[mapserver-commits] r10131 - in branches/branch-5-6/mapserver: .
mapscript/csharp mapscript/csharp/config
svn at osgeo.org
svn at osgeo.org
Sun May 2 08:34:21 EDT 2010
Author: tamas
Date: 2010-05-02 08:34:21 -0400 (Sun, 02 May 2010)
New Revision: 10131
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapscript/csharp/Makefile.vc
branches/branch-5-6/mapserver/mapscript/csharp/config/AssemblyInfo.cs
Fix security exception issue in C# with MSVC2010 (#3438)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-05-02 12:33:29 UTC (rev 10130)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-05-02 12:34:21 UTC (rev 10131)
@@ -15,6 +15,8 @@
Version 5.6.4 (????-??-??):
+- Fix security exception issue in C# with MSVC2010 (#3438)
- Write out join CONNECTIONTYPE when saving a mapfile. (#3435)
- Fixed attribute queries to use an extent stored (and cached) as part of the queryObj
Modified: branches/branch-5-6/mapserver/mapscript/csharp/Makefile.vc
--- branches/branch-5-6/mapserver/mapscript/csharp/Makefile.vc 2010-05-02 12:33:29 UTC (rev 10130)
+++ branches/branch-5-6/mapserver/mapscript/csharp/Makefile.vc 2010-05-02 12:34:21 UTC (rev 10131)
@@ -47,6 +47,10 @@
!ENDIF
!ENDIF
+!IF $(MSVC_VER) >= 1600
+CSC = $(CSC) /define:CLR4 /debug:full
+!ENDIF
#SWIG = swig
!IFDEF DLLBUILD
Modified: branches/branch-5-6/mapserver/mapscript/csharp/config/AssemblyInfo.cs
--- branches/branch-5-6/mapserver/mapscript/csharp/config/AssemblyInfo.cs 2010-05-02 12:33:29 UTC (rev 10130)
+++ branches/branch-5-6/mapserver/mapscript/csharp/config/AssemblyInfo.cs 2010-05-02 12:34:21 UTC (rev 10131)
@@ -92,3 +92,7 @@
// Web page that should be running under restricted permissions.
[assembly: AllowPartiallyTrustedCallers]
+// Use the .NET Framework 2.0 transparency rules (level 1 transparency) as default
+#if (CLR4)
+[assembly: SecurityRules(SecurityRuleSet.Level1)]
+#endif
\ No newline at end of file
More information about the mapserver-commits
