[mapserver-commits] r12019 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Sat Aug 6 07:14:56 EDT 2011
Author: havatv
Date: 2011-08-06 04:14:56 -0700 (Sat, 06 Aug 2011)
New Revision: 12019
   branches/branch-6-0/docs/en/mapfile/style.txt
   trunk/docs/en/mapfile/style.txt
Changed 5.2 to 5.4 for the introduction of attribute binding of width (#3448)
Modified: branches/branch-6-0/docs/en/mapfile/style.txt
--- branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-06 11:09:08 UTC (rev 12018)
+++ branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-06 11:14:56 UTC (rev 12019)
@@ -345,7 +345,7 @@
       specifies the thickness of the hatched lines.
       For its use with hatched lines, see Example #7 in the
       :ref:`symbology examples <sym_examples>`.
-    - [*attribute*] was added in version 5.2 to specify the attribute
+    - [*attribute*] was added in version 5.4 to specify the attribute
       to use for the width value. The hard brackets [] are required.
     - Starting from version 5.4, the value can also be a decimal
       value (and not only integer).
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-08-06 11:09:08 UTC (rev 12018)
+++ trunk/docs/en/mapfile/style.txt	2011-08-06 11:14:56 UTC (rev 12019)
@@ -345,7 +345,7 @@
