[mapserver-commits] r10758 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Nov 22 09:51:05 EST 2010
Author: tbonfort
Date: 2010-11-22 06:51:05 -0800 (Mon, 22 Nov 2010)
New Revision: 10758
trunk/mapserver/mapgd.c
removed unused offset params for gd shade rendering
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2010-11-22 14:16:39 UTC (rev 10757)
+++ trunk/mapserver/mapgd.c 2010-11-22 14:51:05 UTC (rev 10758)
@@ -135,9 +135,8 @@
** Polygon fill. Based on "Concave Polygon Scan Conversion" by Paul
** Heckbert from "Graphics Gems", Academic Press, 1990.
-** TODO: do we need the offsets?
-static void imageFilledPolygon(gdImagePtr im, shapeObj *p, int c, int offsetx, int offsety)
+static void imageFilledPolygon(gdImagePtr im, shapeObj *p, int c)
typedef struct { /* a polygon edge */
double x; /* x coordinate of edge's intersection with current scanline */
@@ -277,7 +276,7 @@
xr = (int) (active[j+1]->x - 0.5) ;
if(active[j]->x != active[j+1]->x)
- imageScanline(im, xl+offsetx, xr+offsetx, y+offsety, c);
+ imageScanline(im, xl, xr, y, c);
active[j]->x += active[j]->dx; /* increment edge coords */
active[j+1]->x += active[j+1]->dx;
@@ -358,7 +357,7 @@
if(!img || !p || !color) return MS_FAILURE;
if(!(ip = MS_IMAGE_GET_GDIMAGEPTR(img))) return MS_FAILURE;
SETPEN(ip, color);
- imageFilledPolygon(ip, p, color->pen, 0, 0);
+ imageFilledPolygon(ip, p, color->pen);
return MS_SUCCESS;
@@ -739,7 +738,7 @@
if(!(tp = MS_IMAGE_GET_GDIMAGEPTR(tile))) return MS_FAILURE;
gdImageColorTransparent(tp,0);
gdImageSetTile(ip, tp);
- imageFilledPolygon(ip, p, gdTiled, 0, 0);
+ imageFilledPolygon(ip, p, gdTiled);
return MS_SUCCESS;
More information about the mapserver-commits
