[mapserver-commits] r10717 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 12 10:57:45 EST 2010
Author: sdlime
Date: 2010-11-12 07:57:45 -0800 (Fri, 12 Nov 2010)
New Revision: 10717
trunk/mapserver/mapwcs.c
trunk/mapserver/mapwcs20.c
Added patch to address situation where libxml is not available (and WCS support is not requested). (#3595)
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2010-11-12 15:35:22 UTC (rev 10716)
+++ trunk/mapserver/mapwcs.c 2010-11-12 15:57:45 UTC (rev 10717)
@@ -1818,12 +1818,18 @@
wcsParamsObj *params;
int retVal = MS_DONE;
- /* first try to dispatch WCS 20 */
+ /* First try to dispatch WCS 2.0 */
+ /* We need libxml2 for WCS 2.0 */
+#if defined(USE_LIBXML2)
if ((retVal = msWCSDispatch20(map, request)) != MS_DONE )
msDebug("msWCSDispatch(): msWCSDispatch20() finished --> exiting\n");
return retVal;
+#else
+ /* TODO: If we don't have libxml2, then report WCS 2.0 requests */
+ /* as unsupported if possible. Only KVP requests can be detected. */
+#endif /* defined(USE_LIBXML2) */
/* populate the service parameters */
params = msWCSCreateParams();
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2010-11-12 15:35:22 UTC (rev 10716)
+++ trunk/mapserver/mapwcs20.c 2010-11-12 15:57:45 UTC (rev 10717)
@@ -28,6 +28,8 @@
* DEALINGS IN THE SOFTWARE.
+#if defined(USE_WCS_SVR) && defined(USE_LIBXML2)
#include <assert.h>
#include "mapserver.h"
#include "maperror.h"
@@ -2982,3 +2984,5 @@
msWCSFreeParamsObj20(params);
return returnValue;
+#endif /* defined(USE_WCS_SVR) && defined(USE_LIBXML2) */
More information about the mapserver-commits
