[mapserver-commits] r11558 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Apr 13 12:43:21 EDT 2011
Author: tbonfort
Date: 2011-04-13 09:43:21 -0700 (Wed, 13 Apr 2011)
New Revision: 11558
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapdraw.c
clean up the symbolset if we've used an alternate renderer for a layer (#3834,#3616)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-13 15:56:55 UTC (rev 11557)
+++ trunk/mapserver/HISTORY.TXT 2011-04-13 16:43:21 UTC (rev 11558)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- clean up the symbolset if we've used an alternate renderer for a layer (#3834,#3616)
- fix crash on embeded legend with cairo raster renderer
- fix crashes in SVG renderer on polygon symbol fills (#3837)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2011-04-13 15:56:55 UTC (rev 11557)
+++ trunk/mapserver/mapdraw.c 2011-04-13 16:43:21 UTC (rev 11558)
@@ -733,14 +733,34 @@
rendererVTableObj *renderer = MS_IMAGE_RENDERER(image);
rendererVTableObj *altrenderer = MS_IMAGE_RENDERER(image_draw);
rasterBufferObj rb;
+ int i;
memset(&rb,0,sizeof(rasterBufferObj));
altrenderer->endLayer(image_draw,map,layer);
altrenderer->getRasterBufferHandle(image_draw,&rb);
renderer->mergeRasterBuffer(image,&rb,layer->opacity*0.01,0,0,0,0,rb.width,rb.height);
+ * hack to work around bug #3834: if we have use an alternate renderer, the symbolset may contain
+ * symbols that reference it. We want to remove those references before the altFormat is destroyed
+ * to avoid a segfault and/or a leak, and so the the main renderer doesn't pick the cache up thinking
+ * it's for him.
+ for(i=0; i<map->symbolset.numsymbols; i++) {
+ if (map->symbolset.symbol[i]!=NULL) {
+ symbolObj *s = map->symbolset.symbol[i];
+ if(s->renderer == altrenderer) {
+ altrenderer->freeSymbol(s);
+ s->renderer = NULL;
msFreeImage(image_draw);
+ /* set the imagetype from the original outputformat back (it was removed by msSelectOutputFormat() */
+ msFree(map->imagetype);
+ map->imagetype = msStrdup(image->format->name);
else if( image != image_draw) {
rendererVTableObj *renderer = MS_IMAGE_RENDERER(image_draw);
More information about the mapserver-commits
