[mapserver-commits] r11516 - trunk/mapserver
    svn at osgeo.org
    svn at osgeo.org
    Mon Apr 11 05:25:36 EDT 2011
Author: tbonfort
Date: 2011-04-11 02:25:36 -0700 (Mon, 11 Apr 2011)
New Revision: 11516
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsymbol.c
add GAP, POSITION and CAPS/JOINS to mapfile writer (#3797)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-04-10 11:34:36 UTC (rev 11515)
+++ trunk/mapserver/HISTORY.TXT	2011-04-11 09:25:36 UTC (rev 11516)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- add GAP, POSITION and CAPS/JOINS to mapfile writer (#3797)
 - fix GEOMTRANSFORM rotation orientation for vector symbols (#3802)
 - GD Driver broken in FastCGI (#3813)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2011-04-10 11:34:36 UTC (rev 11515)
+++ trunk/mapserver/mapfile.c	2011-04-11 09:25:36 UTC (rev 11516)
@@ -2383,9 +2383,9 @@
   style->patternlength = 0; /* solid line */
   style->gap = 0;
   style->position = MS_CC;
-  style->linecap = MS_CJC_ROUND;
-  style->linejoin = MS_CJC_NONE;
-  style->linejoinmaxsize = 3;
+  style->linecap = MS_CJC_DEFAULT_CAPS;
+  style->linejoin = MS_CJC_DEFAULT_JOINS;
+  style->linejoinmaxsize = MS_CJC_DEFAULT_JOIN_MAXSIZE;
   style->numbindings = 0;
   for(i=0; i<MS_STYLE_BINDING_LENGTH; i++) {
@@ -2688,7 +2688,27 @@
   if(style->numbindings > 0 && style->bindings[MS_STYLE_BINDING_COLOR].item)
     writeAttributeBinding(stream, indent, "COLOR", &(style->bindings[MS_STYLE_BINDING_COLOR]));
   else writeColor(stream, indent, "COLOR", &(style->color));
+  writeNumber(stream, indent, "GAP", 0, style->gap);
+  if(style->linecap != MS_CJC_DEFAULT_CAPS) {
+     writeKeyword(stream,indent,"LINECAP",(int)style->linecap,5,
+           MS_CJC_NONE,"NONE",
+           MS_CJC_ROUND, "ROUND",
+           MS_CJC_SQUARE, "SQUARE",
+           MS_CJC_BUTT, "BUTT",
+           MS_CJC_TRIANGLE, "TRIANGLE");
+  if(style->linejoin != MS_CJC_DEFAULT_JOINS) {
+     writeKeyword(stream,indent,"LINEJOIN",(int)style->linejoin,5,
+           MS_CJC_BEVEL, "BEVEL",
+           MS_CJC_MITER, "MITER");
+  writeNumber(stream, indent, "LINEJOINMAXSIZE", MS_CJC_DEFAULT_JOIN_MAXSIZE , style->linejoinmaxsize);
   writeNumber(stream, indent, "MAXSCALEDENOM", -1, style->maxscaledenom);
   writeNumber(stream, indent, "MAXSIZE", MS_MAXSYMBOLSIZE, style->maxsize);
   writeNumber(stream, indent, "MAXWIDTH", MS_MAXSYMBOLWIDTH, style->maxwidth);
@@ -2721,6 +2741,13 @@
      indent--;
+  if(style->position != MS_CC) {
+    writeKeyword(stream, indent, "POSITION", style->position, 9,
+          MS_UL, "UL", MS_UC, "UC", MS_UR, "UR", MS_CL, "CL",
+          MS_CC, "CC", MS_CR, "CR", MS_LL, "LL", MS_LC, "LC",
+          MS_LR, "LR");
   if(style->numbindings > 0 && style->bindings[MS_STYLE_BINDING_SIZE].item)
     writeAttributeBinding(stream, indent, "SIZE", &(style->bindings[MS_STYLE_BINDING_SIZE]));
   else writeNumber(stream, indent, "SIZE", -1, style->size);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-04-10 11:34:36 UTC (rev 11515)
+++ trunk/mapserver/mapserver.h	2011-04-11 09:25:36 UTC (rev 11516)
@@ -454,6 +454,11 @@
 enum MS_ALIGN_VALUE {MS_ALIGN_LEFT, MS_ALIGN_CENTER, MS_ALIGN_RIGHT};
 enum MS_CAPS_JOINS_AND_CORNERS {MS_CJC_NONE, MS_CJC_BEVEL, MS_CJC_BUTT, MS_CJC_MITER, MS_CJC_ROUND, MS_CJC_SQUARE, MS_CJC_TRIANGLE};
+#define MS_CJC_DEFAULT_CAPS MS_CJC_ROUND
+#define MS_CJC_DEFAULT_JOINS MS_CJC_NONE
+#define MS_CJC_DEFAULT_JOIN_MAXSIZE 3
 enum MS_RETURN_VALUE {MS_SUCCESS, MS_FAILURE, MS_DONE};
 enum MS_IMAGEMODE { MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB, MS_IMAGEMODE_RGBA, MS_IMAGEMODE_INT16, MS_IMAGEMODE_FLOAT32, MS_IMAGEMODE_BYTE, MS_IMAGEMODE_FEATURE, MS_IMAGEMODE_NULL };
Modified: trunk/mapserver/mapsymbol.c
--- trunk/mapserver/mapsymbol.c	2011-04-10 11:34:36 UTC (rev 11515)
+++ trunk/mapserver/mapsymbol.c	2011-04-11 09:25:36 UTC (rev 11516)
@@ -47,12 +47,6 @@
 static const unsigned char PNGsig[8] = {137, 80, 78, 71, 13, 10, 26, 10}; /* 89 50 4E 47 0D 0A 1A 0A hex */
 static const unsigned char JPEGsig[3] = {255, 216, 255}; /* FF D8 FF hex */
-** Symbol to string static arrays needed for writing map files.
-** Must be kept in sync with enumerations and defines found in mapserver.h.
-extern char *msPositionsText[]; /* Defined in mapfile.c */
-static char *msCapsJoinsCorners[7]={"NONE", "BEVEL", "BUTT", "MITER", "ROUND", "SQUARE", "TRIANGLE"};
 void freeImageCache(struct imageCacheObj *ic)
More information about the mapserver-commits
