[mapserver-commits] r11614 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Apr 21 06:11:40 EDT 2011
Author: tbonfort
Date: 2011-04-21 03:11:39 -0700 (Thu, 21 Apr 2011)
New Revision: 11614
trunk/mapserver/mapagg.cpp
only apply caps and joins if line width is more than 1 pixel.
add (ifdef'd out for 6.0) aliased rendering for agg lines.
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp 2011-04-21 07:30:11 UTC (rev 11613)
+++ trunk/mapserver/mapagg.cpp 2011-04-21 10:11:39 UTC (rev 11614)
@@ -66,6 +66,11 @@
#include "renderers/agg/include/agg_conv_clipper.h"
+#ifdef AGG_ALIASED_ENABLED
+#include "renderers/agg/include/agg_renderer_primitives.h"
+#include "renderers/agg/include/agg_rasterizer_outline.h"
+#endif
#ifdef CPL_MSB
typedef mapserver::order_argb band_order;
#else
@@ -88,6 +93,10 @@
typedef mapserver::font_cache_manager<font_engine_type> font_manager_type;
typedef mapserver::conv_curve<font_manager_type::path_adaptor_type> font_curve_type;
+typedef mapserver::renderer_primitives<renderer_base> renderer_primitives;
+typedef mapserver::rasterizer_outline<renderer_primitives> rasterizer_outline;
+#endif
static color_type AGG_NO_COLOR = color_type(0, 0, 0, 0);
const mapserver::int8u* rasterfonts[]= {
@@ -118,14 +127,23 @@
class AGG2Renderer {
public:
- AGG2Renderer(){
+ AGG2Renderer()
+ m_renderer_primitives(m_renderer_base),
+ m_rasterizer_primitives(m_renderer_primitives)
+#endif
band_type* buffer;
rendering_buffer m_rendering_buffer;
pixel_format m_pixel_format;
renderer_base m_renderer_base;
renderer_scanline m_renderer_scanline;
+ renderer_primitives m_renderer_primitives;
+ rasterizer_outline m_rasterizer_primitives;
+#endif
rasterizer_scanline m_rasterizer_aa;
mapserver::scanline_p8 sl_poly; /*packed scanlines, works faster when the area is larger
than the perimeter, in number of pixels*/
@@ -169,6 +187,14 @@
AGG2Renderer *r = AGG_RENDERER(img);
line_adaptor lines = line_adaptor(p);
+ r->m_rasterizer_primitives.reset();
+ r->m_renderer_primitives.line_color(aggColor(style->color));
+ r->m_rasterizer_primitives.add_path(lines);
+ return MS_SUCCESS;
+#endif
r->m_rasterizer_aa.reset();
r->m_rasterizer_aa.filling_rule(mapserver::fill_non_zero);
r->m_renderer_scanline.color(aggColor(style->color));
@@ -176,7 +202,8 @@
if (style->patternlength <= 0) {
mapserver::conv_stroke<line_adaptor> stroke(lines);
stroke.width(style->width);
- applyCJC(stroke, style->linecap, style->linejoin);
+ if(style->width>1)
+ applyCJC(stroke, style->linecap, style->linejoin);
r->m_rasterizer_aa.add_path(stroke);
} else {
mapserver::conv_dash<line_adaptor> dash(lines);
@@ -190,7 +217,8 @@
stroke_dash.width(style->width);
- applyCJC(stroke_dash, style->linecap, style->linejoin);
+ applyCJC(stroke_dash, style->linecap, style->linejoin);
r->m_rasterizer_aa.add_path(stroke_dash);
mapserver::render_scanlines(r->m_rasterizer_aa, r->sl_line, r->m_renderer_scanline);
More information about the mapserver-commits
