[mapserver-commits] r10184 - trunk/docs/en/mapscript/php
Thu May 27 14:41:12 EDT 2010
Author: aboudreault
Date: 2010-05-27 14:41:10 -0400 (Thu, 27 May 2010)
New Revision: 10184
   trunk/docs/en/mapscript/php/index.txt
   trunk/docs/en/mapscript/php/migration_guide.txt
Added memory management section in php/mapscript doc
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-05-27 16:08:40 UTC (rev 10183)
+++ trunk/docs/en/mapscript/php/index.txt	2010-05-27 18:41:10 UTC (rev 10184)
@@ -330,6 +330,10 @@
 int removeMetaData(string name)
     Remove a metadata entry for the class.  Returns MS_SUCCESS/MS_FAILURE.
+void free()
+    Free the object properties and break the internal references.
+    Note that you have to unset the php variable to free totally the resources.
 colorObj
@@ -572,15 +576,15 @@
 Accessible only through the `mapObj`_ (map->labelcache). This object
 is only used to give the possiblity to free the label cache
-(map->labelcache->free())
+(map->labelcache->freeCache())
 Method
-boolean free()
+boolean freeCache()
     Free the label cache. Always returns MS_SUCCESS.
-    Ex : (map->labelcache->free();
+    Ex : (map->labelcache->freeCache();
 labelObj
@@ -674,6 +678,10 @@
         $oStyle->removebinding(MS_LABEL_BINDING_COLOR);
+void free()
 layerObj
@@ -1026,6 +1034,10 @@
     Returns an array containing the grid intersection coordinates. If there
     are no coordinates, it returns an empty array.
+void free()
 legendObj
@@ -1064,6 +1076,10 @@
 int set(string property_name, new_value)
     Set object property to a new value.
+void free()
 lineObj
@@ -1601,6 +1617,10 @@
 layerObj removeLayer( int nIndex )
     Remove a layer from the mapObj. The argument is the index of the layer
     to be removed. Returns the removed layerObj on success, else null.
+void free()
 outputformatObj
@@ -1842,6 +1862,10 @@
+void free()
 rectObj
@@ -1935,6 +1959,10 @@
+void free()
 resultCacheMemberObj
@@ -2003,6 +2031,10 @@
     Sets the imagecolor propery (baclground) of the object.
     Returns MS_SUCCESS or MS_FAILURE on error.
+void free()
 shapefileObj
@@ -2058,10 +2090,13 @@
 int addPoint(pointObj point)
     Appends a point to an open shapefile.
+void free()
 **NOTE**: The shape file is closed (and changes committed) when the object
           is destroyed. You can explicitly close and save the changes by calling
-          unset($shape), which will also free the  php object.
+          $shapefile->free(); unset($shapefile), which will also free the php object.
 shapeObj
@@ -2253,6 +2288,10 @@
     Given a tolerance, returns a simplified shape object using
     underlying GEOS library or NULL on error.
+void free()
 styleObj
@@ -2343,6 +2382,10 @@
         $oStyle->removebinding(MS_STYLE_BINDING_COLOR);
+void free()
 symbolObj
@@ -2465,6 +2508,10 @@
 	$oSymbol->set("character", "D");
     $oSymbol->set("font", "ttfFontName");
+void free()
 webObj
@@ -2507,3 +2554,49 @@
+void free()
+ Memory Management
+Normally, you should not have to worry about the memory management because
+php has a garbage collector and will free resources for you. If you write
+only small scripts that don't do a lot of processing, it's not worth to
+care about that. Everything will be freed at the end of the script.
+However, it may be useful to free resources during the execution if the
+script executes many tasks. To do so, you'll have to call the **free()**
+method of the mapscript objects and unset the php variables. The purpose of
+the free methods is to break the circular references between an object and
+its properties to allow the zend engine to free the resources.
+Here's an example of a script that doesn't free things during the execution:
+.. code-block:: php
+    $map = new mapObj("mapfile.map");
+    $of = $map->outputformat;
+    echo $map->extent->minx." - ".$map->extent->miny." - ".$map->extent->maxx." - ".$map->extent->maxy."\n";
+    echo "Outputformat name: $of->name\n";
+    unset($of);
+    unset($map); // Even if we unset the php variables, resources wont be freed
+    // Resources will be only freed at the end of the script
+and the same script that frees resources as soon as it can
+    unset($of);
+    $map->free(); // break the circular references
+    // at this place, the outputformat ($of) and the rect object ($map->extent) resources are freed
+    unset($map);
+    // the map object is immediately freed after the unset (before the end of the script)
Modified: trunk/docs/en/mapscript/php/migration_guide.txt
--- trunk/docs/en/mapscript/php/migration_guide.txt	2010-05-27 16:08:40 UTC (rev 10183)
+++ trunk/docs/en/mapscript/php/migration_guide.txt	2010-05-27 18:41:10 UTC (rev 10184)
@@ -89,9 +89,8 @@
   * pointObj: free
   * projectionObj: free
   * rectObj: free
-  * shapeObj: free, union_geos
-  * shapefileObj: free
-  * symbolObj: free, getstylearray
+  * shapeObj: union_geos
+  * symbolObj: getstylearray
   * outputFormatObj: getformatoption, setformatoption
 layerObj
