[mapserver-commits] r10722 - sandbox/mapserver6
svn at osgeo.org
svn at osgeo.org
Sat Nov 13 13:30:19 EST 2010
Author: tamas
Date: 2010-11-13 10:30:19 -0800 (Sat, 13 Nov 2010)
New Revision: 10722
sandbox/mapserver6/mapimageio.c
sandbox/mapserver6/mapserver.h
Support for saving the GD image to buffer
Modified: sandbox/mapserver6/mapimageio.c
--- sandbox/mapserver6/mapimageio.c 2010-11-13 18:27:32 UTC (rev 10721)
+++ sandbox/mapserver6/mapimageio.c 2010-11-13 18:30:19 UTC (rev 10722)
@@ -800,6 +800,58 @@
return MS_SUCCESS;
+int saveGdImageBuffer(gdImagePtr ip, bufferObj *buffer, outputFormatObj *format) {
+ gdIOCtx *ctx;
+ ctx = gdNewDynamicCtx (2048, NULL);
+ if( format->imagemode == MS_IMAGEMODE_RGBA )
+ gdImageSaveAlpha( ip, 1 );
+ else if( format->imagemode == MS_IMAGEMODE_RGB )
+ gdImageSaveAlpha( ip, 0 );
+ if(strcasecmp("ON", msGetOutputFormatOption(format, "INTERLACE", "ON")) == 0)
+ gdImageInterlace(ip, 1);
+ if(format->transparent)
+ gdImageColorTransparent(ip, 0);
+ if(msCaseFindSubstring(format->driver, "/gif")) {
+ #ifdef USE_GD_GIF
+ gdImageGifCtx( ip, ctx );
+ #else
+ msSetError(MS_MISCERR, "GIF output is not available.", "saveImageGD()");
+ ctx->gd_free(ctx);
+ return(MS_FAILURE);
+ #endif
+ } else if(msCaseFindSubstring(format->driver, "/png")) {
+ #ifdef USE_GD_PNG
+ gdImagePngCtx(ip, ctx);
+ #else
+ msSetError(MS_MISCERR, "PNG output is not available.", "saveImageGD()");
+ #endif
+ } else if(msCaseFindSubstring(format->driver, "/jpeg")) {
+ #ifdef USE_GD_JPEG
+ gdImageJpegCtx(ip, ctx, atoi(msGetOutputFormatOption( format, "QUALITY", "75")));
+ #else
+ msSetError(MS_MISCERR, "JPEG output is not available.", "saveImageGD()");
+ #endif
+ } else {
+ msSetError(MS_MISCERR, "Unknown or unsupported format.", "saveImageGD()");
+ buffer->data = gdDPExtractData (ctx, &buffer->size);
+ return MS_SUCCESS;
int msSaveRasterBuffer(rasterBufferObj *rb, FILE *stream,
if(rb->type == MS_BUFFER_GD) {
@@ -824,6 +876,9 @@
int msSaveRasterBufferToBuffer(rasterBufferObj *data, bufferObj *buffer,
+ if(data->type == MS_BUFFER_GD) {
+ return saveGdImageBuffer(data->data.gd_img, buffer, format);
if(msCaseFindSubstring(format->driver,"/png")) {
streamInfo info;
info.fp = NULL;
Modified: sandbox/mapserver6/mapserver.h
--- sandbox/mapserver6/mapserver.h 2010-11-13 18:27:32 UTC (rev 10721)
+++ sandbox/mapserver6/mapserver.h 2010-11-13 18:30:19 UTC (rev 10722)
@@ -2487,8 +2487,8 @@
int msLoadMSRasterBufferFromFile(char *path, rasterBufferObj *rb);
int msLoadGDRasterBufferFromFile(char *path, rasterBufferObj *rb);
int saveGdImage(gdImagePtr ip, FILE *fp, outputFormatObj *format);
+int saveGdImageBuffer(gdImagePtr ip, bufferObj *buffer, outputFormatObj *format);
void msBufferInit(bufferObj *buffer);
void msBufferResize(bufferObj *buffer, size_t target_size);
MS_DLL_EXPORT void msBufferFree(bufferObj *buffer);
More information about the mapserver-commits
