[mapserver-commits] r10704 - trunk/mapserver
    svn at osgeo.org
    svn at osgeo.org
    Wed Nov  3 17:04:47 EDT 2010
Author: aboudreault
Date: 2010-11-03 14:04:46 -0700 (Wed, 03 Nov 2010)
New Revision: 10704
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapserv.c
   trunk/mapserver/maptemplate.c
   trunk/mapserver/maptemplate.h
   trunk/mapserver/mapwms.c
Added a built-in OpenLayers map viewer (#3549)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-11-03 03:04:54 UTC (rev 10703)
+++ trunk/mapserver/HISTORY.TXT	2010-11-03 21:04:46 UTC (rev 10704)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Added a built-in OpenLayers map viewer (#3549)
 - Fixed issues with static buffers and sprintf (#3537)
 - Fix for the memory corruption when mapping the string data type in the Java bindings (3491)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2010-11-03 03:04:54 UTC (rev 10703)
+++ trunk/mapserver/mapserv.c	2010-11-03 21:04:46 UTC (rev 10704)
@@ -1120,6 +1120,7 @@
   int sendheaders = MS_TRUE;
   struct mstimeval execstarttime, execendtime;
   struct mstimeval requeststarttime, requestendtime;
+  char *service = NULL;
   msSetup();
@@ -1284,7 +1285,7 @@
         if( (ms_error->code != MS_NOERR) && (ms_error->isreported == MS_FALSE) )
           writeError();
       ** This was a WMS/WFS request... cleanup and exit
       ** At this point any error has already been handled
@@ -1296,8 +1297,26 @@
                 (requestendtime.tv_sec+requestendtime.tv_usec/1.0e6)-
                 (requeststarttime.tv_sec+requeststarttime.tv_usec/1.0e6) );
-      msFreeMapServObj(mapserv);
+      if (strcasecmp(mapserv->map->imagetype, "application/openlayers")==0)
+        for( i=0; i<mapserv->request->NumParams; i++)
+          if(strcasecmp(mapserv->request->ParamNames[i], "SERVICE") == 0) {
+            service = mapserv->request->ParamValues[i];
+            break;
+        if (service && strcasecmp(service,"WMS")==0)
+          msIO_printf("Content-type: text/html%c%c",10,10);
+          if (msReturnOpenLayersPage(mapserv) != MS_SUCCESS)
+            writeError();
+      msFreeMapServObj(mapserv);
 #ifdef USE_FASTCGI
       /* FCGI_ --- return to top of loop */
       continue;
@@ -1357,7 +1376,12 @@
     if(mapserv->Mode == BROWSE) {
-      if(!mapserv->map->web.template) {
+      char *template =  NULL;
+      for(i=0;i<mapserv->request->NumParams;i++) /* find the template param value */
+          if (strcasecmp(mapserv->request->ParamNames[i], "template") == 0)
+              template = mapserv->request->ParamValues[i];
+      if ( (!mapserv->map->web.template) && (template==NULL || (strcasecmp(template, "openlayers")!=0)) ) {
         msSetError(MS_WEBERR, "Traditional BROWSE mode requires a TEMPLATE in the WEB section, but none was provided.", "mapserv()");
         writeError();
@@ -1375,8 +1399,13 @@
       if(msGenerateImages(mapserv, MS_FALSE, MS_TRUE) != MS_SUCCESS)
         writeError();
-      if(QueryFile) {
+      if ( (template != NULL) && (strcasecmp(template, "openlayers")==0) ) {
+          writeError();
+      else if(QueryFile) {
         if(msReturnTemplateQuery(mapserv, mapserv->map->web.queryformat, NULL) != MS_SUCCESS)
           writeError();
       } else {
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2010-11-03 03:04:54 UTC (rev 10703)
+++ trunk/mapserver/maptemplate.c	2010-11-03 21:04:46 UTC (rev 10704)
@@ -39,6 +39,40 @@
 MS_CVSID("$Id$")
+static char *olUrl = "http://www.mapserver.org/lib/OpenLayers-ms60.js";
+static char *olTemplate = \
+"<html>\n"
+"<head>\n"
+"  <title>MapServer Simple Viewer</title>\n"
+"    <script type=\"text/javascript\" src=\"[openlayers_js_url]\"></script>\n"
+"    </head>\n"
+"    <body>\n"
+"      <div style=\"width:[mapwidth]; height:[mapheight]\" id=\"map\"></div>\n"
+"      <script defer=\"defer\" type=\"text/javascript\">\n"
+"        var map = new OpenLayers.Map('map',\n"
+"                                     {maxExtent: new OpenLayers.Bounds([minx],[miny],[maxx],[maxy]),\n"
+"                                      maxResolution: [cellsize]});\n"
+"        [openlayers_layer];\n"
+"        map.addLayer(mslayer);\n"
+"        map.zoomToMaxExtent();\n"
+"      </script>\n"
+"</body>\n"
+"</html>";
+static char *olLayerMapServerTag = \
+"var mslayer = new OpenLayers.Layer.MapServer( \"MapServer Layer\",\n"
+"                                              \"[mapserv_onlineresource]\",\n"
+"                                              {layers: '[layers]'},\n"
+"                                              {singleTile: \"true\", ratio:1} )";
+static char *olLayerWMSTag = \
+"var mslayer = new OpenLayers.Layer.WMS('MapServer Simple Viewer\',\n"
+"                                   '[mapserv_onlineresource]',\n"
+"                                   {layers: '[LAYERS]',\n"
+"                                   bbox: '[minx],[miny],[maxx],[maxy]',\n"
+"                                   width: [mapwidth], height: [mapheight] },"
+"                                   {singleTile: \"true\", ratio:1, projection: '[SRS]'});\n";
 static char *processLine(mapservObj *mapserv, char *instr, FILE *stream, int mode);
 static int isValidTemplate(FILE *stream, const char *filename)
@@ -3429,6 +3463,9 @@
     snprintf(repstr, PROCESSLINE_BUFLEN, "%s%s%s.map", mapserv->map->web.imagepath, mapserv->map->name, mapserv->Id);
     outstr = msReplaceSubstring(outstr, "[map]", repstr);
+  outstr = msReplaceSubstring(outstr, "[mapserv_onlineresource]",
+                              msOWSGetOnlineResource(mapserv->map, "O", "onlineresource", mapserv->request));
   if(getenv("HTTP_HOST")) {
     snprintf(repstr, PROCESSLINE_BUFLEN, "%s", getenv("HTTP_HOST"));
@@ -4168,7 +4205,52 @@
   return MS_SUCCESS;
+int msReturnOpenLayersPage(mapservObj *mapserv)
+    int i;
+    char *buffer = NULL, *layer = NULL;
+    const char *tmpUrl = NULL;
+    char *openlayersUrl = olUrl;
+    /* 2 CGI parameters are used in the template. we need to transform them
+     * to be sure the case match during the template processing */
+        if(strcasecmp(mapserv->request->ParamNames[i], "SRS") == 0) {
+            free(mapserv->request->ParamNames[i]);
+            mapserv->request->ParamNames[i] = strdup("SRS");
+        else if(strcasecmp(mapserv->request->ParamNames[i], "LAYERS") == 0) {
+            mapserv->request->ParamNames[i] = strdup("LAYERS");
+    /* check if the environment variable or config MS_OPENLAYERS_JS_URL is set */
+    tmpUrl = msGetConfigOption(mapserv->map, "MS_OPENLAYERS_JS_URL");
+    if (tmpUrl)
+        openlayersUrl = (char*)tmpUrl;
+    else if (getenv("MS_OPENLAYERS_JS_URL"))
+        openlayersUrl = getenv("MS_OPENLAYERS_JS_URL");
+    if (mapserv->Mode == BROWSE) {
+        msSetError(MS_WMSERR, "At least one layer name required in LAYERS.",
+                   "msWMSLoadGetMapParams()");
+        layer = processLine(mapserv, olLayerMapServerTag, NULL, BROWSE);
+    else
+        layer = processLine(mapserv, olLayerWMSTag, NULL, BROWSE);
+    buffer = processLine(mapserv, olTemplate, NULL, BROWSE);
+    buffer = msReplaceSubstring(buffer, "[openlayers_js_url]", openlayersUrl);
+    buffer = msReplaceSubstring(buffer, "[openlayers_layer]", layer);
+    msIO_fwrite(buffer, strlen(buffer), 1, stdout);
+    free(layer);
+    free(buffer);
+    return MS_SUCCESS;
 mapservObj *msAllocMapServObj()
   mapservObj *mapserv = malloc(sizeof(mapservObj));
Modified: trunk/mapserver/maptemplate.h
--- trunk/mapserver/maptemplate.h	2010-11-03 03:04:54 UTC (rev 10703)
+++ trunk/mapserver/maptemplate.h	2010-11-03 21:04:46 UTC (rev 10704)
@@ -139,6 +139,7 @@
 MS_DLL_EXPORT int msReturnURL(mapservObj* msObj, char*, int);
 MS_DLL_EXPORT int msReturnNestedTemplateQuery(mapservObj* msObj, char* pszMimeType, char **papszBuffer);
 MS_DLL_EXPORT int msReturnTemplateQuery(mapservObj *msObj, char* pszMimeType,  char **papszBuffer);
+MS_DLL_EXPORT int msReturnOpenLayersPage(mapservObj *mapserv);
 MS_DLL_EXPORT int msRedirect(char* url);
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2010-11-03 03:04:54 UTC (rev 10703)
+++ trunk/mapserver/mapwms.c	2010-11-03 21:04:46 UTC (rev 10704)
@@ -672,39 +672,42 @@
       outputFormatObj *psFormat=NULL;
       formatfound = 1;
-      /*check to see if a predefined list is given*/
-      format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getmap_formatlist");
-      if (format_list)
+      if (strcasecmp(values[i], "application/openlayers")!=0)
-          psFormat = msOwsIsOutputFormatValid(map, values[i], &(map->web.metadata),
-                                             "M", "getmap_formatlist");
-          if (psFormat == NULL)
+          /*check to see if a predefined list is given*/
+          format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getmap_formatlist");
+          if (format_list)
-              msSetError(MS_IMGERR,
-                       "Unsupported output format (%s).",
-                       "msWMSLoadGetMapParams()",
-                       values[i] );
-              return msWMSException(map, nVersion, "InvalidFormat");
+              psFormat = msOwsIsOutputFormatValid(map, values[i], &(map->web.metadata),
+                                                  "M", "getmap_formatlist");
+              if (psFormat == NULL &&
+                  strcasecmp(values[i], "application/openlayers")!=0)
+                  msSetError(MS_IMGERR,
+                             "Unsupported output format (%s).",
+                             "msWMSLoadGetMapParams()",
+                             values[i] );
+                  return msWMSException(map, nVersion, "InvalidFormat");
-      else
-          format = msSelectOutputFormat( map, values[i] );
-          if( format == NULL ||
-              (strncasecmp(format->driver, "GD/", 3) != 0 &&
-               strncasecmp(format->driver, "GDAL/", 5) != 0 &&
-               strncasecmp(format->driver, "AGG/", 4) != 0 &&
-               strncasecmp(format->driver, "AGG2/", 5) != 0 &&
-               strncasecmp(format->driver, "CAIRO/", 6) != 0 &&
-               strncasecmp(format->driver, "SVG", 3) != 0 &&
-               strncasecmp(format->driver, "KML", 3) != 0))
+          else
-                         values[i] );
+              format = msSelectOutputFormat( map, values[i] );
+              if( format == NULL ||
+                  (strncasecmp(format->driver, "GD/", 3) != 0 &&
+                   strncasecmp(format->driver, "GDAL/", 5) != 0 &&
+                   strncasecmp(format->driver, "AGG/", 4) != 0 &&
+                   strncasecmp(format->driver, "AGG2/", 5) != 0 &&
+                   strncasecmp(format->driver, "CAIRO/", 6) != 0 &&
+                   strncasecmp(format->driver, "SVG", 3) != 0 &&
+                   strncasecmp(format->driver, "KML", 3) != 0))
+                                 values[i] );
       msFree( map->imagetype );
@@ -2789,14 +2792,16 @@
     msIO_printf("Cache-Control: max-age=%s\n", http_max_age , 10, 10);
-  msIO_printf("Content-type: %s%c%c",
-              MS_IMAGE_MIME_TYPE(map->outputformat), 10,10);
-  if (msSaveImage(map, img, NULL) != MS_SUCCESS)
-      return msWMSException(map, nVersion, NULL);
+  if (strcasecmp(map->imagetype, "application/openlayers")!=0)
+      msIO_printf("Content-type: %s%c%c",
+                  MS_IMAGE_MIME_TYPE(map->outputformat), 10,10);
+      if (msSaveImage(map, img, NULL) != MS_SUCCESS)
+          return msWMSException(map, nVersion, NULL);
+      msFreeImage(img);
-  msFreeImage(img);
   return(MS_SUCCESS);
More information about the mapserver-commits
