[mapserver-commits] r10532 - trunk/docs/en/development/rfc
svn at osgeo.org
svn at osgeo.org
Tue Sep 28 17:40:49 EDT 2010
Author: tamas
Date: 2010-09-28 21:40:49 +0000 (Tue, 28 Sep 2010)
New Revision: 10532
trunk/docs/en/development/rfc/ms-rfc-61.txt
Update RFC-61 with the voting results
Modified: trunk/docs/en/development/rfc/ms-rfc-61.txt
--- trunk/docs/en/development/rfc/ms-rfc-61.txt 2010-09-28 20:51:33 UTC (rev 10531)
+++ trunk/docs/en/development/rfc/ms-rfc-61.txt 2010-09-28 21:40:49 UTC (rev 10532)
@@ -1,161 +1,161 @@
-.. _rfc61:
- MS RFC 61: Enhance MapServer Feature Style Support
-:Date: 2010/09/11
-:Author: Tamas Szekeres
-:Contact: szekerest at gmail.com
-:Last Edited: $Date$
-:Status: Proposed
-:Id: $Id$
-Description: This RFC proposes a generic implementation for rendering
-the feature styles retrieved from the various data sources. In this
-regard we intend to enhance the existing STYLEITEM option
-which could now be specified for all layer types and not restricted
-to the OGR driver.
-Background
-Currently only the OGR driver supports rendering the styles attached
-to a feature in the OGR data sources. Theoretically only a few data
-sources support storing the styles along with the features
-(like MapInfo, AutoCAD DXF, Microstation DGN), however those styles
-can easily be transferred to many other data sources as a separate attribute
-by using the ogr2ogr SQL option as follows:
- ogr2ogr -sql "select *, OGR_STYLE from srclayer" "dstlayer" "srclayer"
-As a result of the transfer, the OGR style string is added to the
-destination layer as a separate attribute. We could also rename this
-attribute during the transfer according to the following example:
- ogr2ogr -sql "select *, OGR_STYLE as mystyleattribute from srclayer" "dstlayer" "srclayer"
-Currently the style string transferred this way can only be rendered by
-the MapServer OGR driver, however it would be reasonable to implement such
-option for all layer types in MapServer.
-Proposed New Syntax
-This RFC wouldn't alter the current behaviour of STYLEITEM "AUTO" option, which causes
-the driver specific LayerGetAutoStyle vtable method to be called as before.
-If LayerGetAutoStyle is not implemented by a driver an error message is
-provided to the user "'STYLEITEM AUTO' not supported for this data source."
-We will however add support for specifying the feature attribute containing
-the style string in the form: STYLEITEM "mystyleattribute" which
-will tell mapserver to initialize the style from the specified attribute in
-a generic way.
-Supported Style Representations
-We will implement support for either the current mapserver and OGR specific
-style representations.
-The mapserver style representation follows the syntax of the STYLE and CLASS
-entries in the mapfile format like the following sample:
- "STYLE BACKGROUNDCOLOR 128 0 0 COLOR 0 0 208 END"
-By specifying the entire CLASS instead of a single style allows to use further options
-(like setting expressions, label attributes, multiple styles) on a per feature basis.
-In addition to the mapserver style the OGR style string format will also be supported
-as described in the following documentation: http://www.gdal.org/ogr/ogr_feature_style.html
-The actual style format will be identifyed at run-time according to the first characters of the
-style strings. This solution will allow to specify multiple style formats within the same layer.
-Implementation Details
-In order to implement this enhancement the following changes should be
-made in the MapServer codebase:
-1) Modify msDrawVectorLayer (in mapdraw.cpp) to invoke a new method (msLayerGetFeatureStyle)
- when STYLEITEM is set for a particular layer.
-2) Implement msLayerGetFeatureStyle in maplayer.c which will call either msUpdateStyleFromString,
- msUpdateClassFromString or the new method: msOGRUpdateStyleFromString according to
- the actual style format retrieved from the layer.
-3) Modify msOGRLayerGetAutoStyle (in mapogr.cpp) and extract the bulk of the style
- initialization into a separate function (msOGRUpdateStyle). We will add a new function
- (msOGRUpdateStyleFromString) where the style manager will be initialized by using
- OGRStyleMgr::InitStyleString instead of OGRStyleMgr::InitFromFeature
-4) Modify msLayerWhichItems in (maplayer.c) to retrieve the attribute containing the style string
- specified in the STYLEITEM parameter. By using STYLEITEM "AUTO" no additional attribute
- will be retrieved just as before.
-MapScript Issues
-There's no need to modify the MapScript interface since the styleitem parameter has
-already been exposed. However this attribute will now support the name of the style
-attribute not only the "AUTO" value.
-Files affected
-To implement the solution the following files would require to be changed:
-- mapserver.h => Add the declaration for msLayerGetFeatureStyle and msOGRUpdateStyleFromString
-- mapogr.cpp => Add msOGRUpdateStyleFromString and msOGRUpdateStyle
-- maplayer.c => Modify msLayerWhichItems and implement msLayerGetFeatureStyle
-- mapdraw.c => Call msLayerGetFeatureStyle in addition to msLayerGetAutoStyle
-Backwards Compatibilty Issues
-Currently 'STYLEITEM "AUTO"' has only been implemented in the OGR driver which
-overrides LayerGetAutoStyle with a custom implementation. This behaviour would
-continue to work as previously since the generic implementation would not affect those
-drivers which provide custom auto style implementation.
-When using the 'STYLEITEM "mystyleattribute"' setting, we provide a generic implementation
-to set the style directly from the feature attribute and no driver specific
-function will be called. This option will work for all drivers in the same way.
-Further Considerations
-In the future we may provide support further style representations in addition to
-the mapserver and OGR style strings. Each new representation will require a
-proper (and fast) method to identify the format from the style string itself.
-Using the OGR style format will require the OGR driver to be compiled in. If we compile
-MapServer without OGR support and the 'STYLEITEM "mystyleattribute"' option is used,
-those features may not be rendered correctly where the actual style format is OGR
-style string.
-Bug ID
+.. _rfc61:
+ MS RFC 61: Enhance MapServer Feature Style Support
+:Date: 2010/09/11
+:Author: Tamas Szekeres
+:Contact: szekerest at gmail.com
+:Last Edited: $Date$
+:Status: Adopted
+:Id: $Id$
+Description: This RFC proposes a generic implementation for rendering
+the feature styles retrieved from the various data sources. In this
+regard we intend to enhance the existing STYLEITEM option
+which could now be specified for all layer types and not restricted
+to the OGR driver.
+Background
+Currently only the OGR driver supports rendering the styles attached
+to a feature in the OGR data sources. Theoretically only a few data
+sources support storing the styles along with the features
+(like MapInfo, AutoCAD DXF, Microstation DGN), however those styles
+can easily be transferred to many other data sources as a separate attribute
+by using the ogr2ogr SQL option as follows:
+ ogr2ogr -sql "select *, OGR_STYLE from srclayer" "dstlayer" "srclayer"
+As a result of the transfer, the OGR style string is added to the
+destination layer as a separate attribute. We could also rename this
+attribute during the transfer according to the following example:
+ ogr2ogr -sql "select *, OGR_STYLE as mystyleattribute from srclayer" "dstlayer" "srclayer"
+Currently the style string transferred this way can only be rendered by
+the MapServer OGR driver, however it would be reasonable to implement such
+option for all layer types in MapServer.
+Proposed New Syntax
+This RFC wouldn't alter the current behaviour of STYLEITEM "AUTO" option, which causes
+the driver specific LayerGetAutoStyle vtable method to be called as before.
+If LayerGetAutoStyle is not implemented by a driver an error message is
+provided to the user "'STYLEITEM AUTO' not supported for this data source."
+We will however add support for specifying the feature attribute containing
+the style string in the form: STYLEITEM "mystyleattribute" which
+will tell mapserver to initialize the style from the specified attribute in
+a generic way.
+Supported Style Representations
+We will implement support for either the current mapserver and OGR specific
+style representations.
+The mapserver style representation follows the syntax of the STYLE and CLASS
+entries in the mapfile format like the following sample:
+ "STYLE BACKGROUNDCOLOR 128 0 0 COLOR 0 0 208 END"
+By specifying the entire CLASS instead of a single style allows to use further options
+(like setting expressions, label attributes, multiple styles) on a per feature basis.
+In addition to the mapserver style the OGR style string format will also be supported
+as described in the following documentation: http://www.gdal.org/ogr/ogr_feature_style.html
+The actual style format will be identifyed at run-time according to the first characters of the
+style strings. This solution will allow to specify multiple style formats within the same layer.
+Implementation Details
+In order to implement this enhancement the following changes should be
+made in the MapServer codebase:
+1) Modify msDrawVectorLayer (in mapdraw.cpp) to invoke a new method (msLayerGetFeatureStyle)
+ when STYLEITEM is set for a particular layer.
+2) Implement msLayerGetFeatureStyle in maplayer.c which will call either msUpdateStyleFromString,
+ msUpdateClassFromString or the new method: msOGRUpdateStyleFromString according to
+ the actual style format retrieved from the layer.
+3) Modify msOGRLayerGetAutoStyle (in mapogr.cpp) and extract the bulk of the style
+ initialization into a separate function (msOGRUpdateStyle). We will add a new function
+ (msOGRUpdateStyleFromString) where the style manager will be initialized by using
+ OGRStyleMgr::InitStyleString instead of OGRStyleMgr::InitFromFeature
+4) Modify msLayerWhichItems in (maplayer.c) to retrieve the attribute containing the style string
+ specified in the STYLEITEM parameter. By using STYLEITEM "AUTO" no additional attribute
+ will be retrieved just as before.
+MapScript Issues
+There's no need to modify the MapScript interface since the styleitem parameter has
+already been exposed. However this attribute will now support the name of the style
+attribute not only the "AUTO" value.
+Files affected
+To implement the solution the following files would require to be changed:
+- mapserver.h => Add the declaration for msLayerGetFeatureStyle and msOGRUpdateStyleFromString
+- mapogr.cpp => Add msOGRUpdateStyleFromString and msOGRUpdateStyle
+- maplayer.c => Modify msLayerWhichItems and implement msLayerGetFeatureStyle
+- mapdraw.c => Call msLayerGetFeatureStyle in addition to msLayerGetAutoStyle
+Backwards Compatibilty Issues
+Currently 'STYLEITEM "AUTO"' has only been implemented in the OGR driver which
+overrides LayerGetAutoStyle with a custom implementation. This behaviour would
+continue to work as previously since the generic implementation would not affect those
+drivers which provide custom auto style implementation.
+When using the 'STYLEITEM "mystyleattribute"' setting, we provide a generic implementation
+to set the style directly from the feature attribute and no driver specific
+function will be called. This option will work for all drivers in the same way.
+Further Considerations
+In the future we may provide support further style representations in addition to
+the mapserver and OGR style strings. Each new representation will require a
+proper (and fast) method to identify the format from the style string itself.
+Using the OGR style format will require the OGR driver to be compiled in. If we compile
+MapServer without OGR support and the 'STYLEITEM "mystyleattribute"' option is used,
+those features may not be rendered correctly where the actual style format is OGR
+style string.
+Bug ID
The ticket for RFC-61 (containing the implementation) can be found here.
Bug 3544_
-.. _3544: http://trac.osgeo.org/mapserver/ticket/3544
-Voting history
-None
+.. _3544: http://trac.osgeo.org/mapserver/ticket/3544
+Voting history
++1 from SteveW, DanielM, SteveL, PericlesN, AssefaY, FrankW, ThomasB, HowardB and TamasS
More information about the mapserver-commits
