query_str;
+ layerinfo->row_num = 0;
return msMSSQL2008LayerGetShapeRandom(layer, shape, &(layerinfo->row_num));
@@ -1864,6 +1910,7 @@
vtable->LayerWhichShapes = msMSSQL2008LayerWhichShapes;
vtable->LayerNextShape = msMSSQL2008LayerNextShape;
vtable->LayerGetShape = msMSSQL2008LayerGetShapeVT;
+ vtable->LayerResultsGetShape = msMSSQL2008LayerGetShapeVT; /* no special version, use ...GetShape() */
vtable->LayerClose = msMSSQL2008LayerClose;
@@ -1897,7 +1944,8 @@
layer->vtable->LayerWhichShapes = msMSSQL2008LayerWhichShapes;
layer->vtable->LayerNextShape = msMSSQL2008LayerNextShape;
layer->vtable->LayerGetShape = msMSSQL2008LayerGetShapeVT;
+ layer->vtable->LayerResultsGetShape = msMSSQL2008LayerGetShapeVT; /* no special version, use ...GetShape() */
layer->vtable->LayerClose = msMSSQL2008LayerClose;
layer->vtable->LayerGetItems = msMSSQL2008LayerGetItems;
More information about the mapserver-commits
