[mapserver-commits] r11587 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Apr 15 10:49:16 EDT 2011
Author: dmorissette
Date: 2011-04-15 07:49:16 -0700 (Fri, 15 Apr 2011)
New Revision: 11587
trunk/mapserver/HISTORY.TXT
trunk/mapserver/configure
trunk/mapserver/configure.in
Fix configure output for 'WFS Client' (was reporting WMS info, #3842)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-15 14:32:09 UTC (rev 11586)
+++ trunk/mapserver/HISTORY.TXT 2011-04-15 14:49:16 UTC (rev 11587)
@@ -15,8 +15,11 @@
Current Version (SVN trunk):
-- KML: latlon bbox for raster layers could end up being wrong for non-square requests (#3840)
+- Fix configure output for "WFS Client" (was reporting WMS info, #3842)
+- KML: latlon bbox for raster layers could end up being wrong for non-square
+ requests (#3840)
Version 6.0.0-beta6 (2011-04-13)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2011-04-15 14:32:09 UTC (rev 11586)
+++ trunk/mapserver/configure 2011-04-15 14:49:16 UTC (rev 11587)
@@ -9808,6 +9808,7 @@
fi
test -f $FTGL_DIR/lib/libftgl.so && FTGL_LIBDIR="$FTGL_DIR/lib"
+ test -f $FTGL_DIR/lib/libftgl.dylib && FTGL_LIBDIR="$FTGL_DIR/lib"
test -f $FTGL_DIR/lib64/libftgl.so && FTGL_LIBDIR="$FTGL_DIR/lib64"
if test -z "$FTGL_LIBDIR" ; then
@@ -9908,6 +9909,7 @@
fi
test -f $OGL_DIR/lib/libGL.so -a -f $OGL_DIR/lib/libGLU.so && OGL_LIBDIR="$OGL_DIR/lib"
+ test -f $OGL_DIR/lib/libGL.dylib -a -f $OGL_DIR/lib/libGLU.dylib && OGL_LIBDIR="$OGL_DIR/lib"
test -f $OGL_DIR/lib64/libGL.so -a -f $OGL_DIR/lib64/libGLU.so && OGL_LIBDIR="$OGL_DIR/lib64"
if test -z "$OGL_LIBDIR" ; then
@@ -15368,8 +15370,8 @@
echo "${ECHO_T} WMS Client: ${WMS_LYR_ENABLED}" >&6
echo "$as_me:$LINENO: result: WFS Server: ${WFS_SVR_ENABLED}" >&5
echo "${ECHO_T} WFS Server: ${WFS_SVR_ENABLED}" >&6
-echo "$as_me:$LINENO: result: WFS Client: ${WMS_LYR_ENABLED}" >&5
-echo "${ECHO_T} WFS Client: ${WMS_LYR_ENABLED}" >&6
+echo "$as_me:$LINENO: result: WFS Client: ${WFS_LYR_ENABLED}" >&5
+echo "${ECHO_T} WFS Client: ${WFS_LYR_ENABLED}" >&6
echo "$as_me:$LINENO: result: WCS Server: ${WCS_SVR_ENABLED}" >&5
echo "${ECHO_T} WCS Server: ${WCS_SVR_ENABLED}" >&6
echo "$as_me:$LINENO: result: SOS Server: ${SOS_SVR_ENABLED}" >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2011-04-15 14:32:09 UTC (rev 11586)
+++ trunk/mapserver/configure.in 2011-04-15 14:49:16 UTC (rev 11587)
@@ -2885,7 +2885,7 @@
AC_MSG_RESULT([ WMS Server: ${WMS_SVR_ENABLED}])
AC_MSG_RESULT([ WMS Client: ${WMS_LYR_ENABLED}])
AC_MSG_RESULT([ WFS Server: ${WFS_SVR_ENABLED}])
-AC_MSG_RESULT([ WFS Client: ${WMS_LYR_ENABLED}])
+AC_MSG_RESULT([ WFS Client: ${WFS_LYR_ENABLED}])
AC_MSG_RESULT([ WCS Server: ${WCS_SVR_ENABLED}])
AC_MSG_RESULT([ SOS Server: ${SOS_SVR_ENABLED}])
AC_MSG_RESULT()
More information about the mapserver-commits
