[mapserver-commits] r10149 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri May 7 16:50:38 EDT 2010
Author: assefa
Date: 2010-05-07 16:50:37 -0400 (Fri, 07 May 2010)
New Revision: 10149
trunk/mapserver/maperror.c
trunk/mapserver/mapkmlrenderer.cpp
trunk/mapserver/mapkmlrenderer.h
trunk/mapserver/maplayer.c
More cleanup of the knl renderer (vector layers and description) #3431
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c 2010-05-07 20:38:50 UTC (rev 10148)
+++ trunk/mapserver/maperror.c 2010-05-07 20:50:37 UTC (rev 10149)
@@ -511,6 +511,9 @@
strcat(version, " OUTPUT=SWF");
#endif
strcat(version, " OUTPUT=SVG");
+#ifdef USE_KML
+ strcat(version, " OUTPUT=KML");
+#endif
#ifdef USE_PROJ
strcat(version, " SUPPORTS=PROJ");
#endif
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2010-05-07 20:38:50 UTC (rev 10148)
+++ trunk/mapserver/mapkmlrenderer.cpp 2010-05-07 20:50:37 UTC (rev 10149)
@@ -39,10 +39,16 @@
: XmlDoc(NULL), LayerNode(NULL), GroundOverlayNode(NULL), Width(width), Height(height),
FirstLayer(MS_TRUE), RasterizerOutputFormat(NULL), InternalImg(NULL),
VectorMode(MS_TRUE), RasterMode(MS_FALSE), MapCellsize(1.0),
- PlacemarkNode(NULL), GeomNode(NULL), MaxFeatureCount(100),
+ PlacemarkNode(NULL), GeomNode(NULL),
Items(NULL), NumItems(0), map(NULL), currentLayer(NULL)
+ /*private variables*/
+ pszLayerDescMetadata = NULL;
+ papszLayerIncludeItems = NULL;
+ nIncludeItems=0;
xmlNodePtr styleNode;
xmlNodePtr listStyleNode;
/* Create document.*/
@@ -96,7 +102,7 @@
rendererVTableObj *r = RasterizerOutputFormat->vtable;
imageObj *img = r->createImage(Width, Height, RasterizerOutputFormat, &BgColor);
+ img->format = RasterizerOutputFormat;
return img;
@@ -105,54 +111,9 @@
return NULL;
-int KmlRenderer::saveImage(imageObj *img, FILE *fp, outputFormatObj*)
+int KmlRenderer::saveImage(imageObj *, FILE *fp, outputFormatObj*)
- if (InternalImg)
- char fileName[MS_MAXPATHLEN];
- char fileUrl[MS_MAXPATHLEN];
- rendererVTableObj *r = RasterizerOutputFormat->vtable;
- if (img->imagepath)
- char *tmpFileName = msTmpFile(MapPath, img->imagepath, MS_IMAGE_EXTENSION(RasterizerOutputFormat));
- sprintf(fileName, "%s", tmpFileName);
- msFree(tmpFileName);
- else
- sprintf(fileName, "kml_ground_overlay_%ld%d.%s", (long)time(NULL), (int)getpid(), MS_IMAGE_EXTENSION(RasterizerOutputFormat)); /* __TODO__ add WEB IMAGEURL path;*/
- FILE *stream = fopen(fileName, "wb");
- if(r->supports_pixel_buffer)
- rasterBufferObj data;
- r->getRasterBuffer(InternalImg,&data);
- msSaveRasterBuffer(&data, stream, RasterizerOutputFormat );
- else
- r->saveImage(InternalImg, stream, RasterizerOutputFormat);
- fclose(stream);
- if (img->imageurl)
- sprintf(fileUrl, "%s%s.%s", img->imageurl, msGetBasename(fileName), MS_IMAGE_EXTENSION(RasterizerOutputFormat));
- else
- sprintf(fileUrl, "%s", fileName);
- createGroundOverlayNode(fileUrl);
- r->freeImage(InternalImg);
- else
- xmlUnlinkNode(GroundOverlayNode);
- xmlFreeNode(GroundOverlayNode);
- GroundOverlayNode = NULL;
/* Write out the document. */
@@ -205,6 +166,7 @@
be the center of the element.*/
for(i=0; i<layer->numclasses; i++)
layer->_class[i]->label.position = MS_XY;
char* KmlRenderer::getLayerName(layerObj *layer)
@@ -227,10 +189,28 @@
-void KmlRenderer::startNewLayer(imageObj *img, layerObj *layer)
+void KmlRenderer::startNewLayer(imageObj *, layerObj *layer)
char *layerName=NULL;
+ const char *value=NULL;
+ VectorMode = MS_FALSE;
+ RasterMode = MS_FALSE;
+ if (layer->type == MS_LAYER_RASTER)
+ RasterMode = MS_TRUE;
+ else
+ VectorMode = MS_TRUE;
+ /*check if a vector layer will be dumped as a raster*/
+ const char *outputAsRaster=msLookupHashTable(&(layer->metadata),"KML_OUTPUTASRASTER");
+ if (outputAsRaster && strlen(outputAsRaster) > 0 &&
+ (strcasecmp(outputAsRaster, "true") == 0 || strcasecmp(outputAsRaster, "yes") == 0))
LayerNode = xmlNewNode(NULL, BAD_CAST "Folder");
layerName = getLayerName(layer);
@@ -244,7 +224,13 @@
if (layerDsiplayFolder == NULL)
layerDsiplayFolder = msLookupHashTable(&(layer->map->web.metadata), "kml_folder_display");
if (!layerDsiplayFolder || strlen(layerDsiplayFolder)<=0)
- xmlNewChild(LayerNode, NULL, BAD_CAST "styleUrl", BAD_CAST "#LayerFolder_check");
+ if (RasterMode)
+ xmlNewChild(LayerNode, NULL, BAD_CAST "styleUrl", BAD_CAST "#LayerFolder_checkHideChildren");
+ else
+ xmlNewChild(LayerNode, NULL, BAD_CAST "styleUrl", BAD_CAST "#LayerFolder_check");
else
if (strcasecmp(layerDsiplayFolder, "checkHideChildren") == 0)
@@ -257,46 +243,13 @@
- VectorMode = MS_TRUE;
- RasterMode = MS_TRUE;
- currentLayer = layer;
- if (!msLayerIsOpen(layer))
- if (msLayerOpen(layer) != MS_SUCCESS)
- msSetError(MS_MISCERR, "msLayerOpen failed", "KmlRenderer::startNewLayer" );
- /*pre process the layer to set things that make sense for kml output*/
- processLayer(layer);
- DumpAttributes = MS_FALSE;
- char *attribVal = msLookupHashTable(&layer->metadata, "kml_dumpattributes");
- if (attribVal && strlen(attribVal) > 0)
- DumpAttributes = MS_TRUE;
- msLayerWhichItems(layer, MS_FALSE, attribVal);
- else
- msLayerWhichItems(layer, MS_TRUE, NULL);
- NumItems = layer->numitems;
- if (NumItems)
- Items = (char **)calloc(NumItems, sizeof(char *));
- for (int i=0; i<NumItems; i++)
- Items[i] = strdup(layer->items[i]);
+ /*Init few things on the first layer*/
if (FirstLayer)
FirstLayer = MS_FALSE;
map = layer->map;
@@ -318,8 +271,8 @@
default rasterizer agg2png
optional tag formatoption "kml_rasteroutputformat"*/
char rasterizerFomatName[128];
- /*sprintf(rasterizerFomatName, "cairopng");*/
- sprintf(rasterizerFomatName, "agg2png");
+ sprintf(rasterizerFomatName, "cairopng");
+ /*sprintf(rasterizerFomatName, "agg2png");*/
/*no real need to let the user pick a renderer. It seems more complex than useful.
I am leaving the code here but will remove it form the docs. (AY)*/
@@ -339,61 +292,110 @@
if(!strcasecmp(iFormat->name,rasterizerFomatName))
RasterizerOutputFormat = iFormat;
+ /*always set RGBA*/
+ RasterizerOutputFormat->imagemode = MS_IMAGEMODE_RGBA;
break;
- const char *formatOptionStr = msGetOutputFormatOption(img->format, "kml_maxfeaturecount", "");
- if (strlen(formatOptionStr))
- MaxFeatureCount = atoi(formatOptionStr);
+ currentLayer = layer;
- /* reset feature counter*/
- FeatureCount = 0;
+ if (VectorMode)
- TempImg = RasterMode ? createInternalImage() : NULL;
+ if (!msLayerIsOpen(layer))
+ if (msLayerOpen(layer) != MS_SUCCESS)
+ msSetError(MS_MISCERR, "msLayerOpen failed", "KmlRenderer::startNewLayer" );
+ /*pre process the layer to set things that make sense for kml output*/
+ processLayer(layer);
+ if (msLookupHashTable(&layer->metadata, "kml_description"))
+ pszLayerDescMetadata = msLookupHashTable(&layer->metadata, "kml_description");
+ value=msLookupHashTable(&layer->metadata, "kml_include_items");
+ if (value)
+ papszLayerIncludeItems = msStringSplit(value, ',', &nIncludeItems);
+ DumpAttributes = MS_FALSE;
+ char *attribVal = msLookupHashTable(&layer->metadata, "kml_dumpattributes");
+ if (attribVal && strlen(attribVal) > 0)
+ DumpAttributes = MS_TRUE;
+ msLayerWhichItems(layer, MS_FALSE, attribVal);
+ else
+ msLayerWhichItems(layer, MS_TRUE, NULL);
+ NumItems = layer->numitems;
+ if (NumItems)
+ Items = (char **)calloc(NumItems, sizeof(char *));
+ for (int i=0; i<NumItems; i++)
+ Items[i] = strdup(layer->items[i]);
+ ImgLayer= NULL;
+ ImgLayer = RasterMode ? createInternalImage() : NULL;
setupRenderingParams(&layer->metadata);
-void KmlRenderer::closeNewLayer(imageObj*, layerObj *layer)
+void KmlRenderer::closeNewLayer(imageObj *img, layerObj *layer)
- flushPlacemark();
+ if (VectorMode)
+ flushPlacemark();
- if (!VectorMode)
- /* layer was rasterized, merge temp layer image with main output image*/
- if (!InternalImg)
- InternalImg = TempImg;
- else
+ /*if we rendering through a raster buffer, save the layer into a file and create
+ a GroundOverlay node*/
+ if (RasterMode && ImgLayer)
+ char *tmpFileName = NULL;
+ char *tmpUrl = NULL;
+ tmpFileName = msTmpFile(MapPath, img->imagepath, MS_IMAGE_EXTENSION(RasterizerOutputFormat));
+ if (tmpFileName)
+ msSaveImage(layer->map, ImgLayer, tmpFileName);
+ tmpUrl = strdup( img->imageurl);
+ tmpUrl = msStringConcatenate(tmpUrl, (char *)(msGetBasename(tmpFileName)));
+ tmpUrl = msStringConcatenate(tmpUrl, ".");
+ tmpUrl = msStringConcatenate(tmpUrl, MS_IMAGE_EXTENSION(RasterizerOutputFormat));
+ createGroundOverlayNode(LayerNode, tmpUrl, layer);
+ msFree(tmpFileName);
+ msFree(tmpUrl);
+ msFreeImage(ImgLayer);
+ xmlAddChild(DocNode, LayerNode);
- r->getRasterBuffer(TempImg,&data);
+ if(Items)
+ msFreeCharArray(Items, NumItems);
+ Items = NULL;
+ NumItems = 0;
- r->mergeRasterBuffer(InternalImg, &data, layer->opacity * 0.01, 0, 0);
+ if (pszLayerDescMetadata)
- r->freeImage(TempImg);
- xmlFreeNode(LayerNode);
- else
- xmlAddChild(DocNode, LayerNode);
- if(Items)
- msFreeCharArray(Items, NumItems);
- Items = NULL;
- NumItems = 0;
+ if (papszLayerIncludeItems && nIncludeItems>0)
+ msFreeCharArray(papszLayerIncludeItems, nIncludeItems);
@@ -426,16 +428,6 @@
Tessellate = atoi(tessellateVal);
- char *maxFeatureVal = msLookupHashTable(layerMetadata, "kml_maxfeaturecount");
- if (maxFeatureVal)
- MaxFeatureCount = atoi(maxFeatureVal);
- if (MaxFeatureCount >= 999999)
- RasterMode = MS_FALSE;
- if (MaxFeatureCount == 0)
- VectorMode = MS_FALSE;
int KmlRenderer::checkProjection(projectionObj *projection)
@@ -463,28 +455,22 @@
xmlNodePtr KmlRenderer::createPlacemarkNode(xmlNodePtr parentNode, char *styleUrl)
- FeatureCount++;
- if (FeatureCount > MaxFeatureCount)
- return NULL;
- xmlNodePtr placemarkNode = xmlNewChild(parentNode, NULL, BAD_CAST "Placemark", NULL);
- /*always add a name. It will be replaced by a text value if available*/
- char tmpid[100];
- char *stmp=NULL, *layerName=NULL;
- sprintf(tmpid, ".%d", CurrentShape->index);
- layerName = getLayerName(currentLayer);
- stmp = msStringConcatenate(stmp, layerName);
- stmp = msStringConcatenate(stmp, tmpid);
- xmlNewChild(placemarkNode, NULL, BAD_CAST "name", BAD_CAST stmp);
- msFree(layerName);
- msFree(stmp);
- if (styleUrl)
- xmlNewChild(placemarkNode, NULL, BAD_CAST "styleUrl", BAD_CAST styleUrl);
+ xmlNodePtr placemarkNode = xmlNewChild(parentNode, NULL, BAD_CAST "Placemark", NULL);
+ /*always add a name. It will be replaced by a text value if available*/
+ char tmpid[100];
+ char *stmp=NULL, *layerName=NULL;
+ sprintf(tmpid, ".%d", CurrentShape->index);
+ layerName = getLayerName(currentLayer);
+ stmp = msStringConcatenate(stmp, layerName);
+ stmp = msStringConcatenate(stmp, tmpid);
+ xmlNewChild(placemarkNode, NULL, BAD_CAST "name", BAD_CAST stmp);
+ msFree(layerName);
+ msFree(stmp);
+ if (styleUrl)
+ xmlNewChild(placemarkNode, NULL, BAD_CAST "styleUrl", BAD_CAST styleUrl);
- return placemarkNode;
+ return placemarkNode;
void KmlRenderer::renderLineVector(imageObj*, shapeObj *p, strokeStyleObj *style)
@@ -543,7 +529,7 @@
r->transformShape(&rasShape, MapExtent, MapCellsize);
- r->renderLine(TempImg, &rasShape, style);
+ r->renderLine(ImgLayer, &rasShape, style);
msFreeShape(&rasShape);
@@ -602,7 +588,7 @@
- r->renderPolygon(TempImg, &rasShape, color);
+ r->renderPolygon(ImgLayer, &rasShape, color);
@@ -677,7 +663,7 @@
/* internal renderer used for rasterizing*/
- r->renderGlyphs(TempImg, x, y, style, text);
+ r->renderGlyphs(ImgLayer, x, y, style, text);
@@ -696,7 +682,7 @@
if (RasterMode)
- r->getTruetypeTextBBox(TempImg, font, size, string, rect, advances);
+ r->getTruetypeTextBBox(ImgLayer, font, size, string, rect, advances);
return true;
@@ -778,7 +764,7 @@
if (RasterMode)
- r->renderPixmapSymbol(TempImg, x, y, symbol, style);
+ r->renderPixmapSymbol(ImgLayer, x, y, symbol, style);
@@ -791,7 +777,7 @@
if (RasterMode)
- r->renderVectorSymbol(TempImg, x, y, symbol, style);
+ r->renderVectorSymbol(ImgLayer, x, y, symbol, style);
@@ -804,7 +790,7 @@
if (RasterMode)
- r->renderEllipseSymbol(TempImg, x, y, symbol, style);
+ r->renderEllipseSymbol(ImgLayer, x, y, symbol, style);
@@ -817,11 +803,11 @@
if (RasterMode)
- r->renderTruetypeSymbol(TempImg, x, y, symbol, style);
+ r->renderTruetypeSymbol(ImgLayer, x, y, symbol, style);
-xmlNodePtr KmlRenderer::createGroundOverlayNode(char *imageHref)
+xmlNodePtr KmlRenderer::createGroundOverlayNode(xmlNodePtr parentNode, char *imageHref, layerObj *layer)
@@ -847,9 +833,13 @@
</kml>
- xmlNodePtr groundOverlayNode = xmlNewChild(DocNode, NULL, BAD_CAST "GroundOverlay", NULL);
+ xmlNodePtr groundOverlayNode = xmlNewChild(parentNode, NULL, BAD_CAST "GroundOverlay", NULL);
+ char *layerName = getLayerName(layer);
+ xmlNewChild(groundOverlayNode, NULL, BAD_CAST "name", BAD_CAST layerName);
xmlNewChild(groundOverlayNode, NULL, BAD_CAST "color", BAD_CAST "ffffffff");
- xmlNewChild(groundOverlayNode, NULL, BAD_CAST "drawOrder", BAD_CAST "0");
+ char stmp[20];
+ sprintf(stmp, "%d",layer->index);
+ xmlNewChild(groundOverlayNode, NULL, BAD_CAST "drawOrder", BAD_CAST stmp);
if (imageHref)
@@ -887,7 +877,7 @@
PlacemarkNode = NULL;
GeomNode = NULL;
- if (VectorMode && DumpAttributes && NumItems)
+ if (VectorMode)/* && DumpAttributes && NumItems)*/
DescriptionNode = createDescriptionNode(shape);
else
DescriptionNode = NULL;
@@ -1156,36 +1146,76 @@
xmlNodePtr KmlRenderer::createDescriptionNode(shapeObj *shape)
<description>
<![CDATA[
special characters here
<description>
- char lineBuf[512];
- xmlNodePtr descriptionNode = xmlNewNode(NULL, BAD_CAST "description");
- /*xmlNodeAddContent(descriptionNode, BAD_CAST "\n\t<![CDATA[\n");*/
- xmlNodeAddContent(descriptionNode, BAD_CAST "<table>");
+ /*description nodes for vector layers:
+ - if kml_description is set, use it
+ - if not, dump the attributes */
- for (int i=0; i<shape->numvalues; i++)
- if (shape->values[i] && strlen(shape->values[i]))
- sprintf(lineBuf, "<tr><td><b>%s</b></td><td>%s</td></tr>\n", Items[i], shape->values[i]);
- else
- sprintf(lineBuf, "<tr><td><b>%s</b></td><td></td></tr>\n", Items[i]);
- xmlNodeAddContent(descriptionNode, BAD_CAST lineBuf);
+ char *pszTmp=NULL;
+ char *pszTmpDesc = NULL;
+ pszTmpDesc = strdup(pszLayerDescMetadata);
+ for (int i=0; i<currentLayer->numitems; i++)
+ pszTmp = (char *)malloc(sizeof(char)*strlen(currentLayer->items[i]) + 3);
+ sprintf(pszTmp, "%%%s%%",currentLayer->items[i]);
+ if (strcasestr(pszTmpDesc, pszTmp))
+ pszTmpDesc = msCaseReplaceSubstring(pszTmpDesc, pszTmp, shape->values[i]);
+ msFree(pszTmp);
+ xmlNodePtr descriptionNode = xmlNewNode(NULL, BAD_CAST "description");
+ xmlNodeAddContent(descriptionNode, BAD_CAST pszTmpDesc);
+ msFree(pszTmpDesc);
+ return descriptionNode;
+ else if (papszLayerIncludeItems && nIncludeItems > 0)
+ char lineBuf[512];
- xmlNodeAddContent(descriptionNode, BAD_CAST "</table>");
+ /*xmlNodeAddContent(descriptionNode, BAD_CAST "\n\t<![CDATA[\n");*/
+ xmlNodeAddContent(descriptionNode, BAD_CAST "<table>");
+ int j=0;
+ /*TODO optimize to calculate this only once per layer*/
+ for (j=0; j<nIncludeItems;j++)
+ if (strcasecmp(currentLayer->items[i], papszLayerIncludeItems[j]) == 0)
+ break;
+ if (j<nIncludeItems)
+ if (shape->values[i] && strlen(shape->values[i]))
+ sprintf(lineBuf, "<tr><td><b>%s</b></td><td>%s</td></tr>\n", currentLayer->items[i], shape->values[i]);
+ else
+ sprintf(lineBuf, "<tr><td><b>%s</b></td><td></td></tr>\n", currentLayer->items[i]);
+ xmlNodeAddContent(descriptionNode, BAD_CAST lineBuf);
+ xmlNodeAddContent(descriptionNode, BAD_CAST "</table>");
/*xmlNodeAddContent(descriptionNode, BAD_CAST "\t]]>\n");*/
- return descriptionNode;
+ return NULL;
#endif
Modified: trunk/mapserver/mapkmlrenderer.h
--- trunk/mapserver/mapkmlrenderer.h 2010-05-07 20:38:50 UTC (rev 10148)
+++ trunk/mapserver/mapkmlrenderer.h 2010-05-07 20:50:37 UTC (rev 10149)
@@ -39,6 +39,11 @@
class KmlRenderer
+ private:
+ const char *pszLayerDescMetadata; /*if the kml_description is set*/
+ char **papszLayerIncludeItems;
+ int nIncludeItems;
protected:
// map properties
@@ -83,34 +88,14 @@
outputFormatObj *RasterizerOutputFormat;
imageObj *InternalImg;
- imageObj *TempImg;
+ imageObj *ImgLayer;
int FirstLayer;
mapObj *map;
layerObj *currentLayer;
- // max number of features rendered in "vector KML" mode
- // default value 100
- // value can be specified in format option
- // OUTPUTFORMAT
- // FORMATOPTION "kml_maxfeaturecount=512"
- // END
- // value can be specified also in layer metadata
- // LAYER
- // METADATA
- // kml_maxfeaturecount "512"
- // END
- // END
- int MaxFeatureCount;
- // if FeatureCount is greater than MaxFeatureCount, layer is rasterized and
- // rendered as ground overlay
- // number of features in layer
- int FeatureCount;
// if true - features are rasterized
int VectorMode;
@@ -127,7 +112,7 @@
imageObj* createInternalImage();
xmlNodePtr createPlacemarkNode(xmlNodePtr parentNode, char *styleUrl);
- xmlNodePtr createGroundOverlayNode(char *imageHref);
+ xmlNodePtr createGroundOverlayNode(xmlNodePtr parentNode, char *imageHref, layerObj *layer);
xmlNodePtr createDescriptionNode(shapeObj *shape);
char* lookupSymbolUrl(imageObj *img, symbolObj *symbol, symbolStyleObj *style);
Modified: trunk/mapserver/maplayer.c
--- trunk/mapserver/maplayer.c 2010-05-07 20:38:50 UTC (rev 10148)
+++ trunk/mapserver/maplayer.c 2010-05-07 20:50:37 UTC (rev 10149)
@@ -451,7 +451,8 @@
/* always retrieve all items in some cases */
- if(layer->connectiontype == MS_INLINE || get_all == MS_TRUE) {
+ if(layer->connectiontype == MS_INLINE || get_all == MS_TRUE ||
+ (layer->map->outputformat && layer->map->outputformat->renderer == MS_RENDER_WITH_KML)) {
msLayerGetItems(layer);
if(nt > 0) /* need to realloc the array to accept the possible new items*/
layer->items = (char **)realloc(layer->items, sizeof(char *)*(layer->numitems + nt));
More information about the mapserver-commits
