[mapserver-commits] r10506 - in sandbox/mapserver6/mapscript:
python python/pygdioctx swiginc
svn at osgeo.org
svn at osgeo.org
Fri Sep 17 11:44:04 EDT 2010
Author: aboudreault
Date: 2010-09-17 15:44:04 +0000 (Fri, 17 Sep 2010)
New Revision: 10506
sandbox/mapserver6/mapscript/python/pyextend.i
sandbox/mapserver6/mapscript/python/pygdioctx/pygdioctx.c
sandbox/mapserver6/mapscript/swiginc/image.i
sandbox/mapserver6/mapscript/swiginc/outputformat.i
sandbox/mapserver6/mapscript/swiginc/shapefile.i
sandbox/mapserver6/mapscript/swiginc/symbol.i
Fixed Mapscript/SWIG to use proper functions of mapserver 6 rendering
Modified: sandbox/mapserver6/mapscript/python/pyextend.i
--- sandbox/mapserver6/mapscript/python/pyextend.i 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/python/pyextend.i 2010-09-17 15:44:04 UTC (rev 10506)
@@ -166,23 +166,24 @@
* omit width and height. Work done as part of Bugzilla issue 550. */
imageObj(PyObject *arg1=Py_None, PyObject *arg2=Py_None,
- PyObject *input_format=Py_None)
+ PyObject *input_format=Py_None, PyObject *input_resolution=Py_None, PyObject *input_defresolution=Py_None)
imageObj *image=NULL;
outputFormatObj *format=NULL;
int width;
int height;
+ double resolution, defresolution;
PyObject *pybytes;
+ rendererVTableObj *renderer = NULL;
+ rasterBufferObj *rb = NULL;
unsigned char PNGsig[8] = {137, 80, 78, 71, 13, 10, 26, 10};
unsigned char JPEGsig[3] = {255, 216, 255};
- if (PyInt_Check(arg1) && PyInt_Check(arg2))
+ resolution = defresolution = MS_DEFAULT_RESOLUTION;
+ if ((PyInt_Check(arg1) && PyInt_Check(arg2)) || PyString_Check(arg1))
- /* Create from width, height, format/driver */
- width = (int) PyInt_AsLong(arg1);
- height = (int) PyInt_AsLong(arg2);
if (input_format == Py_None) {
format = msCreateDefaultOutputFormat(NULL, "GD/GIF");
if (format == NULL)
@@ -191,18 +192,21 @@
format = msCreateDefaultOutputFormat(NULL, "GD/JPEG");
if (format == NULL)
format = msCreateDefaultOutputFormat(NULL, "GD/WBMP");
+ if (format)
+ msInitializeRendererVTable(format);
else if (PyString_Check(input_format)) {
- PyString_AsString(input_format));
+ PyString_AsString(input_format));
else {
if ((SWIG_ConvertPtr(input_format, (void **) &format,
- SWIGTYPE_p_outputFormatObj,
- SWIG_POINTER_EXCEPTION | 0 )) == -1)
+ SWIGTYPE_p_outputFormatObj,
+ SWIG_POINTER_EXCEPTION | 0 )) == -1)
msSetError(MS_IMGERR, "Can't convert format pointer",
- "imageObj()");
+ "imageObj()");
return NULL;
@@ -212,15 +216,44 @@
"imageObj()");
return NULL;
- image = msImageCreate(width, height, format, NULL, NULL, NULL);
+ if (PyFloat_Check(input_resolution))
+ resolution = PyFloat_AsDouble(input_resolution);
+ if (PyFloat_Check(input_defresolution))
+ defresolution = PyFloat_AsDouble(input_defresolution);
+ if (PyInt_Check(arg1) && PyInt_Check(arg2))
+ /* Create from width, height, format/driver */
+ width = (int) PyInt_AsLong(arg1);
+ height = (int) PyInt_AsLong(arg2);
+ image = msImageCreate(width, height, format, NULL, NULL, resolution, defresolution, NULL);
return image;
/* Is arg1 a filename? */
else if (PyString_Check(arg1))
- return (imageObj *) msImageLoadGD((char *) PyString_AsString(arg1));
+ renderer = format->vtable;
+ rb = (rasterBufferObj*)calloc(1,sizeof(rasterBufferObj));
+ if (!rb) {
+ msSetError(MS_MEMERR, NULL, "imageObj()");
+ return NULL;
+ if ( (renderer->loadImageFromFile(PyString_AsString(arg1), rb)) == MS_FAILURE)
+ return NULL;
+ image = msImageCreate(rb->width, rb->height, format, NULL, NULL,
+ resolution, defresolution, NULL);
+ renderer->mergeRasterBuffer(image, rb, 1.0, 0, 0, 0, 0, rb->width, rb->height);
+ msFreeRasterBuffer(rb);
+ return image;
/* Is a file-like object */
@@ -298,47 +331,32 @@
int write( PyObject *file=Py_None )
- FILE *stream;
- gdIOCtx *ctx;
unsigned char *imgbuffer=NULL;
int imgsize;
PyObject *noerr;
int retval=MS_FAILURE;
/* Return immediately if image driver is not GD */
- if ( !(MS_DRIVER_GD(self->format) || MS_DRIVER_AGG(self->format)) )
+ if ( !MS_RENDERER_PLUGIN(self->format) )
msSetError(MS_IMGERR, "Writing of %s format not implemented",
"imageObj::write", self->format->driver);
return MS_FAILURE;
if (file == Py_None) /* write to stdout */
- ctx = msNewGDFileCtx(stdout);
- retval = msSaveImageGDCtx(self, ctx, self->format);
- ctx->gd_free(ctx);
+ retval = msSaveImage(NULL, self, NULL);
else if (PyFile_Check(file)) /* a Python (C) file */
- stream = PyFile_AsFile(file);
- ctx = msNewGDFileCtx(stream);
+ renderer = self->format->vtable;
+ retval = renderer->saveImage(self, PyFile_AsFile(file), self->format);
else /* presume a Python file-like object */
- if( MS_DRIVER_GD(self->format) )
- imgbuffer = msSaveImageBufferGD(self, &imgsize,
- self->format);
-#ifdef USE_AGG
- else if( MS_DRIVER_AGG(self->format) )
- imgbuffer = msSaveImageBuffer( self, &imgsize,
- self->format);
-#endif
+ imgbuffer = msSaveImageBuffer(self, &imgsize,
+ self->format);
if (imgsize == 0)
msSetError(MS_IMGERR, "failed to get image buffer", "write()");
@@ -347,7 +365,7 @@
noerr = PyObject_CallMethod(file, "write", "s#", imgbuffer,
imgsize);
- gdFree(imgbuffer);
+ free(imgbuffer);
if (noerr == NULL)
return MS_FAILURE;
else
@@ -364,14 +382,14 @@
unsigned char *imgbytes;
PyObject *imgstring;
- imgbytes = msSaveImageBufferGD(self, &size, self->format);
+ imgbytes = msSaveImageBuffer(self, &size, self->format);
if (size == 0)
msSetError(MS_IMGERR, "failed to get image buffer", "saveToString()");
return NULL;
imgstring = PyString_FromStringAndSize((const char*) imgbytes, size);
- gdFree(imgbytes);
+ free(imgbytes);
return imgstring;
Modified: sandbox/mapserver6/mapscript/python/pygdioctx/pygdioctx.c
--- sandbox/mapserver6/mapscript/python/pygdioctx/pygdioctx.c 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/python/pygdioctx/pygdioctx.c 2010-09-17 15:44:04 UTC (rev 10506)
@@ -136,7 +136,7 @@
imageObj *createImageObjFromPyFile(PyObject *file, const char *driver)
struct PyFileIfaceObj_gdIOCtx *pctx;
@@ -155,7 +155,7 @@
else
pctx = alloc_PyFileIfaceObj_IOCtx(file);
- image = msImageLoadGDCtx((gdIOCtx *) pctx, driver);
+ //image = msImageLoadGDCtx((gdIOCtx *) pctx, driver);
free_PyFileIfaceObj_IOCtx(pctx);
return image;
Modified: sandbox/mapserver6/mapscript/swiginc/image.i
--- sandbox/mapserver6/mapscript/swiginc/image.i 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/swiginc/image.i 2010-09-17 15:44:04 UTC (rev 10506)
@@ -35,14 +35,14 @@
* instead use the one in python/pymodule.i. */
#ifndef SWIGPYTHON
imageObj(int width, int height, outputFormatObj *input_format=NULL,
- const char *file=NULL)
+ const char *file=NULL,
+ double resolution=MS_DEFAULT_RESOLUTION, double defresolution=MS_DEFAULT_RESOLUTION)
outputFormatObj *format;
- if (file) {
- return (imageObj *) msImageLoadGD(file);
if (input_format) {
format = input_format;
@@ -54,13 +54,37 @@
if (format == NULL)
+ if (format)
if (format == NULL) {
msSetError(MS_IMGERR, "Could not create output format",
"imageObj()");
return NULL;
+ if (file) {
+ rb = (rasterBufferObj*) malloc(sizeof(rasterBufferObj));
+ if (!rb) {
+ return NULL;
+ return NULL;
+ return image;
return image;
#endif
@@ -86,26 +110,20 @@
#ifndef SWIGPYTHON
int write( FILE *file=NULL )
- gdIOCtx *ctx=NULL;
- if ( MS_DRIVER_GD(self->format) )
+ if (MS_RENDERER_PLUGIN(self->format))
if (file)
- /* gdNewFileCtx is a semi-documented function from
- gd_io_file.c */
- ctx = msNewGDFileCtx(file);
+ retval = renderer->saveImage(self, file, self->format);
- else /* create a gdIOCtx interface to stdout */
+ else
- /* we wrap msSaveImageGDCtx in the same way that
- gdImageJpeg() wraps gdImageJpegCtx() (bug 1047). */
else
Modified: sandbox/mapserver6/mapscript/swiginc/outputformat.i
--- sandbox/mapserver6/mapscript/swiginc/outputformat.i 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/swiginc/outputformat.i 2010-09-17 15:44:04 UTC (rev 10506)
@@ -47,6 +47,8 @@
return NULL;
/* Else, continue */
format->refcount++;
format->inmapfile = MS_TRUE;
Modified: sandbox/mapserver6/mapscript/swiginc/shapefile.i
--- sandbox/mapserver6/mapscript/swiginc/shapefile.i 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/swiginc/shapefile.i 2010-09-17 15:44:04 UTC (rev 10506)
@@ -104,7 +104,7 @@
msFreeShape(shape); /* frees all lines and points before re-filling */
msSHPReadShape(self->hSHP, i, shape);
- msTransformShapeToPixel(shape, map->extent, map->cellsize);
+ msTransformShapeToPixel(shape, map->extent, map->cellsize, MS_SIMPLIFY_DEFAULT);
return MS_SUCCESS;
Modified: sandbox/mapserver6/mapscript/swiginc/symbol.i
--- sandbox/mapserver6/mapscript/swiginc/symbol.i 2010-09-13 19:41:06 UTC (rev 10505)
+++ sandbox/mapserver6/mapscript/swiginc/symbol.i 2010-09-17 15:44:04 UTC (rev 10506)
@@ -100,14 +100,76 @@
%newobject getImage;
- imageObj *getImage(outputFormatObj *format)
+ imageObj *getImage(outputFormatObj *input_format)
- return msSymbolGetImageGD(self, format);
+ imageObj *image;
+ outputFormatObj *format = NULL;
+ if (self->type != MS_SYMBOL_PIXMAP)
+ msSetError(MS_SYMERR, "Can't return image from non-pixmap symbol",
+ "getImage()");
+ return NULL;
+ if (input_format)
+ format = input_format;
+ else
+ format = msCreateDefaultOutputFormat(NULL, "GD/GIF");
+ if (format == NULL)
+ format = msCreateDefaultOutputFormat(NULL, "GD/PNG");
+ format = msCreateDefaultOutputFormat(NULL, "GD/JPEG");
+ format = msCreateDefaultOutputFormat(NULL, "GD/WBMP");
+ if (format)
+ msSetError(MS_IMGERR, "Could not create output format",
+ "getImage()");
+ return NULL;
+ msPreloadImageSymbol(renderer, self);
+ if (self->pixmap_buffer)
+ image = msImageCreate(self->pixmap_buffer->width, self->pixmap_buffer->height, format, NULL, NULL,
+ MS_DEFAULT_RESOLUTION, MS_DEFAULT_RESOLUTION, NULL);
+ renderer->mergeRasterBuffer(image, self->pixmap_buffer, 1.0, 0, 0, 0, 0,
+ self->pixmap_buffer->width, self->pixmap_buffer->height);
+ return image;
int setImage(imageObj *image)
- return msSymbolSetImageGD(self, image);
+ renderer = image->format->vtable;
+ msFreeRasterBuffer(self->pixmap_buffer);
+ self->pixmap_buffer = (rasterBufferObj*)malloc(sizeof(rasterBufferObj));
+ if (!self->pixmap_buffer) {
+ msSetError(MS_MEMERR, NULL, "setImage()");
+ return MS_FAILURE;
+ renderer->initializeRasterBuffer(self->pixmap_buffer, image->width, image->height, image->format->imagemode);
+ self->type = MS_SYMBOL_PIXMAP;
+ renderer->getRasterBufferCopy(image, self->pixmap_buffer);
+ return MS_SUCCESS;
More information about the mapserver-commits
