[mapserver-commits] r10562 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Sep 30 15:59:55 EDT 2010
Author: tamas
Date: 2010-09-30 19:59:55 +0000 (Thu, 30 Sep 2010)
New Revision: 10562
trunk/docs/en/mapfile/layer.txt
Document the additions related to RFC-61 (#3544)
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt 2010-09-30 19:12:47 UTC (rev 10561)
+++ trunk/docs/en/mapfile/layer.txt 2010-09-30 19:59:55 UTC (rev 10562)
@@ -473,9 +473,38 @@
STYLEITEM [attribute]
- Item to use for feature specific styling. This is *very* experimental and
- OGR only at the moment.
+ Item to use for feature specific styling. The style information may be
+ represented by a separate attribute (style string) attached to the feature.
+ MapServer supports the following style string representations:
+ - **MapServer STYLE definition** - The style string can be represented as a
+ MapServer :ref:`STYLE` block according to the following example:
+ .. code-block:: mapfile
+ STYLE BACKGROUNDCOLOR 128 0 0 COLOR 0 0 208 END
+ - **MapServer CLASS definition** - By specifying the entire :ref:`CLASS`
+ instead of a single style allows to use further options (like setting
+ expressions, label attributes, multiple styles) on a per feature basis.
+ - **OGR Style String** - MapServer support rendering the OGR style string
+ format according to the `OGR - Feature Style Specification`_ documentation.
+ Currently only a few data sources support storing the styles along with the
+ features (like MapInfo, AutoCAD DXF, Microstation DGN), however those styles
+ can easily be transferred to many other data sources as a separate attribute
+ by using the `ogr2ogr`_ command line tool as follows:
+ ogr2ogr -sql "select *, OGR_STYLE from srclayer" "dstlayer" "srclayer"
+.. _`OGR - Feature Style Specification`: http://www.gdal.org/ogr/ogr_feature_style.html
+.. _`ogr2ogr`: http://www.gdal.org/ogr2ogr.html
+ We can specify the value: "AUTO" in order to have the driver to retrieve the
+ style information. Currently only the OGR driver supports the "AUTO" setting,
.. index::
pair: SYMBOLSCALEDENOM; LAYER
More information about the mapserver-commits
