[mapserver-commits] r10768 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 26 16:06:42 EST 2010
Author: assefa
Date: 2010-11-26 13:06:42 -0800 (Fri, 26 Nov 2010)
New Revision: 10768
trunk/mapserver/mapkmlrenderer.cpp
use ows_description and ows_include_items
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2010-11-26 21:04:43 UTC (rev 10767)
+++ trunk/mapserver/mapkmlrenderer.cpp 2010-11-26 21:06:42 UTC (rev 10768)
@@ -213,13 +213,14 @@
void KmlRenderer::processLayer(layerObj *layer)
int i;
+ const char *asRaster = NULL;
if (!layer)
return;
/*turn of labelcache*/
layer->labelcache = MS_OFF;
- /*if there are labels we want to coordinates to
+ /*if there are labels we want the coordinates to
be the center of the element.*/
for(i=0; i<layer->numclasses; i++)
layer->_class[i]->label.position = MS_XY;
@@ -228,13 +229,21 @@
the new rendering architecture does not allow
to know if we are dealing with a multi-style.
So here we remove all styles beside the first one*/
while (layer->_class[i]->numstyles > 1)
msDeleteStyle(layer->_class[i], layer->_class[i]->numstyles-1);
+ /*if layer has a metadata KML_OUTPUTASRASTER set to true, add a processing directive
+ to use an agg driver*/
+ asRaster = msLookupHashTable(&layer->metadata, "kml_outputasraster");
+ if (asRaster && (strcasecmp(asRaster, "true") == 0 ||
+ strcasecmp(asRaster, "yes") == 0))
+ msLayerAddProcessing(layer, "RENDERER=png24");
char* KmlRenderer::getLayerName(layerObj *layer)
@@ -349,8 +358,12 @@
if (msLookupHashTable(&layer->metadata, "kml_description"))
pszLayerDescMetadata = msLookupHashTable(&layer->metadata, "kml_description");
+ else if (msLookupHashTable(&layer->metadata, "ows_description"))
+ pszLayerDescMetadata = msLookupHashTable(&layer->metadata, "ows_description");
value=msLookupHashTable(&layer->metadata, "kml_include_items");
+ if (!value)
+ value=msLookupHashTable(&layer->metadata, "ows_include_items");
if (value)
papszLayerIncludeItems = msStringSplit(value, ',', &nIncludeItems);
More information about the mapserver-commits
