[mapserver-commits] r9937 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Thu Mar 11 10:17:39 EST 2010
Author: aboudreault
Date: 2010-03-11 10:17:39 -0500 (Thu, 11 Mar 2010)
New Revision: 9937
trunk/mapserver/configure
trunk/mapserver/configure.in
trunk/mapserver/mapscript/php/php_proj.c
Modified configure to support php 5.2.0 or more recent
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-03-11 14:02:17 UTC (rev 9936)
+++ trunk/mapserver/configure 2010-03-11 15:17:39 UTC (rev 9937)
@@ -932,7 +932,7 @@
--with-fastcgi=path Enable FastCGI, point to installed tree.
--with-httpd Specify path to 'httpd' executable.
--with-warnings[=flags] Enable strict warnings (or user defined warnings)
- --with-php=DIR Specify directory where PHP4's include files are
+ --with-php=DIR Specify directory where PHP5's include files are
installed (or a pointer to the full source tree)
Required in order to compile the PHP/MapScript
module.
@@ -12996,16 +12996,11 @@
PHP_LD="$PHP_LD_SHARED $PHP_LD_XTRAFLAGS"
fi
- echo "$as_me:$LINENO: checking for location of config.h or php_config.h" >&5
-echo $ECHO_N "checking for location of config.h or php_config.h... $ECHO_C" >&6
- test -f "$PHP_SRC_DIR/config.h" && PHP_CONFIG_H="$PHP_SRC_DIR/config.h"
+ echo "$as_me:$LINENO: checking for location of php_config.h" >&5
+echo $ECHO_N "checking for location of php_config.h... $ECHO_C" >&6
+ test -f "$PHP_SRC_DIR/main/php_config.h" && test -f "$PHP_SRC_DIR/main/php_version.h" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
- test -f "$PHP_SRC_DIR/php_config.h" && PHP_CONFIG_H="$PHP_SRC_DIR/php_config.h"
- test -f "$PHP_SRC_DIR/main/php_config.h" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
test -f "$PHP_SRC_DIR/include/php/main/php_config.h" && PHP_SRC_DIR="$PHP_SRC_DIR/include/php/" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
test -f "$PHP_SRC_DIR/include/php5/main/php_config.h" && PHP_SRC_DIR="$PHP_SRC_DIR/include/php5/" && PHP_CONFIG_H="$PHP_SRC_DIR/main/php_config.h"
if test -n "$PHP_CONFIG_H" ; then
@@ -13013,27 +13008,31 @@
echo "${ECHO_T}$PHP_CONFIG_H" >&6
else
{ { echo "$as_me:$LINENO: error:
-!!! Could not find config.h or php_config.h in $PHP_SRC_DIR. !!!
+!!! Could not find php_config.h and php_version.h in $PHP_SRC_DIR. !!!
!!! Has PHP been configured yet? !!!" >&5
echo "$as_me: error:
!!! Has PHP been configured yet? !!!" >&2;}
{ (exit 1); exit 1; }; }
fi
- echo "$as_me:$LINENO: checking whether we have PHP3 or PHP4" >&5
-echo $ECHO_N "checking whether we have PHP3 or PHP4... $ECHO_C" >&6
- if test -n "`grep 'ZEND_API' $PHP_CONFIG_H`" ; then
- PHP_VERSION_FLAG="-DPHP4"
- else
- PHP_VERSION_FLAG="-DPHP3"
+ echo "$as_me:$LINENO: checking if we have PHP 5.2.0+" >&5
+echo $ECHO_N "checking if we have PHP 5.2.0+... $ECHO_C" >&6
+ PHP_VERSION=`grep 'PHP_VERSION_ID' $PHP_SRC_DIR/main/php_version.h | cut -d' ' -f3`
+ if test -z "$PHP_VERSION" || test $PHP_VERSION -lt 50200; then
-!!! PHP MapScript now requires PHP 4.1.2 or more recent. !!!
-!!! Support for PHP3 has been dropped after MapServer version 3.5. !!!" >&5
+!!! PHP MapScript now requires PHP 5.2.0 or more recent. !!!
+!!! Support for PHP3 has been dropped after MapServer version 3.5. !!!
+!!! Support for PHP4 has been dropped after MapServer version 5.6. !!!" >&5
-!!! Support for PHP3 has been dropped after MapServer version 3.5. !!!" >&2;}
+!!! Support for PHP4 has been dropped after MapServer version 5.6. !!!" >&2;}
+ else
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
fi
echo "$as_me:$LINENO: result: $PHP_VERSION_FLAG" >&5
echo "${ECHO_T}$PHP_VERSION_FLAG" >&6
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-03-11 14:02:17 UTC (rev 9936)
+++ trunk/mapserver/configure.in 2010-03-11 15:17:39 UTC (rev 9937)
@@ -2438,7 +2438,7 @@
AC_CHECKING(for PHP/MapScript module options)
AC_ARG_WITH(php,
-[ --with-php=DIR Specify directory where PHP4's include files are
+[ --with-php=DIR Specify directory where PHP5's include files are
module.],,)
@@ -2485,22 +2485,15 @@
fi
dnl
- dnl Look for PHP3's config.h or PHP4's php_config.h.
+ dnl Look for PHP5's php_config.h.
dnl We'll need the config file to find info about the PHP configuration
dnl
- AC_MSG_CHECKING([for location of config.h or php_config.h])
- dnl In PHP3, it was called config.h
+ AC_MSG_CHECKING([for location of php_config.h])
+ dnl Look for the main/php_config.h
- dnl In PHP 4.0.1 to 4.0.3, it was php-4.0.x/php_config.h
- dnl Starting with PHP 4.0.4, it's php-4.0.x/main/php_config.h
dnl If php was installed, then the headers are under $prefix/include/php/*
dnl In PHP 5, few distributions use "/usr/include/php5" directory
@@ -2508,22 +2501,23 @@
AC_MSG_RESULT([$PHP_CONFIG_H])
else
AC_MSG_ERROR([
!!! Has PHP been configured yet? !!!])
fi
- dnl
dnl Check which PHP version we're using.
dnl Default is PHP3, and if ZEND_API is set then we assume that we have PHP4.
dnl
- AC_MSG_CHECKING([whether we have PHP3 or PHP4])
- else
+ AC_MSG_CHECKING([if we have PHP 5.2.0+])
AC_MSG_ERROR([
-!!! Support for PHP3 has been dropped after MapServer version 3.5. !!!])
+!!! Support for PHP4 has been dropped after MapServer version 5.6. !!!])
+ else
+ AC_MSG_RESULT([yes])
fi
AC_MSG_RESULT([$PHP_VERSION_FLAG])
Modified: trunk/mapserver/mapscript/php/php_proj.c
--- trunk/mapserver/mapscript/php/php_proj.c 2010-03-11 14:02:17 UTC (rev 9936)
+++ trunk/mapserver/mapscript/php/php_proj.c 2010-03-11 15:17:39 UTC (rev 9937)
@@ -138,14 +138,8 @@
#include <projects.h>
#include "php_mapscript_util.h"
-#if defined (PHP4) || defined (PHP5)
#include "php.h"
#include "php_globals.h"
-#else
-#include "phpdl.h"
-#include "php3_list.h"
-#include "functions/head.h" /* php3_header() */
-#endif
#include "maperror.h"
@@ -157,9 +151,7 @@
#include <errno.h>
#endif
#define ZEND_DEBUG 0
-#endif
#ifndef DLEXPORT
#define DLEXPORT ZEND_DLEXPORT
@@ -190,9 +182,7 @@
DLEXPORT void php_info_proj(void);
#endif
static zend_class_entry *proj_class_entry_ptr;
-#endif
#define PHPMS_GLOBAL(a) a
static int le_projobj;
@@ -256,18 +246,14 @@
DLEXPORT int php_init_proj(INIT_FUNC_ARGS)
zend_class_entry tmp_class_entry;
-#endif
PHPMS_GLOBAL(le_projobj) =
register_list_destructors(php_proj_pj_free,
NULL);
INIT_CLASS_ENTRY(tmp_class_entry, "proj", php_proj_class_functions);
proj_class_entry_ptr = zend_register_internal_class(&tmp_class_entry TSRMLS_CC);
-#endif
return SUCCESS;
@@ -332,12 +318,8 @@
pval *pArrayOfParams = NULL;
pval **pParam = NULL;
HashTable *list=NULL;
-#else
- pval *pParam = NULL;
-#endif
int nParamCount = 0;
int i = 0;
@@ -372,15 +354,9 @@
if (_php3_hash_index_find(pArrayOfParams->value.ht, i,
(void **)&pParam) != FAILURE)
convert_to_string((*pParam));
if ((*pParam)->value.str.val != NULL)
papszBuf[i] = strdup((*pParam)->value.str.val);
-#else
- convert_to_string(pParam);
- if (pParam->value.str.val != NULL)
- papszBuf[i] = strdup(pParam->value.str.val);
-#endif
papszBuf[i] = NULL;
@@ -413,9 +389,7 @@
DLEXPORT void php_proj_pj_fwd(INTERNAL_FUNCTION_PARAMETERS)
-#endif
pval *p1, *p2;
pval *pj = NULL;
PJ *popj = NULL;
@@ -483,9 +457,7 @@
DLEXPORT void php_proj_pj_inv(INTERNAL_FUNCTION_PARAMETERS)
-#endif
pval *p1, *p2;
pval *pj = NULL;
PJ *popj = NULL;
@@ -543,9 +515,7 @@
DLEXPORT void php_proj_pj_transform(INTERNAL_FUNCTION_PARAMETERS)
-#endif
pval *p1, *p2;
pval *pjin, *pjout = NULL;
PJ *in = NULL;
@@ -631,9 +601,7 @@
DLEXPORT void php_proj_pj_datum_transform(INTERNAL_FUNCTION_PARAMETERS)
-#endif
pval *p1, *p2;
PJ *in = NULL;
@@ -712,12 +680,9 @@
/* TODO : freeing does not work properly on PHP4. */
-#ifndef PHP4
+#ifdef PHP4_BAD_FREEING
-#endif
pval *pj = NULL;
PJ *popj = NULL;
More information about the mapserver-commits
