[mapserver-commits] r11463 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Apr 5 10:29:38 EDT 2011
Author: assefa
Date: 2011-04-05 07:29:38 -0700 (Tue, 05 Apr 2011)
New Revision: 11463
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapkmlrenderer.cpp
set layer's projection when it is not defined (#3809)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-05 14:08:53 UTC (rev 11462)
+++ trunk/mapserver/HISTORY.TXT 2011-04-05 14:29:38 UTC (rev 11463)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- KML: set layeer's projection when it is not defined (#3809)
- Updated xml mapfile schema and xsl with the new lexer properties (#3735)
- Updated PHP/MapScript for MS RFC 69: clustering. (#3700)
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2011-04-05 14:08:53 UTC (rev 11462)
+++ trunk/mapserver/mapkmlrenderer.cpp 2011-04-05 14:29:38 UTC (rev 11463)
@@ -222,7 +222,7 @@
return;
/*turn of labelcache*/
- layer->labelcache = MS_OFF;
+ //layer->labelcache = MS_OFF;
/*if there are labels we want the coordinates to
be the center of the element.*/
@@ -510,6 +510,28 @@
char epsg_string[100];
rectObj sRect;
projectionObj out;
+ /* for layer the do not have any projection set, set them with the current map
+ projection*/
+ if (projection && projection->numargs > 0)
+ layerObj *lp = NULL;
+ int i =0;
+ char *pszMapProjectString = msGetProjectionString(projection);
+ if (pszMapProjectString)
+ for(i=0; i<map->numlayers; i++)
+ lp = GET_LAYER(map, i);
+ if (lp->projection.numargs == 0 && lp->transform == MS_TRUE)
+ msFreeProjection(&lp->projection);
+ msLoadProjectionString(&lp->projection, pszMapProjectString);
+ msFree(pszMapProjectString);
strcpy(epsg_string, "epsg:4326" );
msInitProjection(&out);
msLoadProjectionString(&out, epsg_string);
More information about the mapserver-commits
