[mapserver-commits] r11483 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Wed Apr 6 22:31:26 EDT 2011
Author: dmorissette
Date: 2011-04-06 19:31:26 -0700 (Wed, 06 Apr 2011)
New Revision: 11483
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/php/map.c
Fix setting of top-level mapObj member variables in PHP MapScript (#3815)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-06 22:26:42 UTC (rev 11482)
+++ trunk/mapserver/HISTORY.TXT 2011-04-07 02:31:26 UTC (rev 11483)
@@ -15,6 +15,10 @@
Current Version (SVN trunk):
+- Fix setting of top-level mapObj member variables in PHP MapScript (#3815)
+- More robust OpenGL context creation on older video cards and drivers (#3791)
- Allow users to set the maximum number of vector features to be drawn (#3739)
- Fixed FCGI on Windows problem related to lexer (#3812)
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c 2011-04-06 22:26:42 UTC (rev 11482)
+++ trunk/mapserver/mapscript/php/map.c 2011-04-07 02:31:26 UTC (rev 11483)
@@ -402,22 +402,22 @@
php_map = (php_map_object *) zend_object_store_get_object(zobj TSRMLS_CC);
- IF_GET_STRING("name", php_map->map->name)
- else IF_GET_LONG("status", php_map->map->status)
- else IF_GET_LONG("debug", php_map->map->debug)
- else IF_GET_LONG("width", php_map->map->width)
- else IF_GET_LONG("height", php_map->map->height)
- else IF_GET_LONG("maxsize", php_map->map->maxsize)
- else IF_GET_DOUBLE("resolution", php_map->map->resolution)
- else IF_GET_DOUBLE("defresolution", php_map->map->defresolution)
- else IF_GET_DOUBLE("cellsize", php_map->map->cellsize)
- else IF_GET_LONG("units", php_map->map->units)
- else IF_GET_DOUBLE("scaledenom", php_map->map->scaledenom)
- else IF_GET_STRING("shapepath", php_map->map->shapepath)
- else IF_GET_LONG("keysizex", php_map->map->legend.keysizex)
- else IF_GET_LONG("keysizey", php_map->map->legend.keysizey)
- else IF_GET_LONG("keyspacingx", php_map->map->legend.keyspacingx)
- else IF_GET_LONG("keyspacingy", php_map->map->legend.keyspacingy)
+ IF_SET_STRING("name", php_map->map->name, value)
+ else IF_SET_LONG("status", php_map->map->status, value)
+ else IF_SET_LONG("debug", php_map->map->debug, value)
+ else IF_SET_LONG("width", php_map->map->width, value)
+ else IF_SET_LONG("height", php_map->map->height, value)
+ else IF_SET_LONG("maxsize", php_map->map->maxsize, value)
+ else IF_SET_DOUBLE("resolution", php_map->map->resolution, value)
+ else IF_SET_DOUBLE("defresolution", php_map->map->defresolution, value)
+ else IF_SET_DOUBLE("cellsize", php_map->map->cellsize, value)
+ else IF_SET_LONG("units", php_map->map->units, value)
+ else IF_SET_DOUBLE("scaledenom", php_map->map->scaledenom, value)
+ else IF_SET_STRING("shapepath", php_map->map->shapepath, value)
+ else IF_SET_LONG("keysizex", php_map->map->legend.keysizex, value)
+ else IF_SET_LONG("keysizey", php_map->map->legend.keysizey, value)
+ else IF_SET_LONG("keyspacingx", php_map->map->legend.keyspacingx, value)
+ else IF_SET_LONG("keyspacingy", php_map->map->legend.keyspacingy, value)
else if ( (STRING_EQUAL("outputformat", property)) ||
(STRING_EQUAL("extent", property)) ||
(STRING_EQUAL("web", property)) ||
More information about the mapserver-commits
