[mapserver-commits] r11986 - branches/branch-6-0/docs/en/mapscript trunk/docs/en/mapscript
Wed Aug 3 17:34:11 EDT 2011
Author: havatv
Date: 2011-08-03 14:34:11 -0700 (Wed, 03 Aug 2011)
New Revision: 11986
   branches/branch-6-0/docs/en/mapscript/mapscript.txt
   trunk/docs/en/mapscript/mapscript.txt
Changed scale to scaledenom in mapscript document (#3958).  Changed min and max in explanation accordingly. Also adjusted with line breaks before column 80.
Modified: branches/branch-6-0/docs/en/mapscript/mapscript.txt
--- branches/branch-6-0/docs/en/mapscript/mapscript.txt	2011-08-03 21:03:17 UTC (rev 11985)
+++ branches/branch-6-0/docs/en/mapscript/mapscript.txt	2011-08-03 21:34:11 UTC (rev 11986)
@@ -198,14 +198,14 @@
 layer : layerObj_ immutable
     Reference to the parent layer
-maxscale : float
-    The maximum scale at which class is drawn
+maxscaledenom : float
+    The minimum scale at which class is drawn
 metadata : hashTableObj_ immutable
     class metadata hash table.
-minscale : float
-    The minimum scale at which class is drawn
+minscaledenom : float
+    The maximum scale at which class is drawn
     Unique within a layer
@@ -470,9 +470,10 @@
 size : int immutable
     To access this attribute use the getSize method.
-.. note:: the getSize method is inefficient as it does a call to getBytes and then computes
-   the size of the byte array. The bytearray is then immediately discarded. In most
-   cases it is more efficient to call getBytes directly.
+.. note:: the getSize method is inefficient as it does a call to
+   getBytes and then computes the size of the byte array. The
+   bytearray is then immediately discarded. In most cases it is more
+   efficient to call getBytes directly.
 width : int immutable
     Image width in pixels.
@@ -497,9 +498,10 @@
 getSize() : int
     Resturns the size of the binary buffer representing the image buffer.
-   the size of the byte array. The byte array is then immediately discarded. In most
+   getBytes and then computes the size of the byte array. The byte
+   array is then immediately discarded. In most cases it is more
 save( string filename [, mapObj_ parent_map=NULL ] ) : int
     Save image to *filename*.  The optional *parent_map* parameter must be
@@ -509,8 +511,9 @@
     Write image data to an open file descriptor or, by default, to *stdout*.
     Returns MS_SUCCESS or MS_FAILURE.
-.. note:: This method is current enabled for Python and C# only. C# supports writing onto a
-   Stream object. User-contributed typemaps are needed for Perl, Ruby, and Java.
+.. note:: This method is current enabled for Python and C# only. C#
+   supports writing onto a Stream object. User-contributed typemaps
+   are needed for Perl, Ruby, and Java.
 .. note:: The free() method of imageObj has been deprecated.  In MapServer
    revisions 4+ all instances of imageObj will be properly disposed of by
@@ -853,12 +856,12 @@
 labelitem : string
     Attribute defining feature label text.
-labelmaxscale : float
+labelmaxscaledenom : float
+    Minimum scale at which layer will be labeled.
+labelminscaledenom : float
     Maximum scale at which layer will be labeled.
-labelminscale : float
-    Minimum scale at which layer will be labeled.
 labelrequires : string
     Logical expression.
@@ -872,14 +875,14 @@
     Maximum number of layer features that will be drawn.  For shapefile data
     this means the first N features where N = maxfeatures.
-maxscale : float
-    Maximum scale at which layer will be drawn.
+    Minimum scale at which layer will be drawn.
     Layer metadata.
-minscale : float
-    Minimum scale at which layer will be drawn.
+    Maximum scale at which layer will be drawn.
     Unique identifier for layer.
@@ -906,7 +909,8 @@
     Logical expression.
 sizeunits : int
-    Units of class size values. MS_INCHES, MS_FEET, MS_MILES, MS_NAUTICALMILES, MS_METERS, MS_KILOMETERS, MS_DD or MS_PIXELS
+    Units of class size values. MS_INCHES, MS_FEET, MS_MILES,
+    MS_NAUTICALMILES, MS_METERS, MS_KILOMETERS, MS_DD or MS_PIXELS
 status : int
     MS_ON, MS_OFF, or MS_DEFAULT.
@@ -914,7 +918,7 @@
 styleitem : string
     Attribute defining styles.
-symbolscale : float
+symbolscaledenom : float
     Scale at which symbols are default size.
 template : string
@@ -931,7 +935,8 @@
     Search buffer for point and line queries.
 toleranceunits : int
-    MS_INCHES, MS_FEET, MS_MILES, MS_NAUTICALMILES, MS_METERS, MS_KILOMETERS, MS_DD or MS_PIXELS
+    MS_INCHES, MS_FEET, MS_MILES, MS_NAUTICALMILES, MS_METERS,
+    MS_KILOMETERS, MS_DD or MS_PIXELS
 transform : int
     Whether or not layer data is to be transformed to image units.
@@ -1104,8 +1109,8 @@
     Returns the index at which the class was inserted.
 isVisible( ) : int
-    Returns MS_TRUE or MS_FALSE after considering the layer status, minscale,
-    and maxscale within the context of the parent map.
+    Returns MS_TRUE or MS_FALSE after considering the layer status, minscaledenom,
+    and maxscaledenom within the context of the parent map.
 moveClassDown( int class ) : int
     The class specified by the class index will be moved up into
@@ -1487,7 +1492,7 @@
 resolution : float
     Nominal DPI resolution.  Default is 72.
-scale : float
+scaledenom : float
     The nominal map scale.  A value of 25000 means 1:25000 scale.
 scalebar : scalebarObj_ immutable
@@ -2510,8 +2515,9 @@
     Draws the individual shape using layer.  Returns MS_SUCCESS or MS_FAILURE.
 equals( shapeObj shape2 ) : int
-    Returns MS_TRUE if the shape and shape2 are equal (geometry only). Returns -1
-    on error and MS_FALSE otherwise. Requires GEOS support.
+    Returns MS_TRUE if the shape and shape2 are equal (geometry
+    only). Returns -1 on error and MS_FALSE otherwise. Requires GEOS
+    support.
 fromWKT( char \*wkt ) : shapeObj
     Returns a new shapeObj based on a well-known text representation of a
@@ -2636,33 +2642,37 @@
     Foreground or fill pen color.
 mincolor : colorObj_
-    Attribute for Color Range Mapping (:ref:`rfc6`). mincolor, minvalue, maxcolor,
-    maxvalue define the range for mapping a continuous feature value to a continuous
-    range of colors when rendering the feature on the map.
+    Attribute for Color Range Mapping (:ref:`rfc6`). mincolor,
+    minvalue, maxcolor, maxvalue define the range for mapping a
+    continuous feature value to a continuous range of colors when
+    rendering the feature on the map.
 minsize : int
     Minimum pen or symbol width for scaling styles.
 minvalue : double
 minwidth : int
     Minimum width of the symbol.
 maxcolor : colorObj_
 maxsize : int
     Maximum pen or symbol width for scaling.
 maxvalue : double
 maxwidth : int
     Maximum width of the symbol.
@@ -2677,13 +2687,15 @@
     Outline pen color.
 rangeitem : string
-    Attribute/field that stores the values for the Color Range Mapping (:ref:`rfc6`).
+    Attribute/field that stores the values for the Color Range Mapping
+    (:ref:`rfc6`).
     Pixel width of the style's pen or symbol.
 sizeitem : string
-    Attribute/field that stores the size to be used in rendering. Value is given in pixels.
+    Attribute/field that stores the size to be used in
+    rendering. Value is given in pixels.
 symbol : int
     The index within the map symbolset of the style's symbol.
@@ -2896,8 +2908,8 @@
 map : mapObj immutable
     Reference to parent mapObj.
-maxscale : float
-    Maximum map scale.
+    Minimum map scale.
 maxtemplate : string
     **TODO**
@@ -2905,8 +2917,8 @@
-minscale : float
-    Minimum map scale.
+    Maximum map scale.
 mintemplate : string
     **TODO**
Modified: trunk/docs/en/mapscript/mapscript.txt
--- trunk/docs/en/mapscript/mapscript.txt	2011-08-03 21:03:17 UTC (rev 11985)
+++ trunk/docs/en/mapscript/mapscript.txt	2011-08-03 21:34:11 UTC (rev 11986)
-maxscale : float
-minscale : float
 getSize() : int
@@ -509,8 +511,9 @@
 labelitem : string
     Logical expression.
-maxscale : float
     Layer metadata.
-minscale : float
@@ -906,7 +909,8 @@
     Logical expression.
 sizeunits : int
 status : int
@@ -914,7 +918,7 @@
 styleitem : string
 template : string
@@ -931,7 +935,8 @@
 transform : int
 isVisible( ) : int
 resolution : float
-scale : float
+scaledenom : float
+    support.
 minsize : int
 minvalue : double
 minwidth : int
 maxsize : int
 maxvalue : double
 maxwidth : int
     Outline pen color.
 rangeitem : string
+    (:ref:`rfc6`).
 sizeitem : string
 symbol : int
-maxscale : float
     **TODO**
-minscale : float
     **TODO**
