[mapserver-commits] r9955 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Mar 19 14:25:25 EDT 2010
Author: pramsey
Date: 2010-03-19 14:25:24 -0400 (Fri, 19 Mar 2010)
New Revision: 9955
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/mapsde.c
branches/branch-5-4/mapserver/mapstring.c
Check error returns from mapstring functions (#2988)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2010-03-18 18:31:38 UTC (rev 9954)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2010-03-19 18:25:24 UTC (rev 9955)
@@ -14,6 +14,8 @@
Current Version:
+- Check error returns from mapstring functions (#2988)
- Avoid memory error when building SQL bbox (#3324)
- Determine PgSQL version in a more backwards compatible way (#3291)
Modified: branches/branch-5-4/mapserver/mapsde.c
--- branches/branch-5-4/mapserver/mapsde.c 2010-03-18 18:31:38 UTC (rev 9954)
+++ branches/branch-5-4/mapserver/mapsde.c 2010-03-19 18:25:24 UTC (rev 9955)
@@ -753,6 +753,13 @@
else
shape->values[i] = msConvertWideStringToUTF8((const wchar_t*) wide, "UTF-16LE");
msFree(wide);
+ if (!shape->values[i]) { /* There was an error */
+ msSetError( MS_SDEERR,
+ "msConvertWideStringToUTF8()==NULL.",
+ "sdeGetRecord()");
+ shape->values[i] = (char *)malloc(itemdefs[i].size*sizeof(char)+1);
+ shape->values[i][0] = '\0'; /* empty string */
break;
#endif
Modified: branches/branch-5-4/mapserver/mapstring.c
--- branches/branch-5-4/mapserver/mapstring.c 2010-03-18 18:31:38 UTC (rev 9954)
+++ branches/branch-5-4/mapserver/mapstring.c 2010-03-19 18:25:24 UTC (rev 9955)
@@ -1504,8 +1504,8 @@
char* msConvertWideStringToUTF8 (const wchar_t* string, const char* encoding) {
#ifdef USE_ICONV
- int bconvFailed = MS_TRUE;
char* output = NULL;
+ char* errormessage = NULL;
iconv_t cd = NULL;
size_t nStr;
size_t nInSize;
@@ -1536,27 +1536,41 @@
nOutSize = nBufferSize;
if ((iconv_t)-1 != cd)
- nInSize = sizeof (wchar_t)*nStr;
- pszUTF8 = output;
- pwszWide = string;
- nConv = iconv(cd, (char **)&pwszWide, &nInSize, &pszUTF8, &nOutSize);
- if ((size_t)-1 != nConv && nOutSize != nBufferSize)
- bconvFailed = MS_FALSE;
- iconv_close(cd);
+ nInSize = sizeof (wchar_t)*nStr;
+ pszUTF8 = output;
+ pwszWide = string;
+ nConv = iconv(cd, (char **)&pwszWide, &nInSize, &pszUTF8, &nOutSize);
+ if ((size_t)-1 != nConv && nOutSize != nBufferSize) {
+ switch (errno) {
+ case E2BIG:
+ errormessage = "There is not sufficient room in buffer";
+ break;
+ case EILSEQ:
+ errormessage = "An invalid multibyte sequence has been encountered in the input";
+ break;
+ case EINVAL:
+ errormessage = "An incomplete multibyte sequence has been encountered in the input";
+ break;
+ default:
+ errormessage = "Unknown";
+ break;
+ msSetError(MS_MISCERR, "Unable to convert string in encoding '%s' to UTF8 %s",
+ "msConvertWideStringToUTF8()",
+ encoding,errormessage);
+ iconv_close(cd);
+ msFree(output);
+ return NULL;
+ iconv_close(cd);
} else {
msSetError(MS_MISCERR, "Encoding not supported by libiconv (%s).",
encoding);
+ msFree(output);
return NULL;
- if (bconvFailed) {
- msFree(output);
- output = NULL;
- msSetError(MS_MISCERR, "Unable to convert string in encoding '%s' to UTF8",
- "msConvertWideStringToUTF8()",
- encoding);
} else {
/* we were given a NULL wide string, nothing we can do here */
return NULL;
More information about the mapserver-commits
