[mapserver-commits] r10011 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Mar 25 10:38:45 EDT 2010
Author: warmerdam
Date: 2010-03-25 10:38:44 -0400 (Thu, 25 Mar 2010)
New Revision: 10011
trunk/mapserver/mapdrawgdal.c
fix support for EXTENT keyword on raster layers (#3402)
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c 2010-03-25 14:37:43 UTC (rev 10010)
+++ trunk/mapserver/mapdrawgdal.c 2010-03-25 14:38:44 UTC (rev 10011)
@@ -1964,10 +1964,7 @@
const char *extent_priority = NULL;
const char *value;
-#if defined(USE_WMS_SVR) || defined (USE_WFS_SVR)
rectObj rect;
-#endif
/* some GDAL drivers (ie. GIF) don't set geotransform on failure. */
@@ -1988,7 +1985,7 @@
if( extent_priority != NULL
&& EQUALN(extent_priority,"WORLD",5) )
- if( GDALGetDescription(hDS) != NULL
+ if( GDALGetDescription(hDS) != NULL
&& GDALReadWorldFile(GDALGetDescription(hDS), "wld",
padfGeoTransform) )
@@ -2027,6 +2024,30 @@
+/* Do we have the extent keyword on the layer? We only use */
+/* this if we have a single raster associated with the layer as */
+/* opposed to a tile index. */
+/* Arguably this ought to take priority over all the other */
+/* stuff. */
+ if (MS_VALID_EXTENT(layer->extent) && layer->data != NULL)
+ rect = layer->extent;
+ padfGeoTransform[0] = rect.minx;
+ padfGeoTransform[1] = (rect.maxx - rect.minx) /
+ (double) GDALGetRasterXSize( hDS );
+ padfGeoTransform[2] = 0;
+ padfGeoTransform[3] = rect.maxy;
+ padfGeoTransform[4] = 0;
+ padfGeoTransform[5] = (rect.miny - rect.maxy) /
+ (double) GDALGetRasterYSize( hDS );
+ return MS_SUCCESS;
/* Try OWS extent metadata. We only try this if we know there */
/* is metadata so that we don't end up going into the layer */
/* getextent function which will in turn reopen the file with */
More information about the mapserver-commits
