[mapserver-commits] r10009 - trunk/mapserver
Thu Mar 25 10:18:44 EDT 2010
Author: assefa
Date: 2010-03-25 10:18:41 -0400 (Thu, 25 Mar 2010)
New Revision: 10009
   trunk/mapserver/mapowscommon.c
   trunk/mapserver/mapowscommon.h
msOWSCommonNegotiateVersion:no need to have it dependent on libxml2 (#3282
Modified: trunk/mapserver/mapowscommon.c
--- trunk/mapserver/mapowscommon.c	2010-03-25 14:05:29 UTC (rev 10008)
+++ trunk/mapserver/mapowscommon.c	2010-03-25 14:18:41 UTC (rev 10009)
@@ -44,37 +44,8 @@
 MS_CVSID("$Id$")
- * msOWSCommonNegotiateVersion()
- * returns a supported version as per subclause 7.3.2
- * @param requested_version the version passed by the client
- * @param supported_versions an array of supported versions
- * @param num_supported_versions size of supported_versions
- * @return supported version integer, or -1 on error
-int msOWSCommonNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions) {
-  int i;
-  /* if version is not set return error */
-  if (! requested_version)
-    return -1;
-  /* return the first entry that's equal to the requested version */
-  for (i = 0; i < num_supported_versions; i++) {
-    if (supported_versions[i] == requested_version)
-      return supported_versions[i];
-  /* no match; calling code should throw an exception */
-  return -1;
  * msOWSCommonServiceIdentification()
@@ -654,3 +625,34 @@
       return xmlNewChild(psParent, psNs, BAD_CAST name, BAD_CAST content);
 #endif /* defined(USE_LIBXML2) */
+ * msOWSCommonNegotiateVersion()
+ * returns a supported version as per subclause 7.3.2
+ * @param requested_version the version passed by the client
+ * @param supported_versions an array of supported versions
+ * @param num_supported_versions size of supported_versions
+ * @return supported version integer, or -1 on error
+int msOWSCommonNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions) {
+  int i;
+  /* if version is not set return error */
+  if (! requested_version)
+    return -1;
+  /* return the first entry that's equal to the requested version */
+  for (i = 0; i < num_supported_versions; i++) {
+    if (supported_versions[i] == requested_version)
+      return supported_versions[i];
+  /* no match; calling code should throw an exception */
+  return -1;
Modified: trunk/mapserver/mapowscommon.h
--- trunk/mapserver/mapowscommon.h	2010-03-25 14:05:29 UTC (rev 10008)
+++ trunk/mapserver/mapowscommon.h	2010-03-25 14:18:41 UTC (rev 10009)
@@ -70,7 +70,6 @@
 /* function prototypes */
-int msOWSCommonNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions);
 xmlNodePtr msOWSCommonServiceIdentification(xmlNsPtr psNsOws, mapObj *map, const char *servicetype, const char *version, const char *namespaces);
@@ -98,4 +97,6 @@
                                           const char *content, const char *encoding);
+int msOWSCommonNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions);
 #endif /* MAPOWSCOMMON_H */
