[mapserver-commits] r11995 - branches/branch-6-0/docs/en
trunk/docs/en
svn at osgeo.org
svn at osgeo.org
Fri Aug 5 03:26:53 EDT 2011
Author: havatv
Date: 2011-08-05 00:26:53 -0700 (Fri, 05 Aug 2011)
New Revision: 11995
branches/branch-6-0/docs/en/introduction.txt
trunk/docs/en/introduction.txt
Added a note on file organisation to mapfile example in introduction (#3087)
Modified: branches/branch-6-0/docs/en/introduction.txt
--- branches/branch-6-0/docs/en/introduction.txt 2011-08-04 13:17:27 UTC (rev 11994)
+++ branches/branch-6-0/docs/en/introduction.txt 2011-08-05 07:26:53 UTC (rev 11995)
@@ -302,8 +302,30 @@
top of other layers)
* Using relative paths is always recommended
* Paths should be quoted (single or double quotes are accepted)
+ * The above example is built on the following directory structure:
+ * The mapfile could be placed anywhere, as long as it is
+ accessible to the web server. Normally, one would try to
+ avoid placing it at a location that makes it accessible on the
+ web. Let us say it is placed in /home/msuser/mapfiles/
+ * The location of the font file is given relative to the map
+ file, in this case: /home/msuser/etc/fonts.txt
+ * The location of the datasets (`bluemarble.gif`) is given
+ relative to the map file, in this case: /home/msuser/data/
+ * The location of the symbol file is given relative to the map
+ file, in this case: /home/msuser/etc/symbols.txt
+ * The files generated by Mapserver will be placed in the
+ directory /ms4w/tmp/ms_tmp/. The web server must be able to
+ place files in this directory. The web server must make this
+ directory available as /ms_tmp (if the web server is on
+ `www.ms.org`, the web address to the directory must be:
+ `httpd://www.ms.org/ms_tmp/`.
:ref:`MAP` Object
Modified: trunk/docs/en/introduction.txt
--- trunk/docs/en/introduction.txt 2011-08-04 13:17:27 UTC (rev 11994)
+++ trunk/docs/en/introduction.txt 2011-08-05 07:26:53 UTC (rev 11995)
:ref:`MAP` Object
More information about the mapserver-commits
