[mapserver-commits] r10016 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Mar 25 14:48:12 EDT 2010
Author: aboudreault
Date: 2010-03-25 14:48:12 -0400 (Thu, 25 Mar 2010)
New Revision: 10016
trunk/mapserver/HISTORY.TXT
trunk/mapserver/configure
trunk/mapserver/configure.in
trunk/mapserver/mapagg.cpp
Added libgd < 2.0.30 compatibility (#3293)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-03-25 15:49:05 UTC (rev 10015)
+++ trunk/mapserver/HISTORY.TXT 2010-03-25 18:48:12 UTC (rev 10016)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Added libgd < 2.0.30 compatibility (#3293)
- Incorporate support for GDAL nodata on RGB images (#2404)
- Incorporated support for GDAL masks (GDAL RFC 15) (#2640)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-03-25 15:49:05 UTC (rev 10015)
+++ trunk/mapserver/configure 2010-03-25 18:48:12 UTC (rev 10016)
@@ -7228,6 +7228,148 @@
fi
+ GD_HAS_GET_TRUE_COLOR_PIXEL=
+ CFLAGS_BACKUP="$CFLAGS"
+ CXXFLAGS_BACKUP="$CXXFLAGS"
+ CFLAGS="$CFLAGS $GD_INC"
+ CXXFLAGS="$CXXFLAGS $GD_INC"
+ echo "$as_me:$LINENO: checking whether gdImageGetTrueColorPixel is declared" >&5
+echo $ECHO_N "checking whether gdImageGetTrueColorPixel is declared... $ECHO_C" >&6
+if test "${ac_cv_have_decl_gdImageGetTrueColorPixel+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+#include <gd.h>
+int
+main ()
+#ifndef gdImageGetTrueColorPixel
+ char *p = (char *) gdImageGetTrueColorPixel;
+#endif
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest.$ac_objext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ ac_cv_have_decl_gdImageGetTrueColorPixel=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_have_decl_gdImageGetTrueColorPixel=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_have_decl_gdImageGetTrueColorPixel" >&5
+echo "${ECHO_T}$ac_cv_have_decl_gdImageGetTrueColorPixel" >&6
+if test $ac_cv_have_decl_gdImageGetTrueColorPixel = yes; then
+ GD_HAS_GET_TRUE_COLOR_PIXEL=yes
+fi
+ CFLAGS="$CFLAGS_BACKUP"
+ CXXFLAGS="$CXXFLAGS_BACKUP"
+ if test .$GD_HAS_GET_TRUE_COLOR_PIXEL = .yes ; then
+ as_ac_Lib=`echo "ac_cv_lib_$GD_CHECKLIB''_gdImageGetTrueColorPixel" | $as_tr_sh`
+echo "$as_me:$LINENO: checking for gdImageGetTrueColorPixel in -l$GD_CHECKLIB" >&5
+echo $ECHO_N "checking for gdImageGetTrueColorPixel in -l$GD_CHECKLIB... $ECHO_C" >&6
+if eval "test \"\${$as_ac_Lib+set}\" = set"; then
+else
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-l$GD_CHECKLIB $GD_STATIC $GD_LIB $GD_XTRA_LIBS $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char gdImageGetTrueColorPixel ();
+int
+main ()
+gdImageGetTrueColorPixel ();
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ ac_status=$?
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ eval "$as_ac_Lib=yes"
+else
+eval "$as_ac_Lib=no"
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Lib'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Lib'}'`" >&6
+if test `eval echo '${'$as_ac_Lib'}'` = yes; then
+ GD_DEF="$GD_DEF -DGD_HAS_GET_TRUE_COLOR_PIXEL"
+fi
+ fi
echo "$as_me:$LINENO: result: using GD ($GD_DEF) from $GD_DIR." >&5
echo "${ECHO_T} using GD ($GD_DEF) from $GD_DIR." >&6
@@ -7932,6 +8074,139 @@
GD_DEF="$GD_DEF -DUSE_GD_RESOLUTION"
fi
+else
+/* confdefs.h. */
+_ACEOF
+#include <gd.h>
+int
+main ()
+#endif
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+else
+fi
+fi
+fi
+ echo "$as_me:$LINENO: checking for gdImageGetTrueColorPixel in -lgd" >&5
+echo $ECHO_N "checking for gdImageGetTrueColorPixel in -lgd... $ECHO_C" >&6
+if test "${ac_cv_lib_gd_gdImageGetTrueColorPixel+set}" = set; then
+else
+LIBS="-lgd $GD_STATIC $GD_LIB $GD_XTRA_LIBS $LIBS"
+/* confdefs.h. */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_lib_gd_gdImageGetTrueColorPixel=yes
+else
+ac_cv_lib_gd_gdImageGetTrueColorPixel=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_gd_gdImageGetTrueColorPixel" >&5
+echo "${ECHO_T}$ac_cv_lib_gd_gdImageGetTrueColorPixel" >&6
+if test $ac_cv_lib_gd_gdImageGetTrueColorPixel = yes; then
+fi
+ fi
if test -n "$GD_DEF" ; then
GD_LIB="-lgd $GD_LIB"
echo "$as_me:$LINENO: result: using GD ($GD_DEF) from system libs." >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-03-25 15:49:05 UTC (rev 10015)
+++ trunk/mapserver/configure.in 2010-03-25 18:48:12 UTC (rev 10016)
@@ -669,6 +669,25 @@
dnl getter functions.
AC_CHECK_LIB($GD_CHECKLIB, gdFontGetTiny, GD_DEF="$GD_DEF -DGD_HAS_GETBITMAPFONTS",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+ dnl check for gdImageGetTrueColorPixel.
+ dnl In some GD versions this function is defined, but not declared in gd.h,
+ dnl so check headers first
+ dnl AC_CHECK_DECL needs to know the gd include path
+ AC_CHECK_DECL(gdImageGetTrueColorPixel,[GD_HAS_GET_TRUE_COLOR_PIXEL=yes],,[#include <gd.h>])
+ dnl if it's declared, check if we can link with it
+ AC_CHECK_LIB($GD_CHECKLIB, gdImageGetTrueColorPixel, GD_DEF="$GD_DEF -DGD_HAS_GET_TRUE_COLOR_PIXEL",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+ fi
AC_MSG_RESULT([ using GD ($GD_DEF) from $GD_DIR.])
else
@@ -710,6 +729,16 @@
fi
+ AC_CHECK_LIB(gd, gdImageGetTrueColorPixel, GD_DEF="$GD_DEF -DGD_HAS_GET_TRUE_COLOR_PIXEL",, $GD_STATIC $GD_LIB $GD_XTRA_LIBS)
+ fi
AC_MSG_RESULT([ using GD ($GD_DEF) from system libs.])
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2010-03-25 15:49:05 UTC (rev 10015)
+++ trunk/mapserver/mapagg.cpp 2010-03-25 18:48:12 UTC (rev 10016)
@@ -165,7 +165,17 @@
for(int row=0;row<height;row++) {
unsigned int* rowptr=(unsigned int*)im_data_rbuf.row_ptr(row);
for(int col=0;col<width;col++){
+#ifdef GD_HAS_GET_TRUE_COLOR_PIXEL
int gdpix = gdImageGetTrueColorPixel(img,col,row);
+#else
+ int gdpix = gdImageGetPixel(img,col,row);
+ if(!img->trueColor)
+ gdpix = gdTrueColorAlpha(
+ img->red[gdpix],
+ img->green[gdpix],
+ img->blue[gdpix],
+ (img->transparent == gdpix) ? gdAlphaTransparent : img->alpha[gdpix]);
+#endif
//extract the alpha value from the pixel
int gdpixalpha = ((gdpix) & 0x7F000000) >> 24;
More information about the mapserver-commits
