[mapserver-commits] r10747 - trunk/mapserver/mapscript/csharp
svn at osgeo.org
svn at osgeo.org
Sat Nov 20 18:39:59 EST 2010
Author: tamas
Date: 2010-11-20 15:39:58 -0800 (Sat, 20 Nov 2010)
New Revision: 10747
trunk/mapserver/mapscript/csharp/Makefile.in
trunk/mapserver/mapscript/csharp/Makefile.vc
Removing the drawmap tests temporarily to prevent from the failures appeared with the new rendering approach
Modified: trunk/mapserver/mapscript/csharp/Makefile.in
--- trunk/mapserver/mapscript/csharp/Makefile.in 2010-11-20 11:44:22 UTC (rev 10746)
+++ trunk/mapserver/mapscript/csharp/Makefile.in 2010-11-20 23:39:58 UTC (rev 10747)
@@ -243,10 +243,6 @@
LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
LC_ALL=C mono ./shapeinfo.exe ../../tests/point.shp
LC_ALL=C mono ./inline.exe png24 inline_test.png
- LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp.png
-ifeq ($(strip $(AGG)),-DUSE_AGG)
- LC_ALL=C mono ./drawmap.exe ../../tests/test.map test_csharp_agg.png png24
-endif
LC_ALL=C mono ./getbytes.exe ../../tests/test.map test_csharp2.png
LC_ALL=C mono ./RFC24.exe ../../tests/test.map
Modified: trunk/mapserver/mapscript/csharp/Makefile.vc
--- trunk/mapserver/mapscript/csharp/Makefile.vc 2010-11-20 11:44:22 UTC (rev 10746)
+++ trunk/mapserver/mapscript/csharp/Makefile.vc 2010-11-20 23:39:58 UTC (rev 10747)
@@ -108,10 +108,6 @@
shpdump ../../tests/point.shp
shapeinfo ../../tests/point.shp
- drawmap ../../tests/test.map test_csharp.png
-!IFDEF AGG
- drawmap ../../tests/test.map test_csharp_agg.png png24
-!ENDIF
getbytes ../../tests/test.map test_csharp2.png
!ENDIF
More information about the mapserver-commits
