[mapserver-commits] r11449 - trunk/mapserver
Sat Apr 2 18:19:06 EDT 2011
Author: dmorissette
Date: 2011-04-02 15:19:06 -0700 (Sat, 02 Apr 2011)
New Revision: 11449
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maputil.c
Improved error reporting in msSaveImage() (#3733)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-04-02 20:11:21 UTC (rev 11448)
+++ trunk/mapserver/HISTORY.TXT	2011-04-02 22:19:06 UTC (rev 11449)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- Improved error reporting in msSaveImage() (#3733)
 - configure: look for libxslt.so under lib64 as well
 - added missing ';' before charset in WFS DEscribeFeatureType header (#3793)
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2011-04-02 20:11:21 UTC (rev 11448)
+++ trunk/mapserver/maputil.c	2011-04-02 22:19:06 UTC (rev 11449)
@@ -731,12 +731,13 @@
 int msSaveImage(mapObj *map, imageObj *img, char *filename)
-    int nReturnVal = -1;
+    int nReturnVal = MS_FAILURE;
     char szPath[MS_MAXPATHLEN];
     struct mstimeval starttime, endtime;
-    if(map && map->debug >= MS_DEBUGLEVEL_TUNING)
+    if(map && map->debug >= MS_DEBUGLEVEL_TUNING) {
         msGettimeofday(&starttime, NULL);
     if (img)
@@ -753,33 +754,38 @@
 #endif
        if (MS_RENDERER_PLUGIN(img->format)) {
             rendererVTableObj *renderer = img->format->vtable;
-            FILE *stream;
-            int ret;
+            FILE *stream = NULL;
             if(filename) {
                if(map)
                   stream = fopen(msBuildPath(szPath, map->mappath, filename),"wb");
                else
                   stream = fopen(filename,"wb");
+               if(!stream) {
+                  msSetError(MS_IOERR,
+                             "Failed to create output file (%s).",
+                             "msSaveImage()", (map?szPath:filename) );
+                  return MS_FAILURE;
             } else {
                 if ( msIO_needBinaryStdout() == MS_FAILURE )
                     return MS_FAILURE;
                 stream = stdout;
-            if(!stream)
-                return MS_FAILURE;
-            if(renderer->supports_pixel_buffer) {
+           if(renderer->supports_pixel_buffer) {
                 rasterBufferObj data;
                 if(renderer->getRasterBufferHandle(img,&data) != MS_SUCCESS)
                    return MS_FAILURE;
-                ret = msSaveRasterBuffer(&data,stream,img->format );
+                nReturnVal = msSaveRasterBuffer(&data,stream,img->format );
             } else {
-                ret = renderer->saveImage(img, stream, img->format);
+                nReturnVal = renderer->saveImage(img, stream, img->format);
             if( stream != stdout )
                 fclose(stream);
-            return ret;
         else if( MS_DRIVER_IMAGEMAP(img->format) )
             nReturnVal = msSaveImageIM(img, filename, img->format);
@@ -790,7 +796,8 @@
       msGettimeofday(&endtime, NULL);
-      msDebug("msSaveImage() total time: %.3fs\n",
+      msDebug("msSaveImage(%s) total time: %.3fs\n",
+              (filename ? filename : "stdout"),
               (endtime.tv_sec+endtime.tv_usec/1.0e6)-
               (starttime.tv_sec+starttime.tv_usec/1.0e6) );
