[mapserver-commits] r10751 -
sandbox/sdlime/common-expressions/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Nov 22 00:51:59 EST 2010
Author: sdlime
Date: 2010-11-21 21:51:59 -0800 (Sun, 21 Nov 2010)
New Revision: 10751
sandbox/sdlime/common-expressions/mapserver/mapfile.c
sandbox/sdlime/common-expressions/mapserver/maplayer.c
sandbox/sdlime/common-expressions/mapserver/mapparser.c
sandbox/sdlime/common-expressions/mapserver/mapparser.y
sandbox/sdlime/common-expressions/mapserver/mapserver.h
sandbox/sdlime/common-expressions/mapserver/maputil.c
Switched token list from a pre-allocated array to a linked list.
Modified: sandbox/sdlime/common-expressions/mapserver/mapfile.c
--- sandbox/sdlime/common-expressions/mapserver/mapfile.c 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/mapfile.c 2010-11-22 05:51:59 UTC (rev 10751)
@@ -1867,36 +1867,47 @@
exp->string = NULL;
exp->compiled = MS_FALSE;
exp->flags = 0;
- exp->numtokens = 0;
+ exp->tokens = exp->curtoken = NULL;
void freeExpression(expressionObj *exp)
- int i=0;
+ tokenListNodeObjPtr node = NULL;
+ tokenListNodeObjPtr nextNode = NULL;
if(!exp) return;
msFree(exp->string);
if((exp->type == MS_REGEX) && exp->compiled) ms_regfree(&(exp->regex));
- for(i=0; i<exp->numtokens; i++) {
- switch(exp->tokens[i].token) {
- case MS_TOKEN_BINDING_DOUBLE:
- case MS_TOKEN_BINDING_INTEGER:
- case MS_TOKEN_BINDING_STRING:
- case MS_TOKEN_BINDING_TIME:
- msFree(exp->tokens[i].tokenval.bindval.item);
- break;
- case MS_TOKEN_LITERAL_TIME:
- /* anything to do? */
- break;
- case MS_TOKEN_LITERAL_STRING:
- msFree(exp->tokens[i].tokenval.strval);
- break;
- case MS_TOKEN_LITERAL_SHAPE:
- msFreeShape(exp->tokens[i].tokenval.shpval);
- free(exp->tokens[i].tokenval.shpval);
- break;
+ // HERE
+ if(exp->tokens) {
+ node = exp->tokens;
+ while (node != NULL) {
+ nextNode = node->next;
+ switch(node->token) {
+ case MS_TOKEN_BINDING_DOUBLE:
+ case MS_TOKEN_BINDING_INTEGER:
+ case MS_TOKEN_BINDING_STRING:
+ case MS_TOKEN_BINDING_TIME:
+ msFree(node->tokenval.bindval.item);
+ break;
+ case MS_TOKEN_LITERAL_TIME:
+ /* anything to do? */
+ break;
+ case MS_TOKEN_LITERAL_STRING:
+ msFree(node->tokenval.strval);
+ break;
+ case MS_TOKEN_LITERAL_SHAPE:
+ msFreeShape(node->tokenval.shpval);
+ free(node->tokenval.shpval);
+ break;
+ msFree(node);
+ node = nextNode;
Modified: sandbox/sdlime/common-expressions/mapserver/maplayer.c
--- sandbox/sdlime/common-expressions/mapserver/maplayer.c 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/maplayer.c 2010-11-22 05:51:59 UTC (rev 10751)
@@ -348,7 +348,7 @@
int msTokenizeExpression(expressionObj *expression, char **list, int *listsize)
- int n=0;
+ tokenListNodeObjPtr node;
int token;
/* TODO: make sure the constants can't somehow reference invalid expression types */
@@ -361,23 +361,31 @@
// fprintf(stderr, "string is %s\n", msyystring);
while((token = msyylex()) != 0) { /* keep processing tokens until the end of the string (\0) */
- // fprintf(stderr, "%d: %d >> %s <<\n", n, token, msyytext);
+ // fprintf(stderr, "%d >> %s <<\n", token, msyytext);
+ if((node = (tokenListNodeObjPtr) malloc(sizeof(tokenListNodeObj))) == NULL) {
+ msSetError(MS_MEMERR, NULL, "msTokenizeExpression()");
+ goto parse_error;
+ node->tailifhead = NULL;
+ node->next = NULL;
switch(token) {
case MS_TOKEN_LITERAL_NUMBER:
- expression->tokens[n].token = token;
- expression->tokens[n].tokenval.dblval = msyynumber;
+ node->token = token;
+ node->tokenval.dblval = msyynumber;
break;
// fprintf(stderr, " token value is: %s\n", msyytext_esc);
- expression->tokens[n].tokenval.strval = strdup(msyytext_esc);
+ node->tokenval.strval = strdup(msyytext_esc);
free(msyytext_esc); msyytext_esc=NULL;
break;
- msTimeInit(&(expression->tokens[n].tokenval.tmval));
- if(msParseTime(msyytext, &(expression->tokens[n].tokenval.tmval)) != MS_TRUE) {
+ msTimeInit(&(node->tokenval.tmval));
+ if(msParseTime(msyytext, &(node->tokenval.tmval)) != MS_TRUE) {
msSetError(MS_PARSEERR, "Parsing time value failed.", "msTokenizeExpression()");
goto parse_error;
@@ -386,12 +394,12 @@
- expression->tokens[n].token = token; /* binding type */
- expression->tokens[n].tokenval.bindval.item = strdup(msyytext);
- if(list) expression->tokens[n].tokenval.bindval.index = string2list(list, listsize, msyytext);
+ node->token = token; /* binding type */
+ node->tokenval.bindval.item = strdup(msyytext);
+ if(list) node->tokenval.bindval.index = string2list(list, listsize, msyytext);
break;
case MS_TOKEN_BINDING_SHAPE:
break;
case MS_TOKEN_FUNCTION_FROMTEXT: /* we want to process a shape from WKT once and not for every feature being evaluated */
if((token = msyylex()) != 40) { /* ( */
@@ -404,11 +412,13 @@
goto parse_error;
- expression->tokens[n].token = MS_TOKEN_LITERAL_SHAPE;
- expression->tokens[n].tokenval.shpval = msShapeFromWKT(msyytext_esc);
+ // fprintf(stderr, "\tWKT=%s\n", msyytext_esc);
+ node->token = MS_TOKEN_LITERAL_SHAPE;
+ node->tokenval.shpval = msShapeFromWKT(msyytext_esc);
free(msyytext_esc);
- if(!expression->tokens[n].tokenval.shpval) {
+ if(!node->tokenval.shpval) {
msSetError(MS_PARSEERR, "Parsing fromText function failed, WKT processing failed.", "msTokenizeExpression()");
goto parse_error;
@@ -421,14 +431,25 @@
break;
default:
- expression->tokens[n].token = token; /* for everything else */
+ node->token = token; /* for everything else */
break;
- n++;
+ /* add node to token list */
+ if(expression->tokens == NULL) {
+ expression->tokens = node;
+ } else {
+ if(expression->tokens->tailifhead != NULL) /* this should never be NULL, but just in case */
+ expression->tokens->tailifhead->next = node; /* put the node at the end of the list */
+ /* repoint the head of the list to the end - our new element
+ this causes a loop if we are at the head, be careful not to
+ walk in a loop */
+ expression->tokens->tailifhead = node;
- expression->numtokens = n;
+ expression->curtoken = expression->tokens; /* point at the first token */
msReleaseLock(TLOCK_PARSER);
return MS_SUCCESS;
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.c
--- sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-11-22 05:51:59 UTC (rev 10751)
@@ -2259,30 +2259,31 @@
int yylex(void)
- int token, i=yyexpr->curtoken;
+ int token;
- // printf("in yylex() - curtoken=%d of %d (value=%d)...\n", i, yyexpr->numtokens, yyexpr->tokens[i].token);
+ if(yyexpr->curtoken == NULL) return(0); /* done */
- if(yyexpr->curtoken == yyexpr->numtokens) return(0); /* done */
+ // fprintf(stderr, "in yylex() - curtoken=%d...\n", yyexpr->curtoken->token);
- token = yyexpr->tokens[i].token; /* may override */
- switch(yyexpr->tokens[i].token) {
+ token = yyexpr->curtoken->token; /* may override */
+ switch(yyexpr->curtoken->token) {
token = NUMBER;
- yylval.dblval = yyexpr->tokens[i].tokenval.dblval;
+ yylval.dblval = yyexpr->curtoken->tokenval.dblval;
break;
token = SHAPE;
- yylval.shpval = yyexpr->tokens[i].tokenval.shpval;
+ // fprintf(stderr, "token value = %s\n", msShapeToWKT(yyexpr->curtoken->tokenval.shpval));
+ yylval.shpval = yyexpr->curtoken->tokenval.shpval;
break;
- // printf("token value = %s\n", yyexpr->tokens[i].tokenval.strval);
+ // printf("token value = %s\n", yyexpr->curtoken->tokenval.strval);
token = STRING;
- yylval.strval = strdup(yyexpr->tokens[i].tokenval.strval);
+ yylval.strval = strdup(yyexpr->curtoken->tokenval.strval);
break;
token = TIME;
- yylval.tmval = yyexpr->tokens[i].tokenval.tmval;
+ yylval.tmval = yyexpr->curtoken->tokenval.tmval;
break;
case MS_TOKEN_COMPARISON_EQ: token = EQ; break;
@@ -2312,20 +2313,21 @@
token = NUMBER;
- yylval.dblval = atof(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+ yylval.dblval = atof(yyshape->values[yyexpr->curtoken->tokenval.bindval.index]);
break;
token = STRING;
- yylval.strval = strdup(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+ yylval.strval = strdup(yyshape->values[yyexpr->curtoken->tokenval.bindval.index]);
break;
token = SHAPE;
+ // fprintf(stderr, "token value = %s\n", msShapeToWKT(yyshape));
yylval.shpval = yyshape;
break;
token = TIME;
msTimeInit(&(yylval.tmval));
- if(msParseTime(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index], &(yylval.tmval)) != MS_TRUE) {
+ if(msParseTime(yyshape->values[yyexpr->curtoken->tokenval.bindval.index], &(yylval.tmval)) != MS_TRUE) {
yyerror("Parsing time value failed.");
return(-1);
@@ -2343,7 +2345,7 @@
break;
- yyexpr->curtoken++;
+ yyexpr->curtoken = yyexpr->curtoken->next; /* re-position */
return(token);
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.y
--- sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-11-22 05:51:59 UTC (rev 10751)
@@ -576,30 +576,31 @@
int yylex(void)
+ int token;
token = NUMBER;
break;
token = SHAPE;
break;
token = STRING;
break;
token = TIME;
break;
@@ -629,20 +630,21 @@
token = NUMBER;
break;
token = STRING;
break;
token = SHAPE;
break;
token = TIME;
return(-1);
@@ -660,7 +662,7 @@
break;
return(token);
Modified: sandbox/sdlime/common-expressions/mapserver/mapserver.h
--- sandbox/sdlime/common-expressions/mapserver/mapserver.h 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/mapserver.h 2010-11-22 05:51:59 UTC (rev 10751)
@@ -510,7 +510,7 @@
typedef struct listNode {
shapeObj shape;
struct listNode *next;
- struct listNode *tailifhead; /* this is the tail node in the list, if this is the head element, otherwise NULL */
+ struct listNode *tailifhead; /* this is the tail node in the list if this is the head element, otherwise NULL */
} featureListNodeObj;
typedef featureListNodeObj * featureListNodeObjPtr;
@@ -566,11 +566,15 @@
attributeBindingObj bindval;
} tokenValueObj;
-typedef struct {
+typedef struct tokenListNode {
int token;
tokenValueObj tokenval;
-} tokenObj;
+ struct tokenListNode *next;
+ struct tokenListNode *tailifhead; /* this is the tail node in the list if this is the head element, otherwise NULL */
+} tokenListNodeObj;
+typedef tokenListNodeObj * tokenListNodeObjPtr;
typedef struct {
char *string;
int type;
@@ -579,9 +583,8 @@
int flags;
/* logical expression options */
- tokenObj tokens[100];
- int numtokens;
- int curtoken;
+ tokenListNodeObjPtr tokens;
+ tokenListNodeObjPtr curtoken;
/* regular expression options */
ms_regex_t regex; /* compiled regular expression to be matched */
Modified: sandbox/sdlime/common-expressions/mapserver/maputil.c
--- sandbox/sdlime/common-expressions/mapserver/maputil.c 2010-11-22 05:35:42 UTC (rev 10750)
+++ sandbox/sdlime/common-expressions/mapserver/maputil.c 2010-11-22 05:51:59 UTC (rev 10751)
@@ -384,7 +384,7 @@
yyshape = shape;
yylayer = layer;
yyexpr = expression;
- yyexpr->curtoken = 0; /* reset */
+ yyexpr->curtoken = yyexpr->tokens; /* reset to the start of the list */
yypresult_type=MS_PARSE_RESULT_BOOLEAN;
status = yyparse();
More information about the mapserver-commits
