[mapserver-commits] r10536 - trunk/mapserver
Wed Sep 29 14:20:48 EDT 2010
Author: warmerdam
Date: 2010-09-29 18:20:48 +0000 (Wed, 29 Sep 2010)
New Revision: 10536
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwmslayer.c
Restrict cascaded WMS requests based on EXTENT (#3543)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-09-29 18:18:31 UTC (rev 10535)
+++ trunk/mapserver/HISTORY.TXT	2010-09-29 18:20:48 UTC (rev 10536)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Restrict cascaded WMS requests based on EXTENT (#3543)
 - Avoid EPSG lookups for WMS client layers if possible (#3533)
 - RFC-60: Add ability to skip ANGLE FOLLOW labels with too much character overlap (#3523)
Modified: trunk/mapserver/mapwmslayer.c
--- trunk/mapserver/mapwmslayer.c	2010-09-29 18:18:31 UTC (rev 10535)
+++ trunk/mapserver/mapwmslayer.c	2010-09-29 18:20:48 UTC (rev 10536)
@@ -471,7 +471,6 @@
         return MS_FAILURE;
  * Find out request version
@@ -620,7 +619,7 @@
- * Set layer SRS and reproject map extents to the layer's SRS
+ * Set layer SRS.
     /* No need to set lp->proj if it's already set to the right EPSG code */
     if ((pszTmp = msOWSGetEPSGProj(&(lp->projection), NULL, "MO", MS_TRUE)) == NULL ||
@@ -685,10 +684,8 @@
                 && (strcasecmp(nonsquare_ok,"no") == 0
                     || strcasecmp(nonsquare_ok,"false") == 0) )
                 double cellsize_x = (bbox.maxx-bbox.minx) / bbox_width;
                 double cellsize_y = (bbox.maxy-bbox.miny) / bbox_height;
                 if( cellsize_x < cellsize_y * 0.999999 )
@@ -723,6 +720,48 @@
+/*      If the layer has predefined extents, and a predefined           */
+/*      projection that matches the request projection, then            */
+/*      consider restricting the BBOX to match the limits.              */
+    if( bbox_width != 0 )
+        const char *ows_srs;
+        rectObj  layer_rect;
+        ows_srs = msOWSGetEPSGProj(NULL,&(lp->metadata), "MO", MS_FALSE);
+        if( strchr(ows_srs,' ') == NULL
+            && msOWSGetLayerExtent( map, lp, "MO", &layer_rect) == MS_SUCCESS )
+            /* fulloverlap */
+            if( msRectContained( &bbox, &layer_rect ) )
+                /* no changes */
+            /* no overlap */
+            else if( !msRectOverlap( &layer_rect, &bbox ) )
+                bbox_width = 0;
+                bbox_height = 0;
+            else
+                double cellsize_x = (bbox.maxx-bbox.minx) / bbox_width;
+                double cellsize_y = (bbox.maxy-bbox.miny) / bbox_height;
+                double cellsize = MIN(cellsize_x,cellsize_y);
+                msRectIntersect( &bbox, &layer_rect );
+                bbox_width = ceil((bbox.maxx - bbox.minx) / cellsize);
+                bbox_height = ceil((bbox.maxy - bbox.miny) / cellsize);
 /*      Potentially return the bbox.                                    */
     if (bbox_ret != NULL)
@@ -925,6 +964,16 @@
+ * Check if the request is empty, perhaps due to reprojection problems
+ * or wms_extents restrictions.
+    if( bbox_width == 0 || bbox_height == 0 )
+        msFreeWmsParamsObj(&sThisWMSParams);
+        return MS_SUCCESS;  /* No overlap. */
  * Check if layer overlaps current view window (using wms_latlonboundingbox)
     if ((pszTmp = msOWSLookupMetadata(&(lp->metadata),
