[mapserver-commits] r11585 - trunk/docs/en/mapfile
Fri Apr 15 09:33:40 EDT 2011
Author: tbonfort
Date: 2011-04-15 06:33:40 -0700 (Fri, 15 Apr 2011)
New Revision: 11585
   trunk/docs/en/mapfile/label.txt
add note about renderers supproting bitmap fonts
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt	2011-04-15 13:05:40 UTC (rev 11584)
+++ trunk/docs/en/mapfile/label.txt	2011-04-15 13:33:40 UTC (rev 11585)
@@ -280,6 +280,8 @@
     Type of font to use. Generally bitmap fonts are faster to draw then
     TrueType fonts. However, TrueType fonts are scalable and available in a
     variety of faces. Be sure to set the FONT parameter if you select TrueType.
+    Note that bitmap fonts are only supported with the AGG and GD renderers.
 .. _WRAP:
