[mapserver-commits] r10191 - branches/branch-5-6/mapserver
Fri May 28 15:16:25 EDT 2010
Author: assefa
Date: 2010-05-28 15:16:24 -0400 (Fri, 28 May 2010)
New Revision: 10191
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/mapwfs.c
Correct PropertyName parsing for wfs post requests (#3235)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2010-05-28 14:59:13 UTC (rev 10190)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2010-05-28 19:16:24 UTC (rev 10191)
@@ -15,6 +15,8 @@
 Version 5.6.4 (????-??-??):
+- Correct PropertyName parsing for wfs post requests (#3235)
 - Ensure mapwmslayer.c does not unlink file before closing connection on it (#3451)
 - Fix security exception issue in C# with MSVC2010 (#3438)
Modified: branches/branch-5-6/mapserver/mapwfs.c
--- branches/branch-5-6/mapserver/mapwfs.c	2010-05-28 14:59:13 UTC (rev 10190)
+++ branches/branch-5-6/mapserver/mapwfs.c	2010-05-28 19:16:24 UTC (rev 10191)
@@ -256,7 +256,7 @@
    else
        /* Map has no SRS.  Use layer SRS or produce a warning. */
-       pszWfsSrs = msOWSGetEPSGProj(&(map->projection),&(map->web.metadata), "FO", MS_TRUE);
+       pszWfsSrs = msOWSGetEPSGProj(&(lp->projection),&(lp->metadata), "FO", MS_TRUE);
    msOWSPrintEncodeParam(stdout, "(at least one of) MAP.PROJECTION, LAYER.PROJECTION or wfs_srs metadata",
@@ -1196,16 +1196,30 @@
                   if (strlen(papszPropertyName[k]) > 0)
-                      msInsertHashTable(&(lp->metadata), "GML_INCLUDE_ITEMS", papszPropertyName[k]);
+                      if (strcasecmp(papszPropertyName[k], "*") == 0)
+                          msInsertHashTable(&(lp->metadata), "GML_INCLUDE_ITEMS", "all");
+                      /*this character is only used internally and allows postrequest to
+                        have a proper property name parsing. It means do not affect what was set
+                      in the map file, It is set necessary when a wfs post request is used with
+                      several query elements, with some having property names and some not*/
+                      else if (strcasecmp(papszPropertyName[k], "!") == 0)
+                      else
+                          msInsertHashTable(&(lp->metadata), "GML_INCLUDE_ITEMS", papszPropertyName[k]);
-                      /* exclude geometry if it was not asked for */
-                      if (msOWSLookupMetadata(&(lp->metadata), "OFG", "geometries") != NULL)
-                        sprintf(szTmp, "%s", msOWSLookupMetadata(&(lp->metadata), "OFG", "geometries"));
-                      else
-                        sprintf(szTmp, OWS_GML_DEFAULT_GEOMETRY_NAME);
+                          /* exclude geometry if it was not asked for */
+                          if (msOWSLookupMetadata(&(lp->metadata), "OFG", "geometries") != NULL)
+                            sprintf(szTmp, "%s", msOWSLookupMetadata(&(lp->metadata), "OFG", "geometries"));
+                          else
+                            sprintf(szTmp, OWS_GML_DEFAULT_GEOMETRY_NAME);
-                      if (strstr(papszPropertyName[k], szTmp) == NULL)
-                        msInsertHashTable(&(lp->metadata), "GML_GEOMETRIES", "none");
+                          if (strstr(papszPropertyName[k], szTmp) == NULL)
+                            msInsertHashTable(&(lp->metadata), "GML_GEOMETRIES", "none");
                   else /*empty string*/
@@ -2249,9 +2263,9 @@
 /*      Parse typenames and filters. If there are multiple queries,     */
-/*      typenames will be build with comma between thme                 */
+/*      typenames will be build with comma between them                 */
 /*      (typename1,typename2,...) and filters will be build with        */
-/*      bracets enclosinf the filters :(filter1)(filter2)...            */
+/*      brackets enclosing the filters :(filter1)(filter2)...            */
 /*      propertynames are stored like (property1,property2)(property1)  */
                     while (psQuery &&  psQuery->pszValue &&
@@ -2289,9 +2303,9 @@
                         psPropertyName = CPLGetXMLNode(psQuery, "PropertyName");
                         pszTmp2= NULL;
-                        /*when there is no PropertyName, we outpout () so that it is parsed properly in GetFeature*/
+                        /*when there is no PropertyName, we outpout (!) so that it is parsed properly in GetFeature*/
                         if (psPropertyName == NULL)
-                          pszTmp2 = strdup("");
+                          pszTmp2 = strdup("!");
                         while (psPropertyName)
