[mapserver-commits] r10729 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Nov 14 14:55:03 EST 2010
Author: tamas
Date: 2010-11-14 11:55:02 -0800 (Sun, 14 Nov 2010)
New Revision: 10729
trunk/mapserver/mapwcs20.c
Fix for the build problems (#3595)
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2010-11-14 18:52:01 UTC (rev 10728)
+++ trunk/mapserver/mapwcs20.c 2010-11-14 19:55:02 UTC (rev 10729)
@@ -768,7 +768,9 @@
char *validYAxisNames[] = {"y", "yaxis", "y-axis", "y_axis", "lat", "lat_axis", "lat-axis", NULL};
char ***validAxisNames;
char *crs = NULL;
- wcs20SubsetObj* subsets[numAxis];
+ wcs20SubsetObj** subsets;
+ subsets = (wcs20SubsetObj**)malloc(sizeof(wcs20SubsetObj*) * numAxis);
validAxisNames = calloc(sizeof(char**), numAxis);
validAxisNames[0] = validXAxisNames;
@@ -778,11 +780,13 @@
free(validAxisNames);
if(returnValue != MS_SUCCESS)
+ msFree(subsets);
return MS_FAILURE;
if(outBBOX == NULL)
+ msFree(subsets);
return MS_FAILURE;
@@ -812,6 +816,7 @@
msSetError(MS_WCSERR, "CRS for X and Y axis are not the same.",
"msWCSCreateBoundingBox20()");
+ msFree(subsets);
return MS_FAILURE;
@@ -821,6 +826,8 @@
+ msFree(subsets);
/* check if projections are equal */
if(crs != NULL)
@@ -1157,9 +1164,9 @@
/* add constraint */
psConstraint = xmlNewChild(psQuantity, psSweNs, BAD_CAST "constraint", NULL);
- char interval[100];
+ char interval[100];
char id[100];
psAllowedValues = xmlNewChild(psConstraint, psSweNs, BAD_CAST "AllowedValues", NULL);
sprintf(id, "VALUE_SPACE_%d", i);
@@ -2006,12 +2013,13 @@
return MS_FAILURE;
+#define MAX_MIMES 20
static int msWCSGetCapabilities20_CreateProfiles(
mapObj *map, xmlNodePtr psServiceIdentification, xmlNsPtr psOwsNs)
xmlNodePtr psProfile, psTmpNode;
- static const int max_mimes = 20;
- char *available_mime_types[max_mimes];
+ char *available_mime_types[MAX_MIMES];
int i = 0;
/* even indices are urls, uneven are mime-types, or null*/
@@ -2036,7 +2044,7 @@
/* get list of all available mime types */
- msGetOutputFormatMimeList(map, available_mime_types, max_mimes);
+ msGetOutputFormatMimeList(map, available_mime_types, MAX_MIMES);
while(urls_and_mime_types[i] != NULL)
@@ -2682,13 +2690,13 @@
double total = ABS(map->extent.maxx - map->extent.minx),
part = ABS(tmpBBOX.maxx - tmpBBOX.minx);
- map->width = lround((part * map->width) / total);
+ map->width = MS_NINT((part * map->width) / total);
if(ABS(tmpBBOX.maxy - tmpBBOX.miny) != ABS(map->extent.maxy - map->extent.miny))
double total = ABS(map->extent.maxy - map->extent.miny),
part = ABS(tmpBBOX.maxy - tmpBBOX.miny);
- map->height = lround((part * map->height) / total);
+ map->height = MS_NINT((part * map->height) / total);
msDebug("msGetCoverage20(): width: %d height: %d\n", map->width, map->height);
@@ -2878,7 +2886,7 @@
int msWCSDispatch20(mapObj *map, cgiRequestObj *request)
wcs20ParamsObj *params = NULL;
- int returnValue = MS_FAILURE, status;
+ int returnValue = MS_FAILURE, status, x;
params = msWCSCreateParamsObj20();
status = msWCSParseRequest20(request, params);
@@ -2919,7 +2927,6 @@
/*debug output the parsed parameters*/
- int x = 0;
msDebug("ParamsObj:\n");
msDebug("\tVersion: %s\n\tRequest: %s\n\tService: %s\n", params->version, params->request, params->service);
msDebug("\tIDs:\n");
More information about the mapserver-commits
