[mapserver-commits] r9942 - trunk/mapserver
Mon Mar 15 15:38:38 EDT 2010
Author: assefa
Date: 2010-03-15 15:38:38 -0400 (Mon, 15 Mar 2010)
New Revision: 9942
   trunk/mapserver/mapows.c
   trunk/mapserver/mapows.h
   trunk/mapserver/mapserv.c
   trunk/mapserver/mapserv.h
   trunk/mapserver/maptemplate.h
   trunk/mapserver/mapwfs.c
   trunk/mapserver/mapwms.c
Add support for mode=wfs (#2531)
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapows.c	2010-03-15 19:38:38 UTC (rev 9942)
@@ -29,6 +29,7 @@
 #include "mapserver.h"
 #include "maptime.h"
+#include "maptemplate.h"
 #include <ctype.h> /* isalnum() */
 #include <stdarg.h>
@@ -46,14 +47,19 @@
 **   request then MS_DONE is returned and MapServer is expected to process
 **   this as a regular MapServer (traditional CGI) request.
-int msOWSDispatch(mapObj *map, cgiRequestObj *request, int force_ows_mode)
+int msOWSDispatch(mapObj *map, cgiRequestObj *request, int ows_mode)
     int i, status = MS_DONE;
     const char *service=NULL;
+    int force_ows_mode = 0;
     if (!request)
       return status;
+    if (ows_mode == OWS || ows_mode == WFS)
+      force_ows_mode = 1;
     for( i=0; i<request->NumParams; i++ )
         if(strcasecmp(request->ParamNames[i], "SERVICE") == 0)
@@ -64,7 +70,7 @@
     /* Note: SERVICE param did not exist in WMS 1.0.0, it was added only in WMS 1.1.0,
      * so we need to let msWMSDispatch check for known REQUESTs even if SERVICE is not set.
-    if ((status = msWMSDispatch(map, request)) != MS_DONE )
+    if ((status = msWMSDispatch(map, request, MS_FALSE)) != MS_DONE )
         return status;
 #else
     if( service != NULL && strcasecmp(service,"WMS") == 0 )
@@ -77,7 +83,7 @@
     /* Note: WFS supports POST requests, so the SERVICE param may only be in the post data
      * and not be present in the GET URL
-    if ((status = msWFSDispatch(map, request)) != MS_DONE )
+    if ((status = msWFSDispatch(map, request, (ows_mode == WFS))) != MS_DONE )
         return status;
 #else
     if( service != NULL && strcasecmp(service,"WFS") == 0 )
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapows.h	2010-03-15 19:38:38 UTC (rev 9942)
@@ -167,7 +167,7 @@
  *   mapows.c
-MS_DLL_EXPORT int msOWSDispatch(mapObj *map, cgiRequestObj *request, int force_ows_mode);
+MS_DLL_EXPORT int msOWSDispatch(mapObj *map, cgiRequestObj *request, int ows_mode);
 MS_DLL_EXPORT const char * msOWSLookupMetadata(hashTableObj *metadata,
                                     const char *namespaces, const char *name);
@@ -410,7 +410,7 @@
  *   mapwms.c
-int msWMSDispatch(mapObj *map, cgiRequestObj *req);
+int msWMSDispatch(mapObj *map, cgiRequestObj *req, int force_wms_mode);
 MS_DLL_EXPORT int msWMSLoadGetMapParams(mapObj *map, int nVersion,
                           char **names, char **values, int numentries);
@@ -444,7 +444,7 @@
 #define OWS_DEFAULT_SCHEMA 0 /* basically a GML 2.1 schema */
 #define OWS_SFE_SCHEMA 1 /* GML for simple feature exchange (formerly GML3L0) */
-int msWFSDispatch(mapObj *map, cgiRequestObj *requestobj);
+MS_DLL_EXPORT int msWFSDispatch(mapObj *map, cgiRequestObj *requestobj, int force_wfs_mode);
 void msWFSParseRequest(cgiRequestObj *, wfsParamsObj *);
 wfsParamsObj *msWFSCreateParamsObj(void);
 void msWFSFreeParamsObj(wfsParamsObj *wfsparams);
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapserv.c	2010-03-15 19:38:38 UTC (rev 9942)
@@ -1259,9 +1259,9 @@
     ** Start by calling the WMS/WFS/WCS Dispatchers.  If they fail then we'll
     ** process this as a regular MapServer request.
-    if((mapserv->Mode == -1 || mapserv->Mode == OWS) &&
-       (status = msOWSDispatch(mapserv->map, mapserv->request,
-                               (mapserv->Mode == OWS))) != MS_DONE  )  {
+    if((mapserv->Mode == -1 || mapserv->Mode == OWS || mapserv->Mode == WFS) &&
+       (status = msOWSDispatch(mapserv->map, mapserv->request,
+                               mapserv->Mode)) != MS_DONE  )  {
       ** OWSDispatch returned either MS_SUCCESS or MS_FAILURE
Modified: trunk/mapserver/mapserv.h
--- trunk/mapserver/mapserv.h	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapserv.h	2010-03-15 19:38:38 UTC (rev 9942)
@@ -57,13 +57,13 @@
 ** Enumerated types, keep the query modes in sequence and at the end of the enumeration (mode enumeration is in maptemplate.h).
-int numModes = 29;
-static char *modeStrings[29] = {"BROWSE","ZOOMIN","ZOOMOUT","MAP","LEGEND","LEGENDICON","REFERENCE","SCALEBAR","COORDINATE",
+int numModes = 30;
+static char *modeStrings[30] = {"BROWSE","ZOOMIN","ZOOMOUT","MAP","LEGEND","LEGENDICON","REFERENCE","SCALEBAR","COORDINATE",
                                 "QUERY","QUERYMAP","NQUERY","NQUERYMAP",
 			        "ITEMQUERY","ITEMQUERYMAP","ITEMNQUERY","ITEMNQUERYMAP",
 				"FEATUREQUERY","FEATUREQUERYMAP","FEATURENQUERY","FEATURENQUERYMAP",
 				"ITEMFEATUREQUERY","ITEMFEATUREQUERYMAP","ITEMFEATURENQUERY","ITEMFEATURENQUERYMAP",
-				"INDEXQUERY","INDEXQUERYMAP","TILE","OWS"};
+				"INDEXQUERY","INDEXQUERYMAP","TILE","OWS", "WFS"};
 ** Global variables
Modified: trunk/mapserver/maptemplate.h
--- trunk/mapserver/maptemplate.h	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/maptemplate.h	2010-03-15 19:38:38 UTC (rev 9942)
@@ -46,7 +46,7 @@
             ITEMQUERY, ITEMQUERYMAP, ITEMNQUERY, ITEMNQUERYMAP,
             FEATUREQUERY, FEATUREQUERYMAP, FEATURENQUERY, FEATURENQUERYMAP,
             ITEMFEATUREQUERY, ITEMFEATUREQUERYMAP, ITEMFEATURENQUERY, ITEMFEATURENQUERYMAP,
-            INDEXQUERY, INDEXQUERYMAP, TILE, OWS};
+            INDEXQUERY, INDEXQUERYMAP, TILE, OWS, WFS};
 /* struct mapservObj
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapwfs.c	2010-03-15 19:38:38 UTC (rev 9942)
@@ -52,7 +52,7 @@
     if( version == NULL )
-      version = "1.0.0";
+      version = "1.1.0";
     if( msOWSParseVersionString(version) >= OWS_1_1_0 )
       return msWFSException11( map, locator, code, version );
@@ -2059,7 +2059,7 @@
 **   is returned and MapServer is expected to process this as a regular
 **   MapServer request.
+int msWFSDispatch(mapObj *map, cgiRequestObj *requestobj, int force_wfs_mode)
 #ifdef USE_WFS_SVR
   int status;
@@ -2075,6 +2075,86 @@
   /* into the paramsObj.  */
   msWFSParseRequest(requestobj, paramsObj);
+  if (force_wfs_mode)
+      /*request is always required*/
+      if (paramsObj->pszRequest==NULL || strlen(paramsObj->pszRequest)<=0)
+          msSetError(MS_WFSERR,
+                 "Incomplete WFS request: REQUEST parameter missing",
+                     "msWFSDispatch()");
+          returnvalue = msWFSException(map, "request", "MissingParameterValue", paramsObj->pszVersion);
+          msWFSFreeParamsObj(paramsObj);
+          free(paramsObj);
+          paramsObj = NULL;
+          return returnvalue;
+      /*version:
+        wfs 1.0 and 1.1.0 POST request: optional
+        wfs 1.0 and 1.1.0 GET request: optional for getcapabilities and required for describefeatute and getfeature
+      if (paramsObj->pszVersion == NULL && requestobj && requestobj->postrequest == MS_FALSE &&
+          strcasecmp(paramsObj->pszRequest, "GetCapabilities") != 0)
+                 "Invalid WFS request: VERSION parameter missing",
+          returnvalue = msWFSException(map, "version", "MissingParameterValue", paramsObj->pszVersion);
+          free(paramsObj);
+          paramsObj = NULL;
+      if (paramsObj->pszVersion == NULL || strlen(paramsObj->pszVersion) <=0)
+        paramsObj->pszVersion = strdup("1.1.0");
+      /*service
+        wfs 1.0 and 1.1.0 GET: required and should be set to WFS
+        wfs 1.0 POST: required
+        wfs 1.1.1 POST: optional
+      if ((paramsObj->pszService == NULL || strlen(paramsObj->pszService) == 0) &&
+          ((requestobj && requestobj->postrequest == MS_FALSE) || strcasecmp(paramsObj->pszVersion,"1.0") ==0))
+                 "Invalid WFS request: Missing SERVICE parameter",
+          returnvalue = msWFSException(map, "service", "MissingParameterValue", paramsObj->pszVersion);
+          free(paramsObj);
+          paramsObj = NULL;
+      if (paramsObj->pszService == NULL || strlen(paramsObj->pszService) == 0)
+        paramsObj->pszService = strdup("WFS");
+      if (paramsObj->pszService!=NULL && strcasecmp(paramsObj->pszService, "WFS") != 0)
+                 "Invalid WFS request: SERVICE parameter must be set to WFS",
+          returnvalue = msWFSException(map, "service", "InvalidParameterValue", paramsObj->pszVersion);
+          free(paramsObj);
+          paramsObj = NULL;
+      if (paramsObj->pszService == NULL && strcasecmp(paramsObj->pszVersion, "1.0") == 0)
+                 "Invalid WFS request: SERVICE parameter missing",
+          free(paramsObj);
+          paramsObj = NULL;
   /* If SERVICE is specified then it MUST be "WFS" */
   if (paramsObj->pszService != NULL &&
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2010-03-15 14:36:43 UTC (rev 9941)
+++ trunk/mapserver/mapwms.c	2010-03-15 19:38:38 UTC (rev 9942)
@@ -3770,7 +3770,7 @@
 #ifdef USE_WMS_SVR
   int i, status, nVersion=OWS_VERSION_NOTSET;
@@ -3822,8 +3822,13 @@
        strcasecmp(request, "GetCapabilities") == 0) &&
       (nVersion >= OWS_1_0_7 || nVersion == OWS_VERSION_NOTSET))
-      msSetError(MS_WMSERR, "Required SERVICE parameter missing.", "msWMSDispatch");
-      return msWMSException(map, nVersion, "ServiceNotDefined");
+      if (force_wms_mode)
+          msSetError(MS_WMSERR, "Required SERVICE parameter missing.", "msWMSDispatch");
+          return msWMSException(map, nVersion, "ServiceNotDefined");
+      else
+        return MS_DONE;
