[mapserver-commits] r12002 -
branches/branch-6-0/docs/en/input/vector trunk/docs/en/input/vector
svn at osgeo.org
svn at osgeo.org
Fri Aug 5 05:52:26 EDT 2011
Author: havatv
Date: 2011-08-05 02:52:25 -0700 (Fri, 05 Aug 2011)
New Revision: 12002
branches/branch-6-0/docs/en/input/vector/postgis.txt
trunk/docs/en/input/vector/postgis.txt
Added using before unique in the postgis document (#3127)
Modified: branches/branch-6-0/docs/en/input/vector/postgis.txt
--- branches/branch-6-0/docs/en/input/vector/postgis.txt 2011-08-05 09:41:08 UTC (rev 12001)
+++ branches/branch-6-0/docs/en/input/vector/postgis.txt 2011-08-05 09:52:25 UTC (rev 12002)
@@ -73,7 +73,7 @@
CONNECTION "dbname=yourdatabasename user=yourdbusername"
DATA "the_geom from (select g.gid, g.the_geom, a.attr1, a.attr2 from
geotable g join attrtable a on g.gid = a.aid) as subquery
- unique gid using srid=4326"
+ using unique gid using srid=4326"
This example shows using a geometry function and database sort to
limit the number of features and vertices returned to MapServer:
@@ -84,7 +84,7 @@
DATA "the_geom from (select g.gid, ST_Simplify(g.the_geom, 10.0) as
the_geom from geotable g order by ST_Area(g.the_geom) desc
- limit 10) as subquery unique gid using srid=4326"
+ limit 10) as subquery using unique gid using srid=4326"
This example shows the use of the !BOX! substitution string to
over-ride the default inclusion of the map bounding box in the SQL. By
@@ -101,7 +101,7 @@
DATA "the_geom from (select g.gid, ST_Union(g.the_geom, 10.0) as
the_geom from geotable g where ST_Intersects(g.geom,!BOX!)) as
- subquery unique gid using srid=4326"
+ subquery using unique gid using srid=4326"
OGRINFO Examples
Modified: trunk/docs/en/input/vector/postgis.txt
--- trunk/docs/en/input/vector/postgis.txt 2011-08-05 09:41:08 UTC (rev 12001)
+++ trunk/docs/en/input/vector/postgis.txt 2011-08-05 09:52:25 UTC (rev 12002)
@@ -73,7 +73,7 @@
@@ -84,7 +84,7 @@
@@ -101,7 +101,7 @@
OGRINFO Examples
More information about the mapserver-commits
