[mapserver-commits] r11511 - trunk/docs/en/input/vector
svn at osgeo.org
svn at osgeo.org
Fri Apr 8 17:16:28 EDT 2011
Author: jmckenna
Date: 2011-04-08 14:16:28 -0700 (Fri, 08 Apr 2011)
New Revision: 11511
trunk/docs/en/input/vector/kml.txt
add notes and examples for KMZ files
Modified: trunk/docs/en/input/vector/kml.txt
--- trunk/docs/en/input/vector/kml.txt 2011-04-08 20:57:46 UTC (rev 11510)
+++ trunk/docs/en/input/vector/kml.txt 2011-04-08 21:16:28 UTC (rev 11511)
@@ -4,30 +4,47 @@
KML - Keyhole Markup Language
+.. contents:: Table of Contents
+ :depth: 2
+ :backlinks: top
Keyhole Markup Language (KML) is an XML-based language for managing the
-display of 3D geospatial data.
+display of 3D geospatial data. KML is a standard maintained by the Open
+Geospatial Consoritum (OGC).
+Links to KML-Related Information
+- Google's `KML Reference <http://code.google.com/apis/kml/documentation/kmlreference.html>`__
+- OGC's `KML Specification <http://www.opengeospatial.org/standards/kml>`__
+- `KML Validator <http://feedvalidator.org/>`__
+- `KML Validator <http://www.kmlvalidator.com/home.htm>`__ (against OGC KML 2.2)
Data Access / Connection Method
-KML access is available through OGR. See the OGR `driver page`_
+KML access in MapServer is available through OGR. See the OGR `driver page`_
for specific driver information. Read support was initially added to
-GDAL/OGR version 1.5.0.
+GDAL/OGR version 1.5.0. A more complete KML reader was added to GDAL/OGR in version 1.8.0,
+through the `libKML driver <http://www.gdal.org/ogr/drv_libkml.html>`__ (including the
+ability to read multigeometry, and KMZ files).
.. _`driver page`: http://www.gdal.org/ogr/drv_kml.html
-The CONNECTION parameter must include the kml extension, and the DATA parameter
+The CONNECTION parameter must include the kml or kmz extension, and the DATA parameter
should be the name of the layer.
+.. code-block:: mapfile
- CONNECTIONTYPE ogr
- CONNECTION "myplaces.kml"
+ CONNECTIONTYPE OGR
+ CONNECTION "filename.kml"
DATA "layername"
+Example 1: Displaying a .KML file
-OGRINFO Examples
+OGRINFO
First you should make sure that your GDAL/OGR build contains the "KML" driver,
by using the '--formats' command:
@@ -87,12 +104,12 @@
Mapfile Example
LAYER
- NAME kml_places
+ NAME "kml_example"
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
@@ -114,4 +131,97 @@
POSITION AUTO
END
END
- END
\ No newline at end of file
+ END
+Example 2: Displaying a .KMZ file
+OGRINFO
+First you should make sure that your GDAL/OGR build contains the "LIBKML" driver,
+by using the '--formats' command:
+ >ogrinfo --formats
+ Loaded OGR Format Drivers:
+ -> "GML" (read/write)
+ -> "GPX" (read/write)
+ -> "LIBKML" (read/write)
+ -> "KML" (read/write)
+If you don't have the driver, you might want to try the `FWTools`_ or `MS4W`_
+packages, which include the driver. Or you can follow the
+`compiling notes <http://trac.osgeo.org/gdal/wiki/LibKML>`__ for
+libKML and GDAL/OGR.
+.. _`FWTools`: http://fwtools.maptools.org/
+.. _`MS4W`: http://www.maptools.org/ms4w/
+Once you have the LIBKML driver you are ready to try an ogrinfo command on your
+file to get a list of available layers:
+ >ogrinfo Lunenburg_Municipality.kmz
+ INFO: Open of `Lunenburg_Municipality.kmz'
+ using driver `LIBKML' successful.
+ 1: Lunenburg_Municipality
+Now use ogrinfo to get information on the structure of the layer:
+ >ogrinfo Lunenburg_Municipality.kmz Lunenburg_Municipality -summary
+ Layer name: Lunenburg_Municipality
+ Geometry: Unknown (any)
+ Feature Count: 1
+ Extent: (-64.946433, 44.133207) - (-64.230281, 44.735125)
+ Layer SRS WKT:
+ GEOGCS["WGS 84",
+ DATUM["WGS_1984",
+ SPHEROID["WGS 84",6378137,298.257223563,
+ AUTHORITY["EPSG","7030"]],
+ TOWGS84[0,0,0,0,0,0,0],
+ AUTHORITY["EPSG","6326"]],
+ PRIMEM["Greenwich",0,
+ AUTHORITY["EPSG","8901"]],
+ UNIT["degree",0.0174532925199433,
+ AUTHORITY["EPSG","9108"]],
+ AUTHORITY["EPSG","4326"]]
+ Name: String (0.0)
+ description: String (0.0)
+ timestamp: DateTime (0.0)
+ begin: DateTime (0.0)
+ end: DateTime (0.0)
+ altitudeMode: String (0.0)
+ tessellate: Integer (0.0)
+ extrude: Integer (0.0)
+ visibility: Integer (0.0)
+Mapfile Example
+ LAYER
+ NAME "lunenburg"
+ TYPE POLYGON
+ STATUS DEFAULT
+ CONNECTION "Lunenburg_Municipality.kmz"
+ DATA "Lunenburg_Municipality"
+ CLASS
+ NAME "Lunenburg"
+ STYLE
+ COLOR 244 244 16
+ OUTLINECOLOR 199 199 199
+ END
+ END
+ END # layer
More information about the mapserver-commits
