[mapserver-commits] r10168 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed May 19 16:58:37 EDT 2010
Author: assefa
Date: 2010-05-19 16:58:34 -0400 (Wed, 19 May 2010)
New Revision: 10168
trunk/mapserver/mapdraw.c
trunk/mapserver/mapkml.cpp
trunk/mapserver/mapkml.h
trunk/mapserver/mapkmlrenderer.cpp
trunk/mapserver/mapkmlrenderer.h
trunk/mapserver/mapserv.c
trunk/mapserver/mapserver.h
More cleaup for the kml renderer (styling, raster) #3431
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapdraw.c 2010-05-19 20:58:34 UTC (rev 10168)
@@ -1379,7 +1379,12 @@
if( MS_RENDERER_PLUGIN(image->format) )
- return msDrawRasterLayerPlugin(map, layer, image);
+#ifdef USE_KML
+ if (MS_RENDERER_KML(image->format))
+ return msDrawRasterLayerKml(map, layer, image);
+ else
+#endif
+ return msDrawRasterLayerPlugin(map, layer, image);
else if( MS_RENDERER_GD(image->format) )
return msDrawRasterLayerLow(map, layer, image, NULL);
Modified: trunk/mapserver/mapkml.cpp
--- trunk/mapserver/mapkml.cpp 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapkml.cpp 2010-05-19 20:58:34 UTC (rev 10168)
@@ -76,7 +76,7 @@
void msRenderPolygonTiledKml(imageObj *img, shapeObj *p, imageObj *tile)
- KmlRenderer* renderer = getKmlRenderer(img);
+ /*KmlRenderer* renderer = getKmlRenderer(img);*/
void msRenderLineTiledKml(imageObj *img, shapeObj *p, imageObj *tile)
@@ -204,10 +204,16 @@
void msEndShapeKml(imageObj *img, shapeObj *shape)
- renderer->endShape(img, shape);
+ KmlRenderer* renderer = getKmlRenderer(img);
+ renderer->endShape(img, shape);
+int msDrawRasterLayerKml(mapObj *map, layerObj *layer, imageObj *img)
+ return renderer->renderRasterLayer(img);
#ifdef __cplusplus
#endif
Modified: trunk/mapserver/mapkml.h
--- trunk/mapserver/mapkml.h 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapkml.h 2010-05-19 20:58:34 UTC (rev 10168)
@@ -63,6 +63,8 @@
void msFreeTileKml(imageObj *tile);
void msFreeSymbolKml(symbolObj *symbol);
+int msDrawRasterLayerKml(mapObj *map, layerObj *layer, imageObj *img);
#ifdef __cplusplus
#endif
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapkmlrenderer.cpp 2010-05-19 20:58:34 UTC (rev 10168)
@@ -48,6 +48,8 @@
papszLayerIncludeItems = NULL;
nIncludeItems=0;
+ LineStyle = NULL;
+ numLineStyle = 0;
xmlNodePtr styleNode;
xmlNodePtr listStyleNode;
@@ -101,18 +103,28 @@
imageObj* KmlRenderer::createInternalImage()
rendererVTableObj *r = RasterizerOutputFormat->vtable;
- imageObj *image = r->createImage(Width, Height, RasterizerOutputFormat, &BgColor);
- image->format = RasterizerOutputFormat;
- image->format->refcount++;
- image->width = currentLayer->map->width;
- image->height = currentLayer->map->height;
+ imageObj *image =NULL;
+ mapObj *map = currentLayer->map;
- image->resolution = currentLayer->map->resolution;
- image->resolutionfactor = currentLayer->map->resolution/currentLayer->map->defresolution;
- if (currentLayer->map->web.imagepath)
- image->imagepath = strdup(currentLayer->map->web.imagepath);
- if (map->web.imageurl)
- image->imageurl = strdup(currentLayer->map->web.imageurl);
+ if (r)
+ image = r->createImage(Width, Height, RasterizerOutputFormat, &BgColor);
+ image->format = RasterizerOutputFormat;
+ image->format->refcount++;
+ image->width = currentLayer->map->width;
+ image->height = currentLayer->map->height;
+ image->resolution = currentLayer->map->resolution;
+ image->resolutionfactor = currentLayer->map->resolution/currentLayer->map->defresolution;
+ if (currentLayer->map->web.imagepath)
+ image->imagepath = strdup(currentLayer->map->web.imagepath);
+ if (map->web.imageurl)
+ image->imageurl = strdup(currentLayer->map->web.imageurl);
+ else
+ image = msImageCreateAGG(map->width, map->height,
+ RasterizerOutputFormat,
+ map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution);
return image;
@@ -124,37 +136,37 @@
int KmlRenderer::saveImage(imageObj *, FILE *fp, outputFormatObj*)
- /* Write out the document. */
+ /* Write out the document. */
- int bufSize = 0;
- xmlChar *buf = NULL;
- msIOContext *context = NULL;
+ int bufSize = 0;
+ xmlChar *buf = NULL;
+ msIOContext *context = NULL;
- if( msIO_needBinaryStdout() == MS_FAILURE )
- return MS_FAILURE;
+ if( msIO_needBinaryStdout() == MS_FAILURE )
+ return MS_FAILURE;
- xmlDocDumpFormatMemoryEnc(XmlDoc, &buf, &bufSize, "UTF-8", 1);
+ xmlDocDumpFormatMemoryEnc(XmlDoc, &buf, &bufSize, "UTF-8", 1);
- context = msIO_getHandler(fp);
+ context = msIO_getHandler(fp);
- int chunkSize = 4096;
- for (int i=0; i<bufSize; i+=chunkSize)
- int size = chunkSize;
- if (i + size > bufSize)
- size = bufSize - i;
+ int chunkSize = 4096;
+ for (int i=0; i<bufSize; i+=chunkSize)
+ int size = chunkSize;
+ if (i + size > bufSize)
+ size = bufSize - i;
- if (context)
- msIO_contextWrite(context, buf+i, size);
- else
- msIO_fwrite(buf+i, 1, size, fp);
+ if (context)
+ msIO_contextWrite(context, buf+i, size);
+ else
+ msIO_fwrite(buf+i, 1, size, fp);
- xmlFree(buf);
+ xmlFree(buf);
- return(MS_SUCCESS);
+ return(MS_SUCCESS);
@@ -177,6 +189,17 @@
for(i=0; i<layer->numclasses; i++)
layer->_class[i]->label.position = MS_XY;
+ /*we do not want to draw multiple styles.
+ the new rendering architecture does not allow
+ to know if we are dealing with a multi-style.
+ So here we remove all styles beside the first one*/
+ for(i=0; i<layer->numclasses; i++)
+ while (layer->_class[i]->numstyles > 1)
+ msDeleteStyle(layer->_class[i], layer->_class[i]->numstyles-1);
char* KmlRenderer::getLayerName(layerObj *layer)
@@ -212,6 +235,7 @@
else
VectorMode = MS_TRUE;
/*check if a vector layer will be dumped as a raster*/
const char *outputAsRaster=msLookupHashTable(&(layer->metadata),"KML_OUTPUTASRASTER");
if (outputAsRaster && strlen(outputAsRaster) > 0 &&
@@ -266,6 +290,14 @@
if (layer->map->mappath)
sprintf(MapPath, "%s", layer->map->mappath);
+ /*First rendered layer - check mapfile projection*/
+ checkProjection(layer->map);
+ /*check for image path and image url*/
+ if (layer->map->debug && (layer->map->web.imageurl == NULL || layer->map->web.imagepath == NULL))
+ msDebug("KmlRenderer::startNewLayer: imagepath and imageurl sould be set in the web object\n");
/*map rect for ground overlay*/
MapExtent = layer->map->extent;
MapCellsize = layer->map->cellsize;
@@ -273,10 +305,7 @@
xmlNewChild(DocNode, NULL, BAD_CAST "name", BAD_CAST layer->map->name);
- /*First rendered layer - check mapfile projection*/
- checkProjection(layer->map);
currentLayer = layer;
@@ -339,10 +368,15 @@
The agg should be the only one used but at this point it is not completed; so
use cairo for vector layer that are rasterized and agg2 for raster layers*/
if (layer->type == MS_LAYER_RASTER)
- sprintf(rasterizerFomatName, "agg2png");
+ sprintf(rasterizerFomatName, "agg2png"); //"aggpng24");
else
- sprintf(rasterizerFomatName, "cairopng");
+#ifdef USE_CAIRO
+ sprintf(rasterizerFomatName, "cairopng");
+#else
+#endif
for (int i=0; i<layer->map->numoutputformats; i++)
@@ -415,6 +449,8 @@
if (papszLayerIncludeItems && nIncludeItems>0)
msFreeCharArray(papszLayerIncludeItems, nIncludeItems);
+ papszLayerIncludeItems=NULL;
@@ -456,28 +492,33 @@
#ifdef USE_PROJ
if (projection && projection->numargs > 0 && pj_is_latlong(projection->proj))
- char *projStr = msGetProjectionString(projection);
- /* is ellipsoid WGS84 or projection code epsg:4326 */
- if (strcasestr(projStr, "WGS84") || strcasestr(projStr,"epsg:4326"))
- return MS_SUCCESS;
+ return MS_SUCCESS;
else
- //TODO: give a warning in debug mode
char epsg_string[100];
- //??The only projection valid
+ rectObj sRect;
+ projectionObj out;
strcpy(epsg_string, "epsg:4326" );
+ msInitProjection(&out);
+ msLoadProjectionString(&out, epsg_string);
+ sRect = map->extent;
+ msProjectRect(projection, &out, &sRect);
msFreeProjection(projection);
msLoadProjectionString(projection, epsg_string);
+ /*change also units and extents*/
+ map->extent = sRect;
+ map->units = MS_DD;
+ if (map->debug)
+ msDebug("KmlRenderer::checkProjection: Mapfile projection set to epsg:4326\n");
return MS_SUCCESS;
- msSetError(MS_PROJERR, "Mapfile projection not defined, KML output driver requires projection WGS84 (epsg:4326)", "KmlRenderer::checkProjection()" );
#else
msSetError(MS_MISCERR, "Projection support not enabled", "KmlRenderer::checkProjection" );
return MS_FAILURE;
@@ -491,7 +532,7 @@
/*always add a name. It will be replaced by a text value if available*/
char tmpid[100];
char *stmp=NULL, *layerName=NULL;
- sprintf(tmpid, ".%d", (int)CurrentShape->index);
+ sprintf(tmpid, ".%d", CurrentShapeIndex);
layerName = getLayerName(currentLayer);
stmp = msStringConcatenate(stmp, layerName);
stmp = msStringConcatenate(stmp, tmpid);
@@ -515,11 +556,12 @@
if (!PlacemarkNode)
return;
- memcpy(&LineStyle, style, sizeof(strokeStyleObj));
+ addLineStyleToList(style);
SymbologyFlag[Line] = 1;
- if (p != CurrentShapeDrawn)
+ /*p->index > CurrentDrawnShapeIndexneed to be reviewd. Added since the hight
+ level code caches shapes when rendering lines*/
+ if (CurrentDrawnShapeIndex == -1 || p->index > CurrentDrawnShapeIndex)
xmlNodePtr geomNode = getGeomParentNode("LineString");
@@ -538,7 +580,7 @@
- CurrentShapeDrawn = p;
+ CurrentDrawnShapeIndex = p->index;
@@ -577,7 +619,7 @@
SymbologyFlag[Polygon] = 1;
+ if (p->index != CurrentDrawnShapeIndex)
xmlNodePtr geomParentNode = getGeomParentNode("Polygon");
@@ -596,8 +638,8 @@
addCoordsNode(ringNode, p->line[i].point, p->line[i].numpoints);
@@ -880,16 +922,16 @@
char crdStr[64];
xmlNodePtr latLonBoxNode = xmlNewChild(groundOverlayNode, NULL, BAD_CAST "LatLonBox", NULL);
- sprintf(crdStr, "%.8f", MapExtent.maxy);
+ sprintf(crdStr, "%.8f", currentLayer->map->extent.maxy);
xmlNewChild(latLonBoxNode, NULL, BAD_CAST "north", BAD_CAST crdStr);
- sprintf(crdStr, "%.8f", MapExtent.miny);
+ sprintf(crdStr, "%.8f", currentLayer->map->extent.miny);
xmlNewChild(latLonBoxNode, NULL, BAD_CAST "south", BAD_CAST crdStr);
- sprintf(crdStr, "%.8f", MapExtent.minx);
+ sprintf(crdStr, "%.8f", currentLayer->map->extent.minx);
xmlNewChild(latLonBoxNode, NULL, BAD_CAST "west", BAD_CAST crdStr);
- sprintf(crdStr, "%.8f", MapExtent.maxx);
+ sprintf(crdStr, "%.8f", currentLayer->map->extent.maxx);
xmlNewChild(latLonBoxNode, NULL, BAD_CAST "east", BAD_CAST crdStr);
xmlNewChild(latLonBoxNode, NULL, BAD_CAST "rotation", BAD_CAST "0.0");
@@ -902,9 +944,22 @@
if (PlacemarkNode)
flushPlacemark();
- CurrentShapeDrawn = NULL;
- CurrentShape = shape;
+ CurrentShapeIndex=-1;
+ CurrentDrawnShapeIndex = -1;
+ /*should be done at endshape but the plugin architecture does not call endshape yet*/
+ if(LineStyle)
+ msFree(LineStyle);
+ LineStyle = NULL;
+ numLineStyle = 0;
+ if (shape)
+ CurrentShapeIndex = shape->index;
PlacemarkNode = NULL;
GeomNode = NULL;
@@ -918,7 +973,7 @@
void KmlRenderer::endShape(imageObj*, shapeObj*)
+ CurrentShapeIndex = -1;
xmlNodePtr KmlRenderer::getGeomParentNode(char *geomName)
@@ -1020,17 +1075,20 @@
<width>1</width> <!-- float -->
</LineStyle>
- if (currentLayer && currentLayer->opacity > 0 && currentLayer->opacity < 100 &&
- LineStyle.color.alpha == 255)
- LineStyle.color.alpha = MS_NINT(currentLayer->opacity*2.55);
+ for (int i=0; i<numLineStyle; i++)
+ if (currentLayer && currentLayer->opacity > 0 && currentLayer->opacity < 100 &&
+ LineStyle[i].color.alpha == 255)
+ LineStyle[i].color.alpha = MS_NINT(currentLayer->opacity*2.55);
- sprintf(lineHexColor,"%02x%02x%02x%02x", LineStyle.color.alpha, LineStyle.color.blue,
- LineStyle.color.green, LineStyle.color.red);
+ sprintf(lineHexColor,"%02x%02x%02x%02x", LineStyle[i].color.alpha, LineStyle[0].color.blue,
+ LineStyle[i].color.green, LineStyle[i].color.red);
- char lineStyleName[32];
- sprintf(lineStyleName, "_line_%s_w%.1f", lineHexColor, LineStyle.width);
- styleName = msStringConcatenate(styleName, lineStyleName);
+ char lineStyleName[32];
+ sprintf(lineStyleName, "_line_%s_w%.1f", lineHexColor, LineStyle[i].width);
+ styleName = msStringConcatenate(styleName, lineStyleName);
if (SymbologyFlag[Polygon])
@@ -1125,12 +1183,17 @@
if (SymbologyFlag[Line])
- xmlNodePtr lineStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "LineStyle", NULL);
- xmlNewChild(lineStyleNode, NULL, BAD_CAST "color", BAD_CAST lineHexColor);
+ xmlNodePtr lineStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "LineStyle", NULL);
+ sprintf(lineHexColor,"%02x%02x%02x%02x", LineStyle[i].color.alpha, LineStyle[i].color.blue,
+ xmlNewChild(lineStyleNode, NULL, BAD_CAST "color", BAD_CAST lineHexColor);
- char width[16];
- sprintf(width, "%.1f", LineStyle.width);
- xmlNewChild(lineStyleNode, NULL, BAD_CAST "width", BAD_CAST width);
+ char width[16];
+ sprintf(width, "%.1f", LineStyle[i].width);
+ xmlNewChild(lineStyleNode, NULL, BAD_CAST "width", BAD_CAST width);
if (SymbologyFlag[Symbol])
@@ -1144,7 +1207,18 @@
sprintf(scale, "%.1f", style->scale);
xmlNewChild(iconStyleNode, NULL, BAD_CAST "scale", BAD_CAST scale);*/
+ else
+ const char *value=msLookupHashTable(¤tLayer->metadata, "kml_default_symbol_href");
+ if (value && strlen(value) > 0)
+ xmlNodePtr iconStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "IconStyle", NULL);
+ xmlNodePtr iconNode = xmlNewChild(iconStyleNode, NULL, BAD_CAST "Icon", NULL);
+ xmlNewChild(iconNode, NULL, BAD_CAST "href", BAD_CAST value);
if (SymbologyFlag[Label])
xmlNodePtr labelStyleNode = xmlNewChild(styleNode, NULL, BAD_CAST "LabelStyle", NULL);
@@ -1249,8 +1323,36 @@
return NULL;
-int KmlRenderer::renderRasterLayer(imageObj *img)
+int KmlRenderer::renderRasterLayer(imageObj*)
return msDrawRasterLayer(currentLayer->map, currentLayer, ImgLayer);
+void KmlRenderer::addLineStyleToList(strokeStyleObj *style)
+ /*actually this is not necessary. kml only uses the last LineStyle
+ so we should not bother keeping them all*/
+ int i =0;
+ for (i=0; i<numLineStyle; i++)
+ if (style->width == LineStyle[i].width &&
+ LineStyle[i].color.alpha == style->color.alpha &&
+ LineStyle[i].color.red == style->color.red &&
+ LineStyle[i].color.green == style->color.green &&
+ LineStyle[i].color.blue == style->color.blue)
+ break;
+ if (i == numLineStyle)
+ numLineStyle++;
+ if (LineStyle == NULL)
+ LineStyle = (strokeStyleObj *)malloc(sizeof(strokeStyleObj));
+ else
+ LineStyle = (strokeStyleObj *)realloc(LineStyle, sizeof(strokeStyleObj)*numLineStyle);
+ memcpy(&LineStyle[numLineStyle-1], style, sizeof(strokeStyleObj));
#endif
Modified: trunk/mapserver/mapkmlrenderer.h
--- trunk/mapserver/mapkmlrenderer.h 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapkmlrenderer.h 2010-05-19 20:58:34 UTC (rev 10168)
@@ -63,8 +63,8 @@
xmlNodePtr GeomNode;
xmlNodePtr DescriptionNode;
- shapeObj *CurrentShape;
- shapeObj *CurrentShapeDrawn;
+ int CurrentShapeIndex;
+ int CurrentDrawnShapeIndex;
char **Items;
int NumItems;
int DumpAttributes;
@@ -72,8 +72,9 @@
// placemark symbology
hashTableObj *StyleHashTable;
- labelStyleObj LabelStyle;
- strokeStyleObj LineStyle;
+ labelStyleObj LabelStyle;
+ strokeStyleObj *LineStyle;
+ int numLineStyle;
colorObj PolygonColor;
char SymbolName[128];
@@ -138,6 +139,7 @@
xmlNodePtr getGeomParentNode(char *geomName);
char* getLayerName(layerObj *layer);
void processLayer(layerObj *layer);
+ void addLineStyleToList(strokeStyleObj *style);
public:
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapserv.c 2010-05-19 20:58:34 UTC (rev 10168)
@@ -1161,7 +1161,8 @@
exit(0);
- } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0) {
+ } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0 ||
+ strncmp(argv[iArg], "XMLPOST_QUERY_STRING=", 13) == 0) {
/* Debugging hook... pass "QUERY_STRING=..." on the command-line */
putenv( "REQUEST_METHOD=GET" );
putenv( argv[iArg] );
@@ -1420,7 +1421,11 @@
msIO_printf("Cache-Control: max-age=%s%c", msLookupHashTable(&(mapserv->map->web.metadata), "http_max_age"), 10);
- if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
+ if(mapserv->sendheaders) {
+ const char *attachment = msGetOutputFormatOption(mapserv->map->outputformat, "ATTACHMENT", NULL );
+ if(attachment) msIO_printf("Content-disposition: attachment; filename=%s\n", attachment);
+ msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
if( mapserv->Mode == MAP || mapserv->Mode == TILE )
status = msSaveImage(mapserv->map, img, NULL);
@@ -1804,7 +1809,11 @@
img = msDrawMap(mapserv->map, MS_TRUE);
if(!img) writeError();
- if(mapserv->sendheaders) msIO_printf("Content-type: %s%c%c",MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
+ msIO_printf("Content-type: %s%c%c",MS_IMAGE_MIME_TYPE(mapserv->map->outputformat), 10,10);
if(status != MS_SUCCESS) writeError();
msFreeImage(img);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2010-05-19 15:58:03 UTC (rev 10167)
+++ trunk/mapserver/mapserver.h 2010-05-19 20:58:34 UTC (rev 10168)
@@ -360,6 +360,7 @@
#define MS_RENDERER_AGG(format) ((format)->renderer == MS_RENDER_WITH_AGG)
#define MS_RENDERER_PLUGIN(format) ((format)->renderer >= MS_RENDER_WITH_CAIRO_RASTER)
#define MS_RENDERER_TEMPLATE(format) ((format)->renderer == MS_RENDER_WITH_TEMPLATE)
+#define MS_RENDERER_KML(format) ((format)->renderer == MS_RENDER_WITH_KML)
#define MS_CELLSIZE(min,max,d) ((max - min)/(d-1)) /* where min/max are from an MapServer pixel center-to-pixel center extent */
#define MS_OWS_CELLSIZE(min,max,d) ((max - min)/d) /* where min/max are from an OGC pixel outside edge-to-pixel outside edge extent */
More information about the mapserver-commits
