[mapserver-commits] r10194 - sandbox/mapserver6
svn at osgeo.org
svn at osgeo.org
Sun May 30 06:08:17 EDT 2010
Author: tbonfort
Date: 2010-05-30 06:08:15 -0400 (Sun, 30 May 2010)
New Revision: 10194
sandbox/mapserver6/mapagg2.cpp
sandbox/mapserver6/mapcairo.c
agg pixmap symbols
Modified: sandbox/mapserver6/mapagg2.cpp
--- sandbox/mapserver6/mapagg2.cpp 2010-05-28 20:18:58 UTC (rev 10193)
+++ sandbox/mapserver6/mapagg2.cpp 2010-05-30 10:08:15 UTC (rev 10194)
@@ -353,12 +353,48 @@
return MS_SUCCESS;
-int agg2RenderPixmapSymbol(imageObj *img, double x, double y,
- symbolObj *symbol, symbolStyleObj * style) {
+int agg2RenderPixmapSymbol(imageObj *img, double x, double y, symbolObj *symbol, symbolStyleObj * style) {
+ AGG2Renderer *r = agg2GetRenderer(img);
rasterBufferObj *pixmap = symbol->pixmap_buffer;
rendering_buffer b(pixmap->pixelbuffer, pixmap->width, pixmap->height, pixmap->width*4);
pixel_format pf(b);
+ r->m_rasterizer_aa.reset();
+ r->m_rasterizer_aa.filling_rule(mapserver::fill_non_zero);
+ if( style->rotation != 0 || style->scale != 1) {
+ mapserver::trans_affine image_mtx;
+ image_mtx *= mapserver::trans_affine_translation(-(pf.width()/2.),-(pf.height()/2.));
+ /*agg angles are antitrigonometric*/
+ image_mtx *= mapserver::trans_affine_rotation(-style->rotation);
+ image_mtx *= mapserver::trans_affine_scaling(style->scale);
+ image_mtx *= mapserver::trans_affine_translation(x,y);
+ image_mtx.invert();
+ typedef mapserver::span_interpolator_linear<> interpolator_type;
+ interpolator_type interpolator(image_mtx);
+ mapserver::span_allocator<color_type> sa;
+ // "hardcoded" bilinear filter
+ typedef mapserver::span_image_filter_rgba_bilinear_clip<pixel_format, interpolator_type> span_gen_type;
+ span_gen_type sg(pf, mapserver::rgba(0,0,0,0), interpolator);
+ mapserver::path_storage pixmap_bbox;
+ int ims_2 = MS_NINT(MS_MAX(pixmap->width,pixmap->height)*style->scale*1.415)/2+1;
+ pixmap_bbox.move_to(x-ims_2,y-ims_2);
+ pixmap_bbox.line_to(x+ims_2,y-ims_2);
+ pixmap_bbox.line_to(x+ims_2,y+ims_2);
+ pixmap_bbox.line_to(x-ims_2,y+ims_2);
+ r->m_rasterizer_aa.add_path(pixmap_bbox);
+ mapserver::render_scanlines_aa(r->m_rasterizer_aa, r->sl_line, r->m_renderer_base, sa, sg);
+ else {
+ //just copy the image at the correct location (we place the pixmap on
+ //the nearest integer pixel to avoid blurring)
+ r->m_renderer_base.blend_from(pf,0,MS_NINT(x-pixmap->width/2.),MS_NINT(y-pixmap->height/2.));
return MS_FAILURE;
Modified: sandbox/mapserver6/mapcairo.c
--- sandbox/mapserver6/mapcairo.c 2010-05-28 20:18:58 UTC (rev 10193)
+++ sandbox/mapserver6/mapcairo.c 2010-05-30 10:08:15 UTC (rev 10194)
@@ -158,7 +158,7 @@
cairo_font_face_set_user_data (newface->face, &newface->facekey,
&(newface->ftface), (cairo_destroy_func_t) FT_Done_Face);
- newface->path = font;
+ newface->path = strdup(font);
return newface;
More information about the mapserver-commits
