[mapserver-commits] r11619 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Wed Apr 27 11:23:07 EDT 2011
Author: aboudreault
Date: 2011-04-27 08:23:07 -0700 (Wed, 27 Apr 2011)
New Revision: 11619
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/php/class.c
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/map.c
trunk/mapserver/mapscript/php/php_mapscript.h
trunk/mapserver/mapscript/php/php_mapscript_util.h
trunk/mapserver/mapscript/php/point.c
trunk/mapserver/mapscript/php/style.c
Fixed a system specific segmentation fault in PHP/MapScript and improved the php object method calls (#3730)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/HISTORY.TXT 2011-04-27 15:23:07 UTC (rev 11619)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Fixed segmentation fault in PHP/MapScript and improved the php object method calls (#3730)
- Fix build issue related to unnecessary use of gdal-config --dep-libs (#3316)
Version 6.0.0-beta7 (2011-04-20)
Modified: trunk/mapserver/mapscript/php/class.c
--- trunk/mapserver/mapscript/php/class.c 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/class.c 2011-04-27 15:23:07 UTC (rev 11619)
@@ -498,9 +498,7 @@
zval *zname;
zval *zobj = getThis();
php_class_object *php_class;
- zval retval;
- zval *args[1];
- zval function_name;
+ zval *retval;
PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "z",
@@ -513,10 +511,9 @@
php_class = (php_class_object *) zend_object_store_get_object(zobj TSRMLS_CC);
CHECK_OBJECT(mapscript_ce_hashtable, php_class->metadata, &php_class->class->metadata);
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_class->metadata, "get", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_class->metadata, "get", retval, zname);
- RETURN_STRING(Z_STRVAL(retval),1);
+ RETURN_STRING(Z_STRVAL_P(retval),1);
@@ -527,9 +524,7 @@
zval *zname, *zvalue;
- zval retval;
- zval *args[2];
+ zval *retval;
if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "zz",
@@ -542,11 +537,9 @@
- args[0] = zname;
- args[1] = zvalue;
- MAPSCRIPT_CALL_METHOD(php_class->metadata, "set", retval, 2, args);
+ MAPSCRIPT_CALL_METHOD_2(php_class->metadata, "set", retval, zname, zvalue);
- RETURN_LONG(Z_LVAL(retval));
+ RETURN_LONG(Z_LVAL_P(retval));
@@ -557,9 +550,7 @@
zval *zname;
- zval retval;
- zval *args[1];
+ zval *retval;
@@ -572,10 +563,9 @@
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_class->metadata, "remove", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_class->metadata, "remove", retval, zname);
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/layer.c 2011-04-27 15:23:07 UTC (rev 11619)
@@ -1167,9 +1167,7 @@
zval *zname;
php_layer_object *php_layer;
- zval retval;
- zval *args[1];
+ zval *retval;
@@ -1182,10 +1180,9 @@
php_layer = (php_layer_object *) zend_object_store_get_object(zobj TSRMLS_CC);
CHECK_OBJECT(mapscript_ce_hashtable, php_layer->metadata, &php_layer->layer->metadata);
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_layer->metadata, "get", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_layer->metadata, "get", retval, zname);
@@ -1196,9 +1193,7 @@
- zval retval;
- zval *args[2];
+ zval *retval;
@@ -1211,11 +1206,9 @@
- args[0] = zname;
- args[1] = zvalue;
- MAPSCRIPT_CALL_METHOD(php_layer->metadata, "set", retval, 2, args);
+ MAPSCRIPT_CALL_METHOD_2(php_layer->metadata, "set", retval, zname, zvalue);
@@ -1226,9 +1219,7 @@
zval *zname;
- zval retval;
- zval *args[1];
+ zval *retval;
@@ -1241,10 +1232,9 @@
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_layer->metadata, "remove", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_layer->metadata, "remove", retval, zname);
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/map.c 2011-04-27 15:23:07 UTC (rev 11619)
@@ -2191,9 +2191,7 @@
zval *zname;
php_map_object *php_map;
- zval retval;
- zval *args[1];
+ zval *retval;
@@ -2206,10 +2204,9 @@
php_map = (php_map_object *) zend_object_store_get_object(zobj TSRMLS_CC);
CHECK_OBJECT(mapscript_ce_hashtable, php_map->metadata, &php_map->map->web.metadata);
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_map->metadata, "get", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_map->metadata, "get", retval, zname);
@@ -2220,9 +2217,7 @@
- zval retval;
- zval *args[2];
+ zval *retval;
@@ -2235,11 +2230,9 @@
- args[0] = zname;
- args[1] = zvalue;
- MAPSCRIPT_CALL_METHOD(php_map->metadata, "set", retval, 2, args);
+ MAPSCRIPT_CALL_METHOD_2(php_map->metadata, "set", retval, zname, zvalue);
@@ -2250,9 +2243,7 @@
zval *zname;
- zval retval;
- zval *args[1];
+ zval *retval;
@@ -2265,10 +2256,9 @@
- args[0] = zname;
- MAPSCRIPT_CALL_METHOD(php_map->metadata, "remove", retval, 1, args);
+ MAPSCRIPT_CALL_METHOD_1(php_map->metadata, "remove", retval, zname);
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/php_mapscript.h 2011-04-27 15:23:07 UTC (rev 11619)
@@ -33,6 +33,7 @@
#define PHP_MAPSCRIPT_H
#include "php.h"
+#include "zend_interfaces.h"
#include "php_mapscript_util.h"
#ifdef USE_PHP_REGEX
Modified: trunk/mapserver/mapscript/php/php_mapscript_util.h
--- trunk/mapserver/mapscript/php/php_mapscript_util.h 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/php_mapscript_util.h 2011-04-27 15:23:07 UTC (rev 11619)
@@ -90,10 +90,12 @@
parent.val = zobj; \
parent.child_ptr = ptr;
-#define MAPSCRIPT_CALL_METHOD(zobj, function, retval, param_count, args) \
- ZVAL_STRING(&function_name, function, 0); \
- call_user_function(EG(function_table), &zobj, &function_name, &retval, param_count, args TSRMLS_CC);
+#define MAPSCRIPT_CALL_METHOD_1(zobj, function_name, retval, arg1) \
+ zend_call_method_with_1_params(&zobj, Z_OBJCE_P(zobj), NULL, function_name, &retval, arg1);
+#define MAPSCRIPT_CALL_METHOD_2(zobj, function_name, retval, arg1, arg2) \
+ zend_call_method_with_2_params(&zobj, Z_OBJCE_P(zobj), NULL, function_name, &retval, arg1, arg2);
#define STRING_EQUAL(string1, string2) \
strcmp(string1, string2) == 0
Modified: trunk/mapserver/mapscript/php/point.c
--- trunk/mapserver/mapscript/php/point.c 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/point.c 2011-04-27 15:23:07 UTC (rev 11619)
@@ -175,15 +175,12 @@
Set new point. Returns MS_FAILURE on error. */
PHP_METHOD(pointObj, setXY)
- zval *x, *y, *m = NULL;
+ double x, y, m;
- zval retval;
- zval *args[2];
- zval property_name, function_name;
php_point_object *php_point;
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "zz|z",
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "dd|d",
&x, &y, &m) == FAILURE) {
PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
return;
@@ -192,23 +189,13 @@
php_point = (php_point_object *) zend_object_store_get_object(zobj TSRMLS_CC);
- ZVAL_STRING(&property_name, "x", 0);
- args[0] = &property_name;
- args[1] = x;
- MAPSCRIPT_CALL_METHOD(zobj, "__set", retval, 2, args);
- ZVAL_STRING(&property_name, "y", 0);
- args[1] = y;
+ php_point->point->x = x;
+ php_point->point->y = y;
#ifdef USE_POINT_Z_M
- if (m)
+ if (ZEND_NUM_ARGS() == 3)
- ZVAL_STRING(&property_name, "m", 0);
- args[1] = m;
+ php_point->point->m = m;
#endif
@@ -221,15 +208,12 @@
PHP_METHOD(pointObj, setXYZ)
- zval *x, *y, *z, *m = NULL;
+ double x, y, z, m;
- zval retval;
- zval *args[2];
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "zzz|z",
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "ddd|d",
&x, &y, &z, &m) == FAILURE) {
return;
@@ -238,28 +222,15 @@
- args[1] = x;
- args[1] = y;
- ZVAL_STRING(&property_name, "z", 0);
- args[1] = z;
+ php_point->point->z = z;
- if (m)
+ if (ZEND_NUM_ARGS() == 4)
- args[1] = m;
#endif
Modified: trunk/mapserver/mapscript/php/style.c
--- trunk/mapserver/mapscript/php/style.c 2011-04-27 15:06:17 UTC (rev 11618)
+++ trunk/mapserver/mapscript/php/style.c 2011-04-27 15:23:07 UTC (rev 11619)
@@ -249,9 +249,8 @@
char *snippet;
long snippet_len;
int status = MS_FAILURE;
- zval retval;
- zval *args[2];
+ zval *retval;
+ zval property_name, value;
php_style_object *php_style;
@@ -270,21 +269,17 @@
return;
- ZVAL_LONG(&retval, status);
/* verify the symbol if needed */
if (php_style->style->symbolname)
- MAKE_STD_ZVAL(args[0]);
- MAKE_STD_ZVAL(args[1]);
- ZVAL_STRING(args[0], "symbolname", 1);
- ZVAL_STRING(args[1], php_style->style->symbolname, 1);
- zval_ptr_dtor(&args[0]);
- zval_ptr_dtor(&args[1]);
+ INIT_ZVAL(property_name);
+ INIT_ZVAL(value);
+ ZVAL_STRING(&property_name, "symbolname", 1);
+ ZVAL_STRING(&value, php_style->style->symbolname, 1);
+ MAPSCRIPT_CALL_METHOD_2(zobj, "__set", retval, &property_name, &value);
+ RETURN_LONG(status);
More information about the mapserver-commits
