[mapserver-commits] r10707 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Nov 4 15:12:55 EDT 2010
Author: aboudreault
Date: 2010-11-04 12:12:55 -0700 (Thu, 04 Nov 2010)
New Revision: 10707
trunk/mapserver/mapserv.c
trunk/mapserver/maptemplate.c
Fixed built-in openlayers template to support OGC WMS GetMap version >= 1.3.0 (#3549)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2010-11-03 23:05:08 UTC (rev 10706)
+++ trunk/mapserver/mapserv.c 2010-11-04 19:12:55 UTC (rev 10707)
@@ -1298,7 +1298,8 @@
(requeststarttime.tv_sec+requeststarttime.tv_usec/1.0e6) );
- if (strcasecmp(mapserv->map->imagetype, "application/openlayers")==0)
+ if (status == MS_SUCCESS &&
+ strcasecmp(mapserv->map->imagetype, "application/openlayers")==0)
for( i=0; i<mapserv->request->NumParams; i++)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2010-11-03 23:05:08 UTC (rev 10706)
+++ trunk/mapserver/maptemplate.c 2010-11-04 19:12:55 UTC (rev 10707)
@@ -70,8 +70,8 @@
" '[mapserv_onlineresource]',\n"
" {layers: '[LAYERS]',\n"
" bbox: '[minx],[miny],[maxx],[maxy]',\n"
-" width: [mapwidth], height: [mapheight] },"
-" {singleTile: \"true\", ratio:1, projection: '[SRS]'});\n";
+" width: [mapwidth], height: [mapheight], version: '[VERSION]'},"
+" {singleTile: \"true\", ratio:1, projection: '[openlayers_projection]'});\n";
static char *processLine(mapservObj *mapserv, char *instr, FILE *stream, int mode);
@@ -4211,19 +4211,26 @@
char *buffer = NULL, *layer = NULL;
const char *tmpUrl = NULL;
char *openlayersUrl = olUrl;
+ char *projection = NULL;
/* 2 CGI parameters are used in the template. we need to transform them
- * to be sure the case match during the template processing */
+ * to be sure the case match during the template processing. We also
+ * need to search the SRS/CRS parameter to get the projection info. OGC
+ * services version >= 1.3.0 uses CRS rather than SRS */
- if(strcasecmp(mapserv->request->ParamNames[i], "SRS") == 0) {
- free(mapserv->request->ParamNames[i]);
- mapserv->request->ParamNames[i] = strdup("SRS");
+ if( (strcasecmp(mapserv->request->ParamNames[i], "SRS") == 0) ||
+ (strcasecmp(mapserv->request->ParamNames[i], "CRS") == 0) ) {
+ projection = mapserv->request->ParamValues[i];
else if(strcasecmp(mapserv->request->ParamNames[i], "LAYERS") == 0) {
mapserv->request->ParamNames[i] = strdup("LAYERS");
+ else if(strcasecmp(mapserv->request->ParamNames[i], "VERSION") == 0) {
+ free(mapserv->request->ParamNames[i]);
+ mapserv->request->ParamNames[i] = strdup("VERSION");
/* check if the environment variable or config MS_OPENLAYERS_JS_URL is set */
@@ -4244,6 +4251,8 @@
buffer = processLine(mapserv, olTemplate, NULL, BROWSE);
buffer = msReplaceSubstring(buffer, "[openlayers_js_url]", openlayersUrl);
buffer = msReplaceSubstring(buffer, "[openlayers_layer]", layer);
+ if (projection)
+ buffer = msReplaceSubstring(buffer, "[openlayers_projection]", projection);
msIO_fwrite(buffer, strlen(buffer), 1, stdout);
free(layer);
free(buffer);
More information about the mapserver-commits
