[mapserver-commits] r10698 - trunk/mapserver
Mon Nov 1 18:08:23 EDT 2010
Author: tamas
Date: 2010-11-01 15:08:23 -0700 (Mon, 01 Nov 2010)
New Revision: 10698
   trunk/mapserver/mapgd2.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/maputil.c
Add saveImageBuffer to the renderer vtable in order to support the renderer specific native buffer output. Implemented saveImageBuffer for the gd2 renderer.
Modified: trunk/mapserver/mapgd2.c
--- trunk/mapserver/mapgd2.c	2010-11-01 19:26:33 UTC (rev 10697)
+++ trunk/mapserver/mapgd2.c	2010-11-01 22:08:23 UTC (rev 10698)
@@ -61,6 +61,65 @@
   return img;
+unsigned char* saveImageBufferGD(imageObj *img, int *size_ptr, outputFormatObj *format)
+  gdImagePtr ip;
+  unsigned char *imgbytes;
+  gdIOCtx *ctx;
+  if(!img || !size_ptr) return NULL;
+  if(!(ip = MS_IMAGE_GET_GDIMAGEPTR(img))) return NULL;
+  ctx = gdNewDynamicCtx (2048, NULL);
+  if( format->imagemode == MS_IMAGEMODE_RGBA )
+    gdImageSaveAlpha( ip, 1 );
+  else if( format->imagemode == MS_IMAGEMODE_RGB )
+    gdImageSaveAlpha( ip, 0 );
+  if(strcasecmp("ON", msGetOutputFormatOption(format, "INTERLACE", "ON")) == 0)
+    gdImageInterlace(ip, 1);
+  if(format->transparent)
+    gdImageColorTransparent(ip, 0);
+  if(strcasecmp(format->driver, "gd2/gif") == 0) {
+#ifdef USE_GD_GIF
+    gdImageGifCtx( ip, ctx );
+#else
+    msSetError(MS_MISCERR, "GIF output is not available.", "saveImageBufferGD()");
+    ctx->gd_free(ctx);
+    return NULL;
+#endif
+  } else if(strcasecmp(format->driver, "gd2/png") == 0) {
+#ifdef USE_GD_PNG
+    gdImagePngCtx(ip, ctx);
+#else
+    msSetError(MS_MISCERR, "PNG output is not available.", "saveImageBufferGD()");
+    return NULL;
+#endif
+  } else if(strcasecmp(format->driver, "gd2/jpeg") == 0) {
+#ifdef USE_GD_JPEG
+    gdImageJpegCtx(ip, ctx, atoi(msGetOutputFormatOption( format, "QUALITY", "75")));
+#else
+    msSetError(MS_MISCERR, "JPEG output is not available.", "saveImageBufferGD()");
+    return NULL;
+#endif
+  } else {
+    msSetError(MS_MISCERR, "Unknown or unsupported format.", "saveImageBufferGD()");
+    return NULL;
+  imgbytes = gdDPExtractData (ctx, size_ptr);
+  return imgbytes;
 int saveImageGD(imageObj *img, FILE *fp, outputFormatObj *format)
   gdImagePtr ip;
@@ -426,6 +485,7 @@
   renderer->renderLine = &renderLineGD;
   renderer->createImage = &createImageGD;
   renderer->saveImage = &saveImageGD;
+  renderer->saveImageBuffer = &saveImageBufferGD;
   renderer->getRasterBuffer = &getRasterBufferGD;
   renderer->transformShape = &msTransformShapeToPixel;
   renderer->renderPolygon = &renderPolygonGD;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-11-01 19:26:33 UTC (rev 10697)
+++ trunk/mapserver/mapserver.h	2010-11-01 22:08:23 UTC (rev 10698)
@@ -2753,6 +2753,7 @@
     /* image i/o */
     imageObj* (*createImage)(int width, int height, outputFormatObj *format, colorObj* bg);
     int (*saveImage)(imageObj *img, FILE *fp, outputFormatObj *format);
+    unsigned char* (*saveImageBuffer)(imageObj *img, int *size_ptr, outputFormatObj *format);
     /* helper functions */
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2010-11-01 19:26:33 UTC (rev 10697)
+++ trunk/mapserver/maputil.c	2010-11-01 22:08:23 UTC (rev 10698)
@@ -795,6 +795,10 @@
             return buffer.data;
             //don't free the bufferObj as we don't own the bytes anymore
         } else {
+            /* check if the renderer supports native buffer output */
+            if (renderer->saveImageBuffer)
+                return renderer->saveImageBuffer(image, size_ptr, format);
 	        msSetError(MS_MISCERR, "Unsupported image type", "msSaveImageBuffer()");
             return NULL;
