[mapserver-commits] r10520 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Sep 27 13:30:51 EDT 2010
Author: warmerdam
Date: 2010-09-27 17:30:51 +0000 (Mon, 27 Sep 2010)
New Revision: 10520
trunk/mapserver/mapdrawgdal.c
trunk/mapserver/maprasterquery.c
correct order of arguments to msSetError()
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c 2010-09-24 20:56:14 UTC (rev 10519)
+++ trunk/mapserver/mapdrawgdal.c 2010-09-27 17:30:51 UTC (rev 10520)
@@ -886,7 +886,7 @@
if( eErr != CE_None )
msSetError( MS_IOERR, "GDALRasterIO() failed: %s",
- CPLGetLastErrorMsg(), "drawGDAL()" );
+ "drawGDAL()", CPLGetLastErrorMsg() );
free( pabyRaw1 );
return -1;
@@ -1488,8 +1488,7 @@
msSetError(MS_IOERR,
"Failed to open LUT file '%s'.",
- path,
- "drawGDAL()");
+ "drawGDAL()", path );
return -1;
@@ -1500,8 +1499,8 @@
"LUT definition from file %s longer than maximum buffer size (%d bytes).",
- path, sizeof(lut_def_fromfile),
- "drawGDAL()");
+ "drawGDAL()",
+ path, sizeof(lut_def_fromfile) );
return -1;
@@ -1600,8 +1599,10 @@
- msSetError( MS_IOERR, "GDALDatasetRasterIO() failed: %s",
+ msSetError( MS_IOERR,
+ "GDALDatasetRasterIO() failed: %s",
+ "drawGDAL()",
+ CPLGetLastErrorMsg() );
return -1;
@@ -1657,7 +1658,8 @@
+ "drawGDAL()",
free( pafWholeRawData );
return -1;
@@ -1700,8 +1702,8 @@
msSetError( MS_MISCERR,
"SCALE PROCESSING option unparsable for layer %s.",
- layer->name,
- "msDrawGDAL()" );
+ "msDrawGDAL()",
+ layer->name );
return -1;
else
@@ -2235,8 +2237,7 @@
- "msDrawRasterLayerGDAL_RawMode()" );
+ "msDrawRasterLayerGDAL_RawMode()", CPLGetLastErrorMsg() );
free( pBuffer );
free( f_nodatas );
return -1;
@@ -2422,8 +2423,8 @@
free( pafRawData );
- layer->name,
- "msDrawGDAL()" );
+ "msDrawGDAL()",
+ layer->name );
return -1;
else
@@ -2482,8 +2483,8 @@
free( pafRawData );
"SCALE_BUCKETS PROCESSING option is not a value of 2 or more: %s.",
- pszBuckets,
- "msDrawRasterLayerGDAL_16BitClassification()" );
+ "msDrawRasterLayerGDAL_16BitClassification()",
+ pszBuckets );
return -1;
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c 2010-09-24 20:56:14 UTC (rev 10519)
+++ trunk/mapserver/maprasterquery.c 2010-09-27 17:30:51 UTC (rev 10520)
@@ -550,8 +550,7 @@
- "msRasterQueryByRectLow()" );
+ "msRasterQueryByRectLow()", CPLGetLastErrorMsg() );
free( pafRaster );
return -1;
@@ -922,8 +921,9 @@
if( layer->debug || map->debug )
msSetError( MS_IMGERR,
"Unable to open file %s for layer %s ... fatal error.\n%s",
+ "msRasterQueryByRect()",
szPath, layer->name, cpl_error_msg,
- "msRasterQueryByRect()" );
return(MS_FAILURE);
if( ignore_missing == MS_MISSING_DATA_LOG ) {
More information about the mapserver-commits
