[mapserver-commits] r10511 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Sep 22 13:43:46 EDT 2010
Author: tomkralidis
Date: 2010-09-22 17:43:46 +0000 (Wed, 22 Sep 2010)
New Revision: 10511
trunk/mapserver/HISTORY.TXT
trunk/mapserver/configure
trunk/mapserver/configure.in
Set dependency on libxml2 when building --with-wfs (#3512)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-09-20 15:25:06 UTC (rev 10510)
+++ trunk/mapserver/HISTORY.TXT 2010-09-22 17:43:46 UTC (rev 10511)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Set dependency on libxml2 when building --with-wfs (#3512)
- Fixed TRUE is undefined in shptreevis (#3545)
- shptreevis: bug truncates visualization shapefile if there are more
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-09-20 15:25:06 UTC (rev 10510)
+++ trunk/mapserver/configure 2010-09-22 17:43:46 UTC (rev 10511)
@@ -12156,6 +12156,14 @@
echo "${ECHO_T} If unavailable disable using --without-xml2-config," >&6
echo "$as_me:$LINENO: result: but WCS 1.1 support will be disabled." >&5
echo "${ECHO_T} but WCS 1.1 support will be disabled." >&6
+ elif test "x$WFS_SVR_ENABLED" != "x" ; then
+ with_xml2_config=yes
+ echo "$as_me:$LINENO: result: libxml2 requested for WCS Server." >&5
+echo "${ECHO_T}libxml2 requested for WFS Server." >&6
+ echo "$as_me:$LINENO: result: If unavailable disable using --without-xml2-config," >&5
+echo "${ECHO_T} If unavailable disable using --without-xml2-config," >&6
+ echo "$as_me:$LINENO: result: but WFS 1.1 support will be disabled." >&5
+echo "${ECHO_T} but WFS 1.1 support will be disabled." >&6
else
with_xml2_config=no
echo "$as_me:$LINENO: result: libxml2 not required." >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-09-20 15:25:06 UTC (rev 10510)
+++ trunk/mapserver/configure.in 2010-09-22 17:43:46 UTC (rev 10511)
@@ -1934,6 +1934,11 @@
AC_MSG_RESULT([libxml2 requested for WCS Server.])
AC_MSG_RESULT([ If unavailable disable using --without-xml2-config,])
AC_MSG_RESULT([ but WCS 1.1 support will be disabled.])
+ AC_MSG_RESULT([libxml2 requested for WFS Server.])
+ AC_MSG_RESULT([ If unavailable disable using --without-xml2-config,])
+ AC_MSG_RESULT([ but WFS 1.1 support will be disabled.])
else
with_xml2_config=no
AC_MSG_RESULT([libxml2 not required.])
More information about the mapserver-commits
