[mapserver-commits] r10700 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Nov 2 08:01:49 EDT 2010
Author: assefa
Date: 2010-11-02 05:01:49 -0700 (Tue, 02 Nov 2010)
New Revision: 10700
trunk/mapserver/mapwms.c
Remove non-square processing for a GetFeature request (#3480)
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2010-11-02 00:09:09 UTC (rev 10699)
+++ trunk/mapserver/mapwms.c 2010-11-02 12:01:49 UTC (rev 10700)
@@ -2993,32 +2993,7 @@
/*make sure to initialize the map scale so that layers that are scale dependent are resepected for
the query*/
msCalculateScale(map->extent,map->units,map->width,map->height, map->resolution, &map->scaledenom);
- /*adjust geotransformation parameters. This has no impact on regular GetFeatureInfo results
- but is necessary if we need to return the results through templating mechanism and
- need to transform (reproject) the data #3241*/
- if( msTestConfigOption( map, "MS_NONSQUARE", MS_FALSE ) )
- double cellsize_x = (map->extent.maxx - map->extent.minx)/map->width;
- double cellsize_y = (map->extent.maxy - map->extent.miny)/map->height;
- if( cellsize_y != 0.0
- && (fabs(cellsize_x/cellsize_y) > 1.00001
- || fabs(cellsize_x/cellsize_y) < 0.99999) )
- map->gt.need_geotransform = MS_TRUE;
- if (map->debug)
- msDebug( "msDrawMap(): kicking into non-square pixel preserving mode.\n" );
- map->cellsize = (cellsize_x*0.5 + cellsize_y*0.5);
- /* update geotransform based on adjusted extent. */
- msMapComputeGeotransform( map );
- /* Do we need to fake out stuff for rotated support? */
- if( map->gt.need_geotransform )
- msMapSetFakedExtent( map );
/* check if all layers selected are queryable. If not send an */
/* exception. */
More information about the mapserver-commits
