[mapserver-commits] r11475 - trunk/docs/en/mapfile
Wed Apr 6 06:39:21 EDT 2011
Author: havatv
Date: 2011-04-06 03:39:21 -0700 (Wed, 06 Apr 2011)
New Revision: 11475
   trunk/docs/en/mapfile/symbol.txt
Removed deprecated symbol level keywords from the symbol docs - #3797 and #3798.  Plus some other fixes.
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt	2011-04-06 10:17:42 UTC (rev 11474)
+++ trunk/docs/en/mapfile/symbol.txt	2011-04-06 10:39:21 UTC (rev 11475)
@@ -10,13 +10,13 @@
   This recommended setup is ideal for re-using symbol definitions across
   multiple MapServer applications.
 - There are 3 main types of symbols in MapServer: Markers,
-  Shadesets, and Lines.
+  Lines and Shadesets.
 - Symbol 0 is always the degenerate case for a particular class of
   symbol. For points, symbol 0 is a single pixel, for shading (i.e.
   filled polygons) symbol 0 is a solid fill, and for lines, symbol 0
   is a single pixel wide line.
 - Symbol definitions contain no color information, colors are set within
-  :ref:`CLASS` objects.
+  :ref:`STYLE` objects.
 - For MapServer versions < 5 there is a maximum of 64 symbols per file. This can
   be changed by editing mapsymbol.h and changing the value of MS_MAXSYMBOLS at the
   top of the file.  As of MapServer 5.0 there is no symbol limit.
@@ -37,7 +37,7 @@
 FILLED [true|false]
     Sets the symbol to be filled with a user defined color (See the
-    :ref:`CLASS` object). For marker symbols, if OUTLINECOLOR was specified
+    :ref:`STYLE` object). For marker symbols, if OUTLINECOLOR was specified
     then the symbol is outlined with it.
 FONT [string]
@@ -45,100 +45,80 @@
 GAP [int]
-    This keyword has been deprecated in version 6.0. It has been replaced by the
-    same keyword in the :ref:`STYLE`.
+    This keyword has been moved to :ref:`STYLE` in version 6.0.
-    Given in pixels. This defines a distance between symbols for
-    TrueType lines.  As of MapServer 5.0 this also applies to PixMap symbols.
-    When drawing the symbol along a line segment, a negative GAP will will add
-    180 degress to the angle. The TrueType and PixMap symbols are always oriented
-    along the line.  A GAP of 0 (the default value) will cause MapServer to use
-    the symbol as a brush to draw the line.
     .. deprecated:: 6.0
 IMAGE [string]
     Image (GIF or PNG) to use as a marker or brush for type PIXMAP symbols.
 NAME [string]
-    Alias for this font to be used in :ref:`CLASS` objects
+    Alias for the symbol.  To be used in :ref:`CLASS` :ref:`STYLE`
+    objects.
 LINECAP [butt|round|square|triangle]
-    Sets the line cap type for the cartoline symbol. Default is butt. Works
-    with the CARTOLINE symbol only!
     .. deprecated:: 6.0
 LINEJOIN [round|miter|bevel]
-    Sets the line join type for the cartoline symbol. Default is "none" -
-    lines will not be joined . Works with the CARTOLINE symbol only!
     .. deprecated:: 6.0
 LINEJOINMAXSIZE [int]
-    Sets the max length of the miter line join type. The value represents a
-    coefficient which multiplies a current symbol size. Default is 3.
-    Works with the CARTOLINE symbol only!
     .. deprecated:: 6.0
 PATTERN [num on] [num off] [num on] ... END
-    Defines a dash style or pattern.  Implemented in MapServer 5.0,
-    to replace the deprecated STYLE parameter.
-    .. versionadded: 5.0
     .. deprecated:: 6.0
 POINTS [x y] [x y] ... END
-    Signifies the start of the definition of points that make up a vector
-    symbol or that define the x and y radius of an ellipse symbol. The end
-    of this section is signified with the keyword END. Coordinates are given
-    in pixels and define the default size of the symbol before any scaling.
-    You can create non-contiguous paths by inserting negative coordinates at
-    the appropriate place. For ellipse symbols you provide a single point that
-    defines the x and y radius of an ellipse. Circles are created when x and
-    y are equal.
-.. note::
-    If a class using this symbol doesn't contain an explicit size, then the
-    default symbol size will be based on the range of "y" values in the point
-    coordinates. e.g. if the y coordinates of the points in the symbol range
-    from 0 to 5, then the default size for this symbol will be assumed to be 5.
+    Signifies the start of the definition of points that make up a
+    vector symbol or that define the x and y radius of an ellipse
+    symbol. The end of this section is signified with the keyword END.
+    The `x` and `y` values can be given using decimal numbers.  The
+    maximum `x` and `y` values define the bounding box of the symbol.
+    The size (actually height) of a symbol is defined in the
+    :ref:`STYLE`.  You can create non-contiguous paths by inserting
+    negative coordinates at the appropriate place.
-STYLE [num on] [num off] [num on] ... END -deprecated
-    Since MapServer 5.0 the proper parameter to use is PATTERN instead.
-    The deprecated STYLE parameter defines a dash style or pattern.
+    For ellipse symbols you provide a single point that defines the x
+    and y radius of an ellipse. Circles are created when `x` and `y`
+    are equal.
+    .. note::
+      If a :ref:`STYLE` using this symbol doesn't contain an explicit
+      size, then the default symbol size will be based on the range of
+      "y" values in the point coordinates. e.g. if the y coordinates
+      of the points in the symbol range from 0 to 5, then the default
+      size for this symbol will be assumed to be 5.
+STYLE [num on] [num off] [num on] ... END
+    Renamed to PATTERN in MapServer 5.0.
     .. deprecated:: 5.0
 TRANSPARENT [color index]
-    Sets a transparent color for the input GIF image for pixmap symbols, or
-    determines whether all shade symbols should have a transparent background.
-    For shade symbols it may be desirable to have background features
-    "show through" a transparent hatching pattern, creating a more complex map.
-    By default a symbol's background is the same as the parent image (i.e.
-    color 0). This is user configurable.
+    Sets a transparent color for the input image for pixmap symbols,
+    or determines whether all shade symbols should have a transparent
+    background.  For shade symbols it may be desirable to have
+    background features "show through" a transparent hatching pattern,
+    creating a more complex map.  By default a symbol's background is
+    the same as the parent image (i.e.  color 0). This is user
+    configurable.
-TYPE [vector|ellipse|pixmap|truetype|simple|cartoline|hatch]
-        *  `vector`: a simple drawing is used to define the shape of the symbol.
-        *  `ellipse`: radius values in the x and y directions define an ellipse.
-        *  `pixmap`: a user supplied GIF image will be used as the symbol.
-        *  `truetype`: TrueType font to use as defined in the FONTSET.
-        *  `cartoline`: allows for different designs of line ends (mitered, rounded,
-           beveled). More information can be found in the
-           :ref:`Cartographic Symbols document <sym_construction>`.
-        *  `hatch`: produces hatched lines throughout the shape.
+TYPE [ellipse|hatch|pixmap|simple|truetype|vector]
+    -  `ellipse`: radius values in the x and y directions define an ellipse.
+    -  `hatch`: produces hatched lines throughout the (polygon) shape.
+    -  `pixmap`: a user supplied image will be used as the symbol.
+    -  `simple`: default symbol type (1 pixel point, 1 pixel line, solid
+       fill).
+    -  `truetype`: TrueType font to use as defined in the :ref:`MAP`
+       :ref:`FONTSET`\.
+    -  `vector`: a vector drawing is used to define the shape of the symbol.
