[mapserver-commits] r11566 - trunk/mapserver
Wed Apr 13 16:39:03 EDT 2011
Author: assefa
Date: 2011-04-13 13:39:03 -0700 (Wed, 13 Apr 2011)
New Revision: 11566
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcsld.c
use pixmap size when parameter size is not specified (#2305)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-04-13 19:35:38 UTC (rev 11565)
+++ trunk/mapserver/HISTORY.TXT	2011-04-13 20:39:03 UTC (rev 11566)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- SLD: use pixmap size when parameter size is not specified (#2305)
 - fix memory leaks in mapgraticule.c (#3831)
 - fix runtime sub validation against web metadata, was using wrong lookup key
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2011-04-13 19:35:38 UTC (rev 11565)
+++ trunk/mapserver/mapogcsld.c	2011-04-13 20:39:03 UTC (rev 11566)
@@ -1600,8 +1600,13 @@
             psSize = CPLGetXMLNode(psGraphic, "Size");
             if (psSize && psSize->psChild && psSize->psChild->pszValue)
               psStyle->size = atof(psSize->psChild->pszValue);
-            else
-              psStyle->size = 6; /* default value */
+            else
+                /*do not set a default for external symbols #2305*/
+                psExternalGraphic =  CPLGetXMLNode(psGraphic, "ExternalGraphic");
+                if (!psExternalGraphic)
+                  psStyle->size = 6; /* default value */
             /*SLD 1.1.0 extract opacity, rotation, displacement*/
             psOpacity = CPLGetXMLNode(psGraphic, "Opacity");
@@ -2194,57 +2199,23 @@
                 if (psTmp && psTmp->psChild)
                     pszURL = (char*)psTmp->psChild->pszValue;
-                    /* pf at mapmedia.de:
-                       check if this external graphic is allready in Symbollist;
-                       avoids unnecessary http requests;
-                       this works only if we use the url as symbol->name hashkey!
+                    /*external symbols using http will be automaticallly downloaded. The file should be
+                      saved in a temporary directory (msAddImageSymbol) #2305*/
                     psStyle->symbol = msGetSymbolIndex(&map->symbolset,
                                                        pszURL,
-                                                       MS_FALSE);
-                    if (psStyle->symbol <= 0)
-                        if (strcasecmp(pszFormat, "GIF") == 0 ||
-                            strcasecmp(pszFormat, "image/gif") == 0)
-                          pszTmpSymbolName = msTmpFile(map, map->mappath, NULL, "gif");
-                        else
-                            pszTmpSymbolName = msTmpFile(map, map->mappath, NULL, "png");
+                                                       MS_TRUE);
+                    if (psStyle->symbol > 0 && psStyle->symbol < map->symbolset.numsymbols)
+                      psStyle->symbolname = msStrdup(map->symbolset.symbol[psStyle->symbol]->name);
-                        if (msHTTPGetFile(pszURL, pszTmpSymbolName, &status,-1, 0, 0) == MS_SUCCESS)
-                            /* the last parameter is used to set the GAP size in the symbol.
-                               It is harcoded to be 2 * the size set for the symbol. This is
-                               used when using graphic strokes with line symblizers (symbols
-                               along the line). Set to be negative for rotation purpose. */
-                            psStyle->symbol = msSLDGetGraphicSymbol(map, pszTmpSymbolName, pszURL,
-        (int)(-(2 * psStyle->size)));
-                            if (psStyle->symbol > 0 && psStyle->symbol < map->symbolset.numsymbols)
-                              psStyle->symbolname = msStrdup(map->symbolset.symbol[psStyle->symbol]->name);
-                            /* set the color parameter if not set. Does not make sense */
-                            /* for pixmap but mapserver needs it. */
-                            if (psStyle->color.red == -1 || psStyle->color.green || psStyle->color.blue)
-                                psStyle->color.red = 0;
-                                psStyle->color.green = 0;
-                                psStyle->color.blue = 0;
-                    else
+                    /* set the color parameter if not set. Does not make sense */
+                    /* for pixmap but mapserver needs it. */
+                    if (psStyle->color.red == -1 || psStyle->color.green || psStyle->color.blue)
+                        psStyle->color.red = 0;
+                        psStyle->color.green = 0;
+                        psStyle->color.blue = 0;
