[mapserver-commits] r11520 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Apr 11 06:37:43 EDT 2011
Author: tbonfort
Date: 2011-04-11 03:37:42 -0700 (Mon, 11 Apr 2011)
New Revision: 11520
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maprendering.c
use supplied offset for brushed lines (#3825, #3792)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-11 10:29:22 UTC (rev 11519)
+++ trunk/mapserver/HISTORY.TXT 2011-04-11 10:37:42 UTC (rev 11520)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- use supplied offset for brushed lines (#3825, #3792)
- fix division by 0 error in bar charts for some ill-defined cases (#3218)
- add GAP, POSITION and CAPS/JOINS to mapfile writer (#3797)
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c 2011-04-11 10:29:22 UTC (rev 11519)
+++ trunk/mapserver/maprendering.c 2011-04-11 10:37:42 UTC (rev 11520)
@@ -492,7 +492,7 @@
if(pw<1) pw=1;
if(ph<1) ph=1;
tile = getTile(image, symbol,&s,pw,ph,0);
- renderer->renderLineTiled(image, p, tile);
+ renderer->renderLineTiled(image, offsetLine, tile);
} else {
msSetError(MS_RENDERERERR, "renderer does not support brushed lines", "msDrawLineSymbol()");
return MS_FAILURE;
More information about the mapserver-commits
